I am trying to install nvidia drivers, driver is seemed to be installed still nvidia-settings app does’t open. Current window manager is x11.
I am a newbie in manjaro, thanks in advance.
here is the inxi -G output
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] driver: nvidia
v: 470.182.03
Device-2: AMD Renoir driver: amdgpu v: kernel
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: modesetting dri: radeonsi gpu: amdgpu resolution: 1920x1080~144Hz
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.26-1-MANJARO)
I’ve installed video-hybrid-amd-nvidia-470xx-prime and when I run nvidia-settings I get this
(nvidia-settings:5283): Gtk-WARNING **: 21:26:57.616: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(nvidia-settings:5283): Gtk-WARNING **: 21:26:57.616: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
ERROR: Unable to load info from any available system
mhwd -li output
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-470xx-prime 2023.03.23 false PCI
I think in hybrid mode you can’t start Nvidia Settings directly, you may need to start it with prime-run nvidia-settings and you’ll not have real control here I guess.
Tried it still getting same result.
Hi @JoKer
What is the output of pacman -Qi nvidia-settings ?
If the package is not installed just run sudo pacman -S nvidia-settings.
For detailed explanations: [Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
It is installed as he gave its terminal output:
JoKer
10 May 2023 14:41
6
here is the result
Version : 470.182.03-3
Description : Tool for configuring the NVIDIA graphics driver
Architecture : x86_64
URL : https://github.com/NVIDIA/nvidia-settings
Licenses : GPL2
Groups : None
Provides : nvidia-settings=470.182.03
Depends On : jansson gtk3 libxv libvdpau nvidia-utils=470.182.03 libxnvctrl=470.182.03
Optional Deps : None
Required By : None
Optional For : nvidia-470xx-utils
Conflicts With : nvidia-settings
Replaces : None
Installed Size : 1544.01 KiB
Packager : Mark Wagie <mark@manjaro.org>
Build Date : Fri Mar 31 20:18:23 2023
Install Date : Sun May 7 15:44:39 2023
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Is prime working?
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
What all prime is installed?
pacman -Qs prime
Does the env var work any differently?
Env var?
DRI_PRIME=1 glxinfo | grep 'renderer string'
DRI_PRIME=1 nvidia-settings
JoKer
12 May 2023 11:23
8
Here is the output of every command
OpenGL renderer string: AMD Radeon Graphics (renoir, LLVM 15.0.7, DRM 3.49, 6.1.26-1-MANJARO)
OpenGL renderer string: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2
cscs:
pacman -Qs prime
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
(nvidia-settings:3054): Gtk-WARNING **: 16:48:56.242: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(nvidia-settings:3054): Gtk-WARNING **: 16:48:56.242: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
I wonder …
lspci
ls /sys/bus/pci/devices/
JoKer
16 May 2023 09:23
10
Here’s the output:
cscs:
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GA107M [GeForce RTX 3050 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 2291 (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: MEDIATEK Corp. MT7921 802.11ax PCI Express Wireless Network Adapter
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller 980
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
cscs:
0000:00:00.0 0000:00:02.1 0000:00:14.0 0000:00:18.3 0000:01:00.0 0000:05:00.0 0000:05:00.5
0000:00:00.2 0000:00:02.2 0000:00:14.3 0000:00:18.4 0000:01:00.1 0000:05:00.1 0000:05:00.6
0000:00:01.0 0000:00:02.4 0000:00:18.0 0000:00:18.5 0000:02:00.0 0000:05:00.2
0000:00:01.1 0000:00:08.0 0000:00:18.1 0000:00:18.6 0000:03:00.0 0000:05:00.3
0000:00:02.0 0000:00:08.1 0000:00:18.2 0000:00:18.7 0000:04:00.0 0000:05:00.4
cscs
16 May 2023 09:34
11
Can you try and see if any of these can initialize the nvidia?
DRI_PRIME=pci-0000_01_00_0 glxinfo | grep 'renderer string'
__NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep 'renderer string'
__NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia DRI_PRIME=pci-0000_01_00_0 glxinfo | grep 'renderer string'
JoKer
16 May 2023 10:02
12
Here,
cscs
16 May 2023 10:09
13
woohoo.
Looks like we can wake up the nvidia
This one should be the same as prime-run.
Lets go with the other one that specifies the pci address though.
Please run the following:
__NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia DRI_PRIME=pci-0000_01_00_0 nvidia-settings
… eh, eh ?
JoKer
16 May 2023 16:31
14
Still the same result.
(nvidia-settings:3837): Gtk-WARNING **: 21:50:40.828: Theme parsing error: gtk.css:1649:16: '-gtk-icon-size' is not a valid property name
(nvidia-settings:3837): Gtk-WARNING **: 21:50:40.828: Theme parsing error: gtk.css:1652:16: '-gtk-icon-size' is not a valid property name
Sorry, I haven’t mentioned that I am currently running the manjaro on a dual boot system with windows 10. I cannot edit the actual post now. Could there be an issue because of this? I have already switched off my secure boot and fast boot options
