Hello everyone!
My sincere apologies if this has been asked in some other form I simply could not find. I’ve been tinkering with this problem for a couple days now and my google-fu is simply not helping me find a solution.
I’d like to use my 1660 as the primary display driver to run my desktop/gaming/daily use.
I’d like to use my Tesla K80 (x2) for things like Stable Diffusion, Tensorflow trainings, etc.
I’ve tried the older drivers by figuring out these cards are Kepler cards, finding the appropriate (I think) package and installing.
When I tried older drivers, expectedly, my display stopped working.
I’m afraid my options may be limited to some sort of virtual machine pass through, but before I go down that rabbit hole, I figured I’d ask first:
Is it possible to use TF and SD and other AI things with the K80 while using a modern driver for my desktop usage at the same time?
Here is the output of all the things I could think of that might be helpful/relevant. If I’ve left something out you’d like to see please let me know:
$ uname -a
Linux hostname-1TB 5.15.84-1-MANJARO #1 SMP PREEMPT Mon Dec 19 13:16:33 UTC 2022 x86_64 GNU/Linux
$ pacman -Q nvidia
linux515-nvidia 525.60.11-5
$ lspci | grep NVIDIA
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1660 SUPER] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU116 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller: NVIDIA Corporation TU116 USB Type-C UCSI Controller (rev a1)
07:00.0 3D controller: NVIDIA Corporation GK210GL [Tesla K80] (rev a1)
08:00.0 3D controller: NVIDIA Corporation GK210GL [Tesla K80] (rev a1)
$ nvidia-smi
Wed Dec 21 18:02:11 2022
| NVIDIA-SMI 525.60.11 Driver Version: 525.60.11 CUDA Version: 12.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 26% 36C P8 10W / 125W | 511MiB / 6144MiB | 7% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 631 G /usr/lib/Xorg 181MiB |
| 0 N/A N/A 657 G /usr/bin/kwalletd5 2MiB |
| 0 N/A N/A 739 G /usr/bin/ksmserver 2MiB |
| 0 N/A N/A 741 G /usr/bin/kded5 2MiB |
| 0 N/A N/A 742 G /usr/bin/kwin_x11 73MiB |
| 0 N/A N/A 759 G /usr/bin/plasmashell 23MiB |
| 0 N/A N/A 786 G ...de-authentication-agent-1 2MiB |
| 0 N/A N/A 788 G ...ib/xdg-desktop-portal-kde 2MiB |
| 0 N/A N/A 880 G /usr/bin/msm_kde_notifier 2MiB |
| 0 N/A N/A 881 G /usr/lib/kdeconnectd 2MiB |
| 0 N/A N/A 894 G /usr/bin/kaccess 2MiB |
| 0 N/A N/A 896 G /usr/bin/pamac-tray-plasma 2MiB |
| 0 N/A N/A 2762 G /usr/lib/baloorunner 2MiB |
| 0 N/A N/A 4855 G ...628653838712401211,131072 174MiB |
| 0 N/A N/A 6626 G ...RendererForSitePerProcess 25MiB |
| 0 N/A N/A 8915 G /usr/bin/konsole 2MiB |
$ cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 165
model name : Intel(R) Core(TM) i5-10600K CPU @ 4.10GHz
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
cache size : 12288 KB
physical id : 0
siblings : 12
core id : 0
cpu cores : 6
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp pku ospke md_clear flush_l1d arch_capabilities
bugs : spectre_v1 spectre_v2 spec_store_bypass swapgs itlb_multihit srbds mmio_stale_data retbleed eibrs_pbrsb
bogomips : 8203.45
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 1
cpu cores : 6
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 2
cpu cores : 6
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 800.025
physical id : 0
siblings : 12
core id : 3
cpu cores : 6
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 4
cpu cores : 6
apicid : 8
initial apicid : 8
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 5
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 1381.274
physical id : 0
siblings : 12
core id : 5
cpu cores : 6
apicid : 10
initial apicid : 10
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 6
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 0
cpu cores : 6
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 7
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 1
cpu cores : 6
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 8
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 2
cpu cores : 6
apicid : 5
initial apicid : 5
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 9
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 1373.572
physical id : 0
siblings : 12
core id : 3
cpu cores : 6
apicid : 7
initial apicid : 7
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 10
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 4
cpu cores : 6
apicid : 9
initial apicid : 9
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
processor : 11
cpu family : 6
model : 165
stepping : 5
microcode : 0xf4
cpu MHz : 4100.000
physical id : 0
siblings : 12
core id : 5
cpu cores : 6
apicid : 11
initial apicid : 11
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 8203.45
clflush size : 64
power management:
