Hi all,
I’ve been using Manjaro for about 2 years now but around 4 months ago Nvidia-settings started to reset my display config so that only my left most vertical monitor was active.
Here is my xrandr output
Screen 0: minimum 8 x 8, current 3640 x 1920, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 connected 1080x1920+0+0 right (normal left inverted right x axis y axis) 531mm x 299mm
1920x1080 60.00*+ 59.99 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected (normal left inverted right x axis y axis)
1920x1080 59.93 + 60.00 59.94 50.00
1680x1050 59.95
1280x1024 60.02
1280x960 60.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected primary 2560x1080+1080+840 (normal left inverted right x axis y axis) 64mm x 27mm
2560x1440 59.95 +
2560x1080 59.94*
1920x1080 75.00 60.00 59.94 50.00
1720x1440 75.00
1680x1050 59.95
1440x900 59.89
1280x960 60.00
1280x800 59.81
1280x720 59.94 50.00
1152x864 75.00
720x576 50.00
720x480 59.94
Here is my xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 525.60.11
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Ancor Communications Inc VE247"
HorizSync 30.0 - 83.0
VertRefresh 50.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3060 Ti"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-6"
Option "metamodes" "DP-1: nvidia-auto-select +0+0 {rotation=right, AllowGSYNC=Off}, DP-5: 2560x1080 +1080+840 {AllowGSYNC=Off}; DP-1: 1024x768 +0+0, DP-5: nvidia-auto-select +1024+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1024x768_70 +0+0, DP-5: nvidia-auto-select +1024+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1024x768_60 +0+0, DP-5: nvidia-auto-select +1024+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600 +0+0, DP-5: nvidia-auto-select +800+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_72 +0+0, DP-5: nvidia-auto-select +800+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_60 +0+0, DP-5: nvidia-auto-select +800+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_56 +0+0, DP-5: nvidia-auto-select +800+0, DP-3: nvidia-auto-select +1080+840; DP-1: 720x576 +0+0, DP-5: nvidia-auto-select +720+0, DP-3: nvidia-auto-select +1080+840; DP-1: 720x480 +0+0, DP-5: nvidia-auto-select +720+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480 +0+0, DP-5: nvidia-auto-select +640+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_72 +0+0, DP-5: nvidia-auto-select +640+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_60 +0+0, DP-5: nvidia-auto-select +640+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_60_0 +0+0, DP-5: nvidia-auto-select +640+0, DP-3: nvidia-auto-select +1080+840; DP-1: nvidia-auto-select +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1920x1080_60_0 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1920x1080_60_1 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1920x1080_50 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1680x1050 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1600x1200 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1440x900 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1366x768 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x1024 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x1024_60 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x960 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x720 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x720_60_0 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1280x720_50 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1152x864 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1024x768 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1024x768_70 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 1024x768_60 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_72 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_60 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 800x600_56 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 720x576 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 720x480 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_72 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_60 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: 640x480_60_0 +0+0, DP-3: nvidia-auto-select +1080+840; DP-1: nvidia-auto-select +0+0 {viewportin=1280x800, viewportout=1728x1080+96+0}, DP-3: nvidia-auto-select +1080+840"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
When using Nvida-settings to fix the configuration it keeps loosing the reference to which ever monitor is selected (UI shows im modifying setting for my middle onitor, but settings get applied to the left most monitor (middle monitor is Acer and left most is Asus so Im not getting them confused in the UI). Some times when it get the correct reference to the monitor the monitor will flash black, show enabled in the UI then immediately go back to disabled. After constatly setting display settings, hitting cancel if the ref is wrong and retying it seems to work sometime between 5 - 30 reconfigs which is really annoying every morning.
Let me know if theres any other info I can provide, Thanks!
Added screen shot of my settings UI, took about 20 tries to get the central monitor working, I have given up on the third monitor as it takes enough time just getting the central one up and running
Heres what my actual setup is, savin/ applying this never works
