I have a running system, Manjaro KDE up-to-date. Now I would like to do some optimization.
I am wondering which proprietary drivers are best for my system. On my other machine, Manjaro XFCE I see a nvidia GUI in the startr menu, listing me some info. I would like to have this as well on this machine (KDE). Would you help me please?
What I did first was: I installed Nvidia drivers from their site manually. with a command bash NVIDIA-Linux-x86_64-390.141.run
worked. built kernel modules. made a modprobe entry, made an auto config of xorg:
Now the thing is. MHWD does seem to display this manually installed driver. (OK, might be logical).
Would you generally advice to install drivers manually or via mhwd?
Plus, with my graphics card (you can see it in the output), I always get confused whether to use nvidia or nvidia-390…
If transparency doesn’t work you need to enable the compositor. Often a part of the desktop environment but in case of window manager you need a compositor or a window manager which is also a compositor e.g. compiz.
Using config 'video-nvidia' for device: 0000:02:00.0 (0300:10de:11b4) Display controller nVidia Corporation GK104GL [Quadro K4200]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
:: Synchronisiere Paketdatenbanken...
core ist aktuell
extra ist aktuell
community ist aktuell
multilib ist aktuell
Löse Abhängigkeiten auf...
Suche nach in Konflikt stehenden Paketen...
Pakete (4) lib32-nvidia-utils-460.32.03-1 linux419-nvidia-460.32.03-3 linux59-nvidia-460.32.03-1 nvi
Gesamtgröße der installierten Pakete: 472,26 MiB
:: Installation fortsetzen? [J/n]
Prüfe Schlüsselring...
Prüfe Paketintegrität...
Lade Paket-Dateien...
Prüfe auf Dateikonflikte...
Fehler: Konnte den Vorgang nicht durchführen (In Konflikt stehende Dateien)
nvidia-utils: /usr/bin/nvidia-bug-report.sh existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-cuda-mps-control existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-cuda-mps-server existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-debugdump existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-modprobe existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-persistenced existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-settings existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-smi existiert im Dateisystem
nvidia-utils: /usr/bin/nvidia-xconfig existiert im Dateisystem
nvidia-utils: /usr/lib/libEGL_nvidia.so.0 existiert im Dateisystem
nvidia-utils: /usr/lib/libGLESv1_CM_nvidia.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libGLESv2_nvidia.so.2 existiert im Dateisystem
nvidia-utils: /usr/lib/libGLX_nvidia.so.0 existiert im Dateisystem
nvidia-utils: /usr/lib/libcuda.so existiert im Dateisystem
nvidia-utils: /usr/lib/libcuda.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvcuvid.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvcuvid.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-cfg.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-cfg.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-encode.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-encode.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-fbc.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-fbc.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ifr.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ifr.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ml.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ml.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so existiert im Dateisystem
nvidia-utils: /usr/lib/libnvidia-ptxjitcompiler.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/vdpau/libvdpau_nvidia.so.1 existiert im Dateisystem
nvidia-utils: /usr/lib/xorg/modules/drivers/nvidia_drv.so existiert im Dateisystem
nvidia-utils: /usr/share/glvnd/egl_vendor.d/10_nvidia.json existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-cuda-mps-control.1.gz existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-modprobe.1.gz existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-persistenced.1.gz existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-settings.1.gz existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-smi.1.gz existiert im Dateisystem
nvidia-utils: /usr/share/man/man1/nvidia-xconfig.1.gz existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libEGL_nvidia.so.0 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libGLESv1_CM_nvidia.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libGLESv2_nvidia.so.2 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libGLX_nvidia.so.0 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libcuda.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libcuda.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvcuvid.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvcuvid.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-encode.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-encode.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-fbc.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-fbc.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ifr.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ifr.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ml.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ml.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ptxjitcompiler.so existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/libnvidia-ptxjitcompiler.so.1 existiert im Dateisystem
lib32-nvidia-utils: /usr/lib32/vdpau/libvdpau_nvidia.so.1 existiert im Dateisystem
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
Error: pacman failed!
Error: script failed!
didnt work. Pacman refused to install those packages it seems. Maybe I am still fine with the *.run file from the nvidia homepage? Is there a difference?
What about a GUI File in the Start Menu, as I have it in the other XFCE system?
This is why you NEVER install Nvidia drivers from Nvidia, and ALWAYS rely on the package manager to install packages. Good luck cleaning your install from Nvidia drivers now.
