Nvidia RTX 3050 Freezing - DELL G15 5530
I am running Manjaro XFCE edition in a Nvidia RTX 3050 DELL G15 5530 Laptop.
I use Linux for my research. Not a newbie, but a kind of limited in my technical skills.
  • My computer has frozen occasionally using Kernel 6.1.112-1 or 6.6.54-2
    • I am sticking with 6.1.112-1
  • My computer does not start properly or freezes much more frequently using 6.10.13-3
Here is the results of a inxi -Farz. Please let me know if you need anything else.
  Kernel: 6.1.112-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=a783dc56-3af3-47b6-9e29-edc2c511a372 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Dell product: Dell G15 5530 v: N/A
  Mobo: Dell model: 04HG9Y v: A00 serial: <superuser required> part-nu: 0BF8
    uuid: <superuser required> UEFI: Dell v: 1.19.0 date: 08/16/2024
  ID-1: BAT0 charge: 39.4 Wh (100.0%) condition: 39.4/54.9 Wh (71.8%)
    volts: 12.5 min: 11.4 model: SMP DELL P8P1P35 type: Li-poly serial: <filter>
    status: not charging cycles: 47
  Info: model: 13th Gen Intel Core i5-13450HX bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183) stepping: 1
    microcode: 0x129
  Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
    st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
    KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
    desc: 1x20 MiB
  Speed (MHz): avg: 800 min/max: 800/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
    bogomips: 83584
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
    active: DP-1,eDP-1 empty: none bus-ID: 0000:00:02.0 chip-ID: 8086:a78b
    class-ID: 0300
  Device-2: NVIDIA GN20-P0-R-K2 [GeForce RTX 3050 6GB Laptop GPU]
    vendor: Dell driver: nvidia v: 550.120 alternate: nouveau,nvidia_drm
    non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023
    bus-ID: 0000:01:00.0 chip-ID: 10de:25ec class-ID: 0300
  Device-3: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0c45:6d1a
    class-ID: 0e02
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0
    driver: X: loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
    dri: iris gpu: i915 display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
  Monitor-1: DP-1 model: Samsung LS27A600U serial: <filter> built: 2023
    res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x337mm (23.5x13.27")
    diag: 686mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  Monitor-2: eDP-1 model: Najing CEC Panda 0x005f built: 2021 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
    device-ID: 8086:a78b memory: 15.16 GiB unified: yes
  Device-1: Intel Raptor Lake High Definition Audio vendor: Dell
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:7a50 class-ID: 0401
  Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
    chip-ID: 10de:2291 class-ID: 0403
  API: ALSA v: k6.1.112-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3 chip-ID: 8086:7a70 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-7.1:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u7u1 state: up speed: 100 Mbps duplex: full mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
    driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
    class-ID: 0104
  Local Storage: total: 1.38 TiB used: 246.15 GiB (17.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 43.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: A-Data
    model: SM2P41C3 NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 92401091 temp: 53.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 113.03 GiB (12.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 324 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 97.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1270 pm: pacman pkgs: 1255 libs: 354 tools: pamac,yay pm: flatpak
    pkgs: 15
    1: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    5: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
  Memory: total: 32 GiB note: est. available: 31.04 GiB used: 3.41 GiB (11.0%)
  Processes: 367 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
    image: 12.4 GiB services: upowerd,xfce4-power-manager Init: systemd v: 256
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.36
Any help is appreciated.
Thanks a lot!
Hi!
Recently I bought a Dell g15 5530 with the 4050 gpu and I also have a lot of issues regarding the Nvidia proprietary drivers.
I am not a Manjaro user as I rather prefer Nixos but considering that I saw no answer to your question I decided to give you a few suggestions.
With my current hardware, I can only use the proprietary drivers from Nvidia with the kernel version up to the last LTS branch (version 6.6), otherwise the screen freezes every time a few seconds in after entering the Plasma session.
It doesn’t matter if it is using Xorg or Wayland, nor the Desktop Environment.
Also, blacklisting the Nouveau drivers has no effect when using the proprietary drivers.
Interesting enough is that I found comments on Reddit saying that other notebooks with the same specs showed no similar issues, therefore is likely an issue with Dell (both 3050 and 4050 versions regardless of CPU).
An alternative that I accepted is to use the open-source nvidia kernel modules (not the Nouveau drivers), with this option I could install the most recent kernel version without any issue.
There were no major difference in gaming performance, at least with the ones I observed.
About Manjaro, I don’t know how you can install the opensource modules but considering the same Arch base you might be able to follow the wiki instructions.
Fan broken or not running? Other hardware issue within the cooling system? Clean-out needed?
