Ok, I’m stuck on an unsupported rt-kernel and there’s a conflict with nvidia drivers. I’ve tried plugging my monitor into motherboard hdmi and I get a blank screen. How do I get system to boot using motherboard hdmi? At least from there I can try and troubleshoot using different kernels.
Hi @bearthly,
You can always do troubleshooting from a chroot
environment:
How to chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/
dd
the ISO to a USB thumb drive. -
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the
chroot
encironment:
manjaro-chroot -a
- If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot
environment.
Be careful here, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
Please do not create duplicate topics.
