steky9
20 February 2022 07:19
1
Updated Manjaro to the latest today for the first time in a couple of months. I didn’t watch the update as it was 3-4Gb of downloads etc, but at the end it seemed to be ok. After reboot, Xorg no longer loads.
I’ve put some logs up on pastebin. From googling, the problem seems to be that it can’t find the nvidia or nvidia-drm modules as shown in the Journal logs. But I’m not sure how best to fix it without making it a lot worse. I’ve already tried a mkinitcpio -P without any success.
https://pastebin.com/1d7mXyh1
Any ideas?
omano
20 February 2022 07:24
2
Try to install the previous driver.
sudo mhwd -r pci video-hybrid-intel-nvidia-prime
sudo mhwd -i pci video-hybrid-intel-nvidia-470xx-prime
Output of mhwd -l
and mhwd -li
could be also relevant as well as mhwd-kernel -li
//EDIT: or you could try forcing reinstall of Nvidia hybrid driver sudo mhwd -f -i pci video-hybrid-intel-nvidia-prime
//EDIT2: give the output of any command you try so we can see what is going on.
steky9
20 February 2022 07:36
3
>> mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.12.18 false PCI
>> mhwd -l
> 0000:01:00.0 (0300:10de:1382) Display controller nVidia Corporation:
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:04:00.0 (0300:10de:1382) Display controller nVidia Corporation:
> 0000:00:02.0 (0380:8086:1912) Display controller Intel Corporation:
omano
20 February 2022 07:39
4
So you have a hybrid system but the Intel card isn’t seen in MHWD? //EDIT: it is, at the bottom.
Then try that:
sudo mhwd -r pci video-linux
sudo mhwd -f -i pci video-nvidia
//EDIT: OK you have two Nvidia cards so I guess that’s why it is not as expected to me. So I’m not sure if you should remove the video-linux
driver…
steky9
20 February 2022 07:44
5
Originally I used the Intel card, but when I moved to multiple displays I changed it to the Nvidia. Its years ago now, so I can’t remember if I disabled it or not. I later added a second Nvidia card to try get a third display working again after I had to replace the monitor and it had a different connector type. Never got that working, but thats another days work.
In the interim, here’s some additional output. I’ll try the video-nvidia install at least and see how it goes
>> mhwd-kernel -li
Currently running: 5.15.19-2-rt29-MANJARO (linux515)
* linux510
* linux515
* linux54
* linux515-rt
>> inxi -Fazy
Kernel: 5.15.19-2-rt29-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
root=UUID=2e06d737-e3af-4be7-8d4f-d3b19bd603c0 rw quiet apparmor=1
Desktop: N/A dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Dell product: OptiPlex 7040 v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0Y7WYT v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: 1.18.1 date: 12/23/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 100% rechargeable: yes status: N/A
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 high: 901 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 901 8: 900 bogomips: 54398
Type: l1tf
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0380
Device-2: NVIDIA GM107 [GeForce GTX 745] driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:1382 class-ID: 0300
Device-3: NVIDIA GM107 [GeForce GTX 745] driver: N/A alternate: nouveau
bus-ID: 04:00.0 chip-ID: 10de:1382 class-ID: 0300
Display: server: X.org 1.21.1.3 driver: loaded: N/A failed: nvidia
Message: No advanced graphics data found on this system.
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fbc
class-ID: 0403
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 10de:0fbc
class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-2-rt29-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: N/A class-ID: 0104
Local Storage: total: 931.52 GiB used: 72.86 GiB (7.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-1: / raw-size: 902.22 GiB size: 887.06 GiB (98.32%)
used: 72.86 GiB (8.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: partition size: 29.3 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 29.8 C pch: 50.5 C mobo: 27.8 C
Processes: 187 Uptime: 1h 7m wakeups: 19 Memory: 31.24 GiB
used: 932.4 MiB (2.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: 1786 pacman: 1734 lib: 456 flatpak: 5
snap: 47 Shell: Bash v: 5.1.16 running-in: sshd (SSH) inxi: 3.3.12
steky9
20 February 2022 07:47
6
[sudo] password for stevo:
> Removing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing libxnvctrl breaks dependency 'libxnvctrl' required by conky-lua-nv
Error: pacman failed!
Error: script failed!
omano
7
Yeah just try to force reinstall the driver
if it doesn’t work, remove it then try previous driver.
sudo mhwd -r pci video-nvidia
sudo mhwd -i pci video-nvidia-470xx
//EDIT:
You will need to remove conky-lua-nv
in order to be able to install drivers. You could reinstall it afterwards.
steky9
20 February 2022 07:55
8
:: ffmpeg optionally requires nvidia-utils: Nvidia NVDEC/NVENC support
:: gst-plugins-bad optionally requires nvidia-utils: nvcodec plugin
:: lib32-vulkan-icd-loader optionally requires lib32-vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires vulkan-driver: packaged vulkan driver
:: steam-manjaro optionally requires lib32-vulkan-driver: packaged vulkan driver (32bit)
:: vulkan-icd-loader optionally requires vulkan-driver: packaged vulkan driver
warning: dependency cycle detected:
warning: eglexternalplatform will be removed after its nvidia-utils dependency
Packages (8) egl-wayland-2:1.1.9+r3+g582b2d3-1 eglexternalplatform-1.1-2 lib32-nvidia-utils-510.47.03-1 libxnvctrl-510.47.03-1 linux510-nvidia-510.47.03-3 linux515-nvidia-510.47.03-4 linux54-nvidia-510.47.03-3 nvidia-utils-510.47.03-4
Total Removed Size: 690.40 MiB
:: Do you want to remove these packages? [Y/n]
removing linux54-nvidia...
removing linux515-nvidia...
removing linux510-nvidia...
removing lib32-nvidia-utils...
xorg configuration symlink valid...
removing nvidia-utils...
removing egl-wayland...
removing eglexternalplatform...
removing libxnvctrl...
(1/7) Reloading system manager configuration...
(2/7) Reloading device manager configuration...
(3/7) Arming ConditionNeedsUpdate...
(4/7) Updating module dependencies...
(5/7) Reloading system bus configuration...
(6/7) Updating the desktop file MIME type cache...
(7/7) Updating mlocate database
'/etc/X11/xorg.conf.d/90-mhwd.conf' symlink is invalid! Removing it...
> Successfully removed video-nvidia
> Installing video-nvidia...
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
core downloading...
extra downloading...
community downloading...
multilib downloading...
resolving dependencies...
warning: eglexternalplatform will be installed before its nvidia-utils dependency
Total Installed Size: 690.40 MiB
:: Retrieving packages...
nvidia-utils-510.47.03-4-x86_64 downloading...
linux515-nvidia-510.47.03-4-x86_64 downloading...
linux510-nvidia-510.47.03-3-x86_64 downloading...
linux54-nvidia-510.47.03-3-x86_64 downloading...
lib32-nvidia-utils-510.47.03-1-x86_64 downloading...
libxnvctrl-510.47.03-1-x86_64 downloading...
egl-wayland-2:1.1.9+r3+g582b2d3-1-x86_64 downloading...
eglexternalplatform-1.1-2-any downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
error: failed to commit transaction (conflicting files)
lib32-nvidia-utils: /usr/lib32/libEGL_nvidia.so.0 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLESv1_CM_nvidia.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLESv2_nvidia.so.2 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libGLX_nvidia.so.0 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libcuda.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvcuvid.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-encode.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-fbc.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ml.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-opticalflow.so.1 exists in filesystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ptxjitcompiler.so.1 exists in filesystem
Error: config 'video-nvidia' is not installed!
> Installing video-nvidia-470xx...
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-470xx/MHWDCONFIG
core downloading...
warning: eglexternalplatform will be installed before its nvidia-470xx-utils dependency
Packages (8) egl-wayland-2:1.1.9+r3+g582b2d3-1 eglexternalplatform-1.1-2 lib32-nvidia-470xx-utils-470.103.01-1 libxnvctrl-470xx-470.103.01-1 linux510-nvidia-470xx-470.103.01-4 linux515-nvidia-470xx-470.103.01-4 linux54-nvidia-470xx-470.103.01-4 nvidia-470xx-utils-470.103.01-1
Total Download Size: 322.21 MiB
Total Installed Size: 660.86 MiB
nvidia-470xx-utils-470.103.01-1-x86_64 downloading...
linux515-nvidia-470xx-470.103.01-4-x86_64 downloading...
lib32-nvidia-470xx-utils-470.103.01-1-x86_64 downloading...
linux510-nvidia-470xx-470.103.01-4-x86_64 downloading...
linux54-nvidia-470xx-470.103.01-4-x86_64 downloading...
libxnvctrl-470xx-470.103.01-1-x86_64 downloading...
checking keyring...
lib32-nvidia-470xx-utils: /usr/lib32/libEGL_nvidia.so.0 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libGLESv1_CM_nvidia.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libGLESv2_nvidia.so.2 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libGLX_nvidia.so.0 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libcuda.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvcuvid.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-encode.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-fbc.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-ifr.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-ml.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-opticalflow.so.1 exists in filesystem
lib32-nvidia-470xx-utils: /usr/lib32/libnvidia-ptxjitcompiler.so.1 exists in filesystem
omano
20 February 2022 07:57
9
Untracked files in the system, you used external driver installed manually now your system is a mess, am I guessing right?
steky9
20 February 2022 07:59
10
Not today at least. Who knows possibly months or years ago.
So wipe and reinstall would be best?
omano
20 February 2022 08:06
11
No you could overwrite the files, but I’m not sure of the command with mhwd. Simple solution would be to manually delete these files with sudo
after you uninstall the driver (which should be uninstalled). But at this point it is on you I can’t guarantee it is proper procedure, these files may be part of another package you installed that the system doesn’t “know”.
What I would do, but it is wrong, but I would still do it, for each file sudo rm bla/bla
sudo rm /usr/lib32/libEGL_nvidia.so.0
sudo rm /usr/lib32/libGLESv1_CM_nvidia.so.1
sudo rm /usr/lib32/libGLESv2_nvidia.so.2
sudo rm /usr/lib32/libGLX_nvidia.so.0
sudo rm /usr/lib32/libcuda.so.1
sudo rm /usr/lib32/libnvcuvid.so.1
sudo rm /usr/lib32/libnvidia-encode.so.1
sudo rm /usr/lib32/libnvidia-fbc.so.1
sudo rm /usr/lib32/libnvidia-ml.so.1
sudo rm /usr/lib32/libnvidia-opticalflow.so.1
sudo rm /usr/lib32/libnvidia-ptxjitcompiler.so.1
Remember this is not proper solution, you might break something, and there might be a better proper real solution.
steky9
20 February 2022 08:42
12
So I deleted those files, did the install, and it looks like once installed it went into a mkcpioinit. That eventually completed but with the following text
linux54-nvidia-470xx: install reason has been set to 'explicitly installed'
rmmod: ERROR: could not remove 'nouveau': No such file or directory
rmmod: ERROR: could not remove module nouveau: No such file or directory
rmmod: ERROR: could not remove 'ttm': Resource temporarily unavailable
rmmod: ERROR: could not remove module ttm: Resource temporarily unavailable
rmmod: ERROR: could not remove 'drm_kms_helper': Resource temporarily unavailable
rmmod: ERROR: could not remove module drm_kms_helper: Resource temporarily unavailable
rmmod: ERROR: could not remove 'drm': Resource temporarily unavailable
rmmod: ERROR: could not remove module drm: Resource temporarily unavailable
modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.15.19-2-rt29-MANJARO
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
modprobe: FATAL: Module nvidia-drm not found in directory /lib/modules/5.15.19-2-rt29-MANJARO
> Successfully installed video-nvidia-470xx
I then went for a reboot, but it doesn’t reboot fully and I can no longer get to a prompt via Ctrl-Alt-F2 and pinging from another device doesn’t work. Looks like its messed up beyond a level of time or effort I’m willing to spend on recovering it. I’d pretty much decided before I tried it that I was going to wipe it anyway since there looks to be a tonne of crud built up over the years, and there was nothing on it that I’m worried about losing.
Thanks for all the help. Really appreciate it despite how it ended.
Olli
20 February 2022 08:50
13
i had a similar problem in former times and there is a swiss-knife method that worked all times.
a) make sure that the linuxXXX-headers are installed that are needed for your XXX-kernel to do a build
b) download the driver from nvidia-homepage
c) load into console / terminal (if needed load into level 3 at boot)
d) start the setup.sh from the nvidia-downlaod (but make sure to do a chmod +x to the downloaded files)
e) let the setup override the whole mess you left in the past, accept everything of the setup with y (yes)
d) reboot
omano
20 February 2022 08:54
14
I don’t think removing the remaining Nvidia files cause the issue you had when reinstalling the driver. Anyway if you decided to reinstall then do it and never install something outside of Manjaro repositories without understanding everything as a general rule.
Also you can always access your files from Manjaro live USB (and even work on the system from live USB with the help of manjaro-chroot
, but I think you already decided to not continue working on it).
I will select your last post as solution unfortunately.
system
Closed
22 February 2022 22:54
15
