I have a Rtx2060 with three hdmi/dp monitors connected. My system shows my whole graphicscard as one playback device:
If I click on configure, i can select the correct output i want to use, in my case the first entry
Now the strange things: If my computer locks the screen for a while or was at sleep, the audio will be played through the monitor attached to ‘hdmi 3’ in the dropdown but ‘hdmi’ is selected.
To fix this i have to select ‘hdmi 3’ , and then ‘hdmi’ so my device gets reselected.
Having to do that multiple times a day is really annoying
What i have tried:
- using open source driver
this resolved the error but then the performance was really not there even on desktop
System information:
inxi
Kernel: 5.10.32-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
root=UUID=fa9a4af6-777a-4e52-8768-207cc178c510 rw rootflags=subvol=@ quiet
udev.log_priority=3
resume=/dev/disk/by-uuid/fa9a4af6-777a-4e52-8768-207cc178c510
resume_offset=2102528 nvidia-drm.modeset=1 nmi_watchdog=0 nowatchdog
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: B550M Steel Legend serial: <filter>
UEFI: American Megatrends v: P1.80 date: 12/01/2020
RAM: total: 15.56 GiB used: 5.49 GiB (35.3%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701021 cache:
L2: 3 MiB bogomips: 86240
Speed: 4150 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 4150 2: 4092 3: 4151 4: 2091 5: 4159 6: 2086 7: 4079 8: 2083 9: 4099
10: 4074 11: 4136 12: 2088
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1f08 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4.3:11 chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 8560x1440 s-dpi: 108 s-size: 2013x342mm (79.3x13.5")
s-diag: 2042mm (80.4")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-0 res: 3440x1440 hz: 75 dpi: 109 size: 800x335mm (31.5x13.2")
diag: 867mm (34.1")
Monitor-3: DP-2 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Realtek USB-C to 3.5mm-Headphone Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:7 chip-ID: 0bda:4995
class-ID: 0300 serial: <filter>
Device-4: Microdia Webcam Vitade AF type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-1ca7876678b8 state: down mac: <filter>
IF-ID-2: br-1ec52863ec7e state: down mac: <filter>
IF-ID-3: br-34c85e09d7d3 state: down mac: <filter>
IF-ID-4: br-70e5dcbc1f1f state: down mac: <filter>
IF-ID-5: br-9664a204375e state: down mac: <filter>
IF-ID-6: br-b7e7c344ce1f state: down mac: <filter>
IF-ID-7: br-ec5122f745d8 state: down mac: <filter>
IF-ID-8: docker0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-7.3:6 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 931.51 GiB used: 141.58 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-AG41TB
lanes: 4 rotation: SSD serial: <filter> rev: EGFM11.3 temp: 43.9 C
scheme: GPT
ID-1: / raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
used: 141.56 GiB (51.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: fa9a4af6-777a-4e52-8768-207cc178c510
ID-2: /.snapshots raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-3: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 25.4 MiB (26.8%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: E470-B875
ID-4: /btrfs raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-5: /home raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-6: /home/.snapshots raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
ID-7: /home/<filter>/Nextcloud raw-size: 273.44 GiB
size: 273.44 GiB (100.00%) used: 141.56 GiB (51.8%) fs: btrfs
dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
ID-8: /var raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: bfde55a7-bedf-486b-9eae-20a35d5b3f1f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: vfat label: N/A
uuid: 7860-556E
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 637.91 GiB fs: ntfs label: N/A
uuid: 8CDC712ADC711026
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.1:4 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Device-2: 1-2.3:7 info: Realtek USB-C to 3.5mm-Headphone Adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0bda:4995 class-ID: 0300
serial: <filter>
Hub-3: 1-2.4:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 500mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.4.1:9 info: Holtek USB Gaming Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:a259 class-ID: 0300
Device-2: 1-2.4.2:10 info: Apple Aluminium Keyboard (ISO)
type: Keyboard,Mouse driver: apple,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 05ac:0250 class-ID: 0301
Device-3: 1-2.4.3:11 info: Microdia Webcam Vitade AF type: Video,Audio
power: 500mA chip-ID: 0c45:6366 class-ID: 0102 serial: <filter>
Hub-4: 1-2.4.4:12 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Hub-5: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-7.3:6 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-2: 1-8:5 info: ASRock LED Controller type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
Hub-6: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 2-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Hub-8: 2-2.4:3 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
Hub-9: 2-2.4.4:4 info: Genesys Logic USB3.0 Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Device-1: 2-2.4.4.4:5 info: Norelsys NS1081 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 2537:1081 class-ID: 0806 serial: <filter>
Hub-10: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-11: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-12: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-13: 5-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Hub-14: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
Hub-15: 6-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 57.6 C mobo: 42.0 C gpu: nvidia temp: 53 C
Fan Speeds (RPM): fan-1: 0 fan-2: 542 fan-3: 1539 fan-4: 379 fan-5: 0
fan-6: 0 fan-7: 306 gpu: nvidia fan: 0%
Processes: 419 Uptime: 40m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1610 pacman: 1600 lib: 350 flatpak: 10
Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.04
xrandr
Screen 0: minimum 8 x 8, current 8560 x 1440, maximum 32767 x 32767
HDMI-0 connected 2560x1440+6000+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95 + 74.97*
1920x1080 74.97 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x1440 59.91
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DP-0 connected primary 3440x1440+2560+0 (normal left inverted right x axis y axis) 800mm x 335mm
3440x1440 75.05*+ 143.92 120.00 99.98
2560x1440 120.00 59.95
2048x1152 60.00
1920x1200 59.88
1920x1080 119.98 119.88 60.00 59.94 50.00
1720x1440 59.98
1680x1050 59.95
1600x1200 60.00
1600x900 60.00
1280x800 59.81
1280x720 59.94
720x576 50.00
720x480 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
1680x1050 59.95
1440x900 59.89
1280x1440 59.91
1280x960 60.00
720x576 50.00
720x480 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
I’m happy for any help
