Hello to all,
yesterday I have installed Manjaro linux with nouveau driver, sometime during normal activity my display still freeze,
someone could help me to solve this my problem?
below is possible to see some information about my pc:
sudo inxi -Fxxxa --no-host
System: Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=4a579339-924a-40ba-9a3b-b3b8fcef21c9 rw quiet apparmor=1
Desktop: Cinnamon 4.8.3 tk: GTK 3.24.24 wm: Muffin dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP EliteBook 8540w v: N/A serial: CND0260DMB Chassis: type: 10
serial: CND0260DMB
Mobo: Hewlett-Packard model: 1521 v: KBC Version 32.36 serial: CND0260DMB BIOS: Hewlett-Packard v: 68CVD Ver. F.60
date: 11/11/2015
Battery: ID-1: BAT0 charge: 10.9 Wh condition: 14.7/14.7 Wh (100%) volts: 16.2/14.4 model: Hewlett-Packard Primary
type: Li-ion serial: 02268 2010/03/25 status: Unknown
CPU: Info: Dual Core model: Intel Core i7 M 620 bits: 64 type: MT MCP arch: Nehalem family: 6 model-id: 25 (37)
stepping: 2 microcode: 11 L1 cache: 32 KiB L2 cache: 4 MiB L3 cache: 3.9 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21290
Speed: 1511 MHz min/max: 1199/2667 MHz base/boost: 2657/2666 boost: enabled volts: 1.2 V ext-clock: 133 MHz
Core speeds (MHz): 1: 1511 2: 1667 3: 1509 4: 1450
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GT216GLM [Quadro FX 880M] vendor: Hewlett-Packard driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:0a3c
Device-2: Chicony HP Webcam [2 MP Macro] type: USB driver: uvcvideo bus ID: 1-1.5:3 chip ID: 04f2:b15e
Display: server: X.Org 1.20.10 driver: nouveau unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: LVDS-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: NVA5 v: 3.3 Mesa 20.3.1 direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:3b56
Device-2: NVIDIA GT216 HDMI Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0be2
Sound Server: ALSA v: k5.10.2-2-MANJARO
Network: Device-1: Intel 82577LM Gigabit Network vendor: Hewlett-Packard driver: e1000e v: kernel port: 6020 bus ID: 00:19.0
chip ID: 8086:10ea
IF: enp0s25 state: down mac: 70:5a:b6:b4:c3:72
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel port: 5000 bus ID: 44:00.0 chip ID: 8086:4238
IF: wlo1 state: up mac: 00:24:d7:2a:7b:98
Drives: Local Storage: total: 912.89 GiB used: 99.8 GiB (10.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G size: 447.13 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: 50026B7380768918 rev: K1B3
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9500420AS size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s serial: 5VJ6LH8V rev: HPM1
Partition: ID-1: / raw size: 447.13 GiB size: 439.11 GiB (98.21%) used: 99.8 GiB (22.7%) fs: ext4 block size: 4096 B
dev: /dev/sda1 maj-min: 8:1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 48.0 C mobo: 0.0 C gpu: nouveau temp: 57.0 C
Info: Processes: 212 Uptime: 8m wakeups: 2 Memory: 7.63 GiB used: 2.29 GiB (30.0%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1309 lib: 407 flatpak: 0 Shell: Bash (sudo) v: 5.1.0
running in: gnome-terminal inxi: 3.2.01
below the error detected by using the command: journalctl -p err..alert
gen 01 17:05:52 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:05:54 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:05:56 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:05:59 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:01 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:03 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:06 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:08 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:10 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:12 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:30 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:32 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:34 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:36 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:38 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:40 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:42 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 01 17:06:44 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
-- Boot 3964a0d793714c9b8da09d691a5403e9 --
gen 01 17:07:20 8540w systemd-tmpfiles[231]: /etc/tmpfiles.d/phy0-led.conf:1: Unknown modifiers in command 'systemd-tmpfiles'
gen 01 17:07:21 8540w systemd-tmpfiles[362]: /etc/tmpfiles.d/phy0-led.conf:1: Unknown modifiers in command 'systemd-tmpfiles'
gen 01 17:22:37 8540w systemd-tmpfiles[932]: /etc/tmpfiles.d/phy0-led.conf:1: Unknown modifiers in command 'systemd-tmpfiles'
gen 01 19:09:48 8540w lightdm[890]: gkr-pam: unable to locate daemon control file
gen 01 19:09:57 8540w colord-sane[1269]: io/hpmud/pp.c 627: unable to read device-id ret=-1
gen 01 19:10:14 8540w pulseaudio[1116]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
gen 02 01:17:50 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:17:52 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:17:54 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:17:59 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:02 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:06 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:08 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:10 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:50 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:52 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:54 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:18:56 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:02 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:04 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:06 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:14 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:16 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:18 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:22 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:24 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:26 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:28 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:31 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:33 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:38 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:40 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:42 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:44 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:46 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:48 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:51 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:54 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:57 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:19:59 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:20:03 8540w kernel: nouveau 0000:01:00.0: DRM: base-0: timeout
gen 02 01:20:04 8540w kernel: nouveau 0000:01:00.0: disp: ERROR 5 [INVALID_STATE] 0b [] chid 1 mthd 0080 data 00000001
gen 02 01:20:04 8540w pulseaudio[27402]: GetManagedObjects() failed: org.freedesktop.systemd1.ShuttingDown: Refusing activation, D-Bus is shutting down.
gen 02 01:20:05 8540w kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot c8adafbcbc144d8087128c1d5f6acbc5 --
gen 02 01:20:25 8540w systemd-tmpfiles[244]: /etc/tmpfiles.d/phy0-led.conf:1: Unknown modifiers in command 'systemd-tmpfiles'
gen 02 01:20:26 8540w systemd-tmpfiles[405]: /etc/tmpfiles.d/phy0-led.conf:1: Unknown modifiers in command 'systemd-tmpfiles'
gen 02 01:20:58 8540w lightdm[903]: gkr-pam: unable to locate daemon control file
gen 02 01:21:06 8540w colord-sane[1161]: io/hpmud/pp.c 627: unable to read device-id ret=-1
gen 02 01:21:24 8540w pulseaudio[1012]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
thanks in advace to help me to solve this my issue
Luca
, i’m italian
, so, i try to follow two different way:
