I just install my graphic card but cant see in even mhwd -li
and inxi -v2
commands. Nvidia Settings is not working properly. I couldnt find LTS of Kernel. Prime-run is unknown command too, and i tried to install some packages for Prime-run which didnt work with conflits so is it ok ? I have enabled settings I/O APIC and PAE/NX, VT-X/AMD-X in Virtual Box it may be the problem ? Like 3D ?
post formatted output from:
mhwd -l && mhwd -li
inxi -Fazy
mhwd -l && mhwd -li:
0000:00:02.0 (0300:15ad:0405) Display controller VMware, Inc.:
NAME VERSION FREEDRIVER TYPE
video-virtualmachine 2021.07.26 true PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
inxi - Fazy:
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b759388f-917d-4d8b-b470-2b4b832f6e58 rw nouveau.modeset=o quiet
resume=UUID=3cf62b8f-e356-4828-882b-f6952bca17e8 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Virtualbox System: innotek GmbH product: VirtualBox v: 1.2
serial: <superuser required> Chassis: Oracle Corporation type: 1
Mobo: Oracle model: VirtualBox v: 1.2 serial: <superuser required>
BIOS: innotek GmbH v: VirtualBox date: 12/01/2006
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: N/A
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 36 MiB
desc: 4x9 MiB
Speed (MHz): avg: 2904 min/max: N/A cores: 1: 2904 2: 2904 3: 2904 4: 2904
bogomips: 23240
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
Type: mmio_stale_data
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Type: srbds status: Unknown: Dependent on hypervisor status
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.19.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8
bus-ID: 00:02.0 chip-ID: 15ad:0405 class-ID: 0300
Display: x11 server: `X.Org` v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: vmware unloaded: modesetting alternate: fbdev,vesa gpu: vmwgfx
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: Virtual-1 mapped: Virtual1 res: 1920x1080 hz: 60 size: N/A
modes: max: 1920x1080 min: 640x480
OpenGL: renderer: llvmpipe (LLVM 14.0.6 256 bits) v: 4.5 Mesa 22.1.3
direct render: Yes
Device-1: Intel 82801AA AC97 Audio vendor: Dell driver: snd_intel8x0
v: kernel bus-ID: 00:05.0 chip-ID: 8086:2415 class-ID: 0401
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel 82540EM Gigabit Ethernet driver: e1000 v: kernel port: d020
bus-ID: 00:03.0 chip-ID: 8086:100e class-ID: 0200
IF: enp0s3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
driver: piix4_smbus v: N/A modules: i2c_piix4 port: N/A bus-ID: 00:07.0
chip-ID: 8086:7113 class-ID: 0680
Device-3: Ralink RT2870/RT3070 Wireless Adapter type: USB
driver: rt2800usb bus-ID: 1-2:3 chip-ID: 148f:3070 class-ID: 0000
serial: <filter>
IF: wlp0s6u2 state: down mac: <filter>
Local Storage: total: 33.12 GiB used: 11.13 GiB (33.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: VirtualBox model: VBOX HARDDISK
size: 33.12 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1.0 scheme: MBR
ID-1: / raw-size: 29.8 GiB size: 29.17 GiB (97.87%) used: 11.13 GiB (38.2%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 3.31 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
Message: No sensor data found. Is lm-sensors configured?
Processes: 197 Uptime: 1h 9m wakeups: 3907 Memory: 6.28 GiB
used: 2.02 GiB (32.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1193
lib: 318 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
edit your post … click this icon in editor: </> and post the outputs there…
Got it
i dont use virtual box and dont know nothing about it, but if you google it, the vb cant detect the nvidia and theres nothing you can do about it …
Allright, i googled it about I/O APIC and PAE/NX and VT-X/AMD-X just for knowledge its noting about that. But also i have a problem of Prime-run
command unknown in my console is about the same issue ? But you are saying anyway the system would not recognize because of Virtual Box, what about VMware ? Or should i use second boot ?
Hello,
Your host (the system installed on real hardware) must have two GPUs and in order to use the second one as PCI passthrough via OVMF - ArchWiki to a QEMU virtual macine. VirtualBOX and VMWare Workstation do not support this. The only product from VMWare that supports this is the vSphere Bitfusion server.
Yes, native install is the best to get access to the real hardware, but in that case you can’t use them simultaneously as with QUEMU …
