Oberfläche für systemsettings Nutzer hinzufügen geht nicht?
Siehe den screenshot:
Fehlermeldung
Generated on 2026-01-21 15:09:1769004566
#################### inxi -Fxzc0 ########################
  Kernel: 6.12.64-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
  Desktop: Xfce v: 4.20.1 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 81RS v: Lenovo Yoga S740-14IIL serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <superuser required> Firmware: UEFI
    vendor: LENOVO v: BYCN39WW date: 05/28/2021
  ID-1: BAT0 charge: 64.4 Wh (98.6%) condition: 65.3/62 Wh (105.3%) volts: 17.02 min: 15.4
    model: LGC L19L4PD2 status: full
  Info: quad core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake rev: 5 cache:
    L1: 320 KiB L2: 2 MiB L3: 8 MiB
  Speed (MHz): avg: 1100 min/max: 400/3900 cores: 1: 1100 2: 1100 3: 1100 4: 1100 5: 1100 6: 1100
    7: 1100 8: 1100 bogomips: 23968
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel arch: Gen-11
    bus-ID: 00:02.0
  Device-2: NVIDIA GP108M [GeForce MX250] vendor: Lenovo driver: nvidia v: 570.207 arch: Pascal
    bus-ID: 2b:00.0
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 3-5:5
  Display: x11 server: X.Org v: 21.1.21 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    dri: iris gpu: i915 resolution: 1: 1920x1080~60Hz 2: N/A
  API: EGL v: 1.5 drivers: iris,nvidia,swrast platforms: active: gbm,x11,surfaceless,device
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Plus Graphics (ICL GT2)
  API: Vulkan v: 1.4.335 drivers: intel,nvidia surfaces: N/A devices: 2
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
    gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci-intel-icl
    bus-ID: 00:1f.3
  API: ALSA v: k6.12.64-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.9 status: active
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
  IF: wlp0s20f3 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB bus-ID: 2-1.4:5
  IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-10:8
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: see --recommends
  Local Storage: total: 1.87 TiB used: 432.04 GiB (22.6%)
  ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB temp: 46.9 C
  ID-2: /dev/sda vendor: SanDisk model: Extreme size: 29.25 GiB type: USB
  ID-3: /dev/sdb vendor: Western Digital model: WD10EARX-00N0YB0 size: 931.51 GiB type: USB
  ID-1: / size: 57.85 GiB used: 39.08 GiB (67.5%) fs: ext4 dev: /dev/nvme0n1p8
  ID-2: /boot/efi size: 259.5 MiB used: 117.5 MiB (45.3%) fs: vfat dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 16.67 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p9
  System Temperatures: cpu: 46.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.19 GiB used: 2.94 GiB (19.4%)
  Processes: 319 Uptime: 17h 25m Init: systemd
  Packages: 1739 Compilers: clang: 21.1.6 gcc: 15.2.1 Client: Unknown Client: wrapper-2.0
    inxi: 3.3.40
Ok, ich könnte mich ja auch mal mehr mit useradd im Terminal vertraut machen. Aber was in den Manjaro-Settings ist sollte auch funktionieren
Pass auf daß Du kein Leerzeichen hinten dran hängst.
Aber das ist hier nicht die Ursache.
Der Grund für die Fehlermeldung ist, daß Benutzernamen nur Kleinbuchstaben enthalten dürfen.
berta wäre o.k. - Berta nicht
… nicht gut aussagekräftige Fehlermeldung - muß man wissen :slightly_smiling_face:
Danke für den Tipp .. da wäre ich nie drauf gekommen !
Ich war ja nie admin, hier die einleuchtende Erklärung:
Begründung durch KI
