I’m having some issues saving the settings of above-mentioned application. I’ve tried sudo
-ing it, but to no avail… I will always get the pop-up window with the following dialog. Even if I press ‘Apply’ and save the xconf
, then press ‘Quit’.
The settings do not seem to get saved, as when I enter the system I always have to disable G-Sync - even if the box is unticked.
Cheers
