Hi !
I have the same problem as this thread, with
[leo@zephyrus ~]$ sudo pacman -Syyu
[sudo] password for leo:
:: Synchronising package databases...
core 129,3 KiB 779 KiB/s 00:00 [############################################] 100%
extra 8,3 MiB 3,27 MiB/s 00:03 [############################################] 100%
community 45,0 B 2,20 KiB/s 00:00 [############################################] 100%
multilib 143,0 KiB 2,22 MiB/s 00:00 [############################################] 100%
warning: amd-ucode: local (20230810.7be2766d-1) is newer than core (20230804.7be2766d-2)
warning: base: local (3-2) is newer than core (3-1)
warning: base-devel: local (1-2) is newer than core (1-1)
warning: cryptsetup: local (2.6.1-3.4) is newer than core (2.6.1-3)
warning: filesystem: local (2023.03.21-1) is newer than core (2023.01.31-1)
warning: linux-firmware: local (20230810.7be2766d-1) is newer than core (20230804.7be2766d-2)
warning: linux-firmware-whence: local (20230810.7be2766d-1) is newer than core (20230804.7be2766d-2)
warning: mkinitcpio: local (36-4) is newer than core (36-1)
warning: nano-syntax-highlighting: local (2020.10.10+10+g1aa64a8-2) is newer than extra (2020.10.10-1)
warning: networkmanager-strongswan: local (1.6.0-1.0) is newer than extra (1.6.0-1)
warning: pacman: local (6.0.2-13) is newer than core (6.0.2-7)
warning: plymouth: local (22.02.122-14) is newer than extra (22.02.122-7)
warning: python-anyascii: local (0.3.2-2) is newer than extra (0.3.2-1)
warning: ranger: local (1.9.3+674+gfe7c3b28-1) is newer than extra (1.9.3-9)
resolving dependencies...
:: installing nvidia-utils (535.104.05-1) breaks dependency 'nvidia-utils=535.98' required by linux61-nvidia
I had a problem before connecting to repositories and saw /etc/pacman.d/mirrorlist had no mirrors inside so I generated some with Arch Linux - Pacman Mirrorlist Generator .
if I run mhwd-kernel -li
I get
[leo@zephyrus ~]$ mhwd-kernel -li
Currently running: 6.1.44-1-MANJARO (linux61)
* linux61
[leo@zephyrus ~]$ ```
So it's not a kernel problem, what should I do ? (given the problem is similar but with maybe a different root should I create another post ?)
