Nvidia Graphics Card Not Enabled
Hello.
I have Manjaro dual booted on a system with Windows. The graphics card works with Windows, but on Manjaro, while they are recognized, they aren’t utilized. Here’s some system info below:
[user ~]$ nvidia-smi
Tue Aug  2 21:19:41 2022
| NVIDIA-SMI 515.57       Driver Version: 515.57       CUDA Version: 11.7     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:06:00.0 Off |                  N/A |
| N/A   44C    P8    N/A /  N/A |      0MiB /  2048MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
[user ~]$ mhwd -li
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
[user ~]$ inxi -GC
  Info: quad core model: Intel Core i5-1035G1 bits: 64 type: MT MCP cache:
    L2: 2 MiB
  Speed (MHz): avg: 954 min/max: 400/3600 cores: 1: 1001 2: 987 3: 870
    4: 964 5: 965 6: 956 7: 952 8: 940
  Device-1: Intel Iris Plus Graphics G1 driver: i915 v: kernel
  Device-2: NVIDIA GM108M [GeForce MX130] driver: nvidia v: 515.57
  Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
    loaded: modesetting gpu: i915 resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.1.4
And general system info below:
[user ~]$ inxi -Fazy
  Kernel: 5.18.14-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
    root=UUID=799acea8-83e9-4271-880a-119665f23be5 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 info: kdocker wm: kwin_x11
    vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP Pavilion Laptop 15-cs3xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 86E2 v: 95.32 serial: <superuser required> UEFI: Insyde
    v: F.06 date: 04/08/2020
  ID-1: BAT0 charge: 36.8 Wh (100.0%) condition: 36.8/36.8 Wh (100.0%)
    volts: 12.8 min: 11.4 model: HP Primary type: Li-ion serial: N/A
    status: full
  Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 built: 2019-21 process: Intel 10nm family: 6
    model-id: 0x7E (126) stepping: 5 microcode: 0xB0
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 888 high: 980 min/max: 400/3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 887 2: 980 3: 839 4: 813
    5: 866 6: 902 7: 967 8: 856 bogomips: 19048
  Type: retbleed mitigation: Enhanced IBRS
  Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
    class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
    driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-07) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s bus-ID: 06:00.0 chip-ID: 10de:174d
    class-ID: 0302
    bus-ID: 1-3:3 chip-ID: 04f2:b627 class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Najing CEC Panda 0x003c built: 2018 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
    direct render: Yes
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
    bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.14-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: no
  Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 10:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: docker0 state: down mac: <filter>
    bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 1 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 7060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 931.51 GiB used: 540.91 GiB (58.1%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
  ID-1: / raw-size: 288.06 GiB size: 282.47 GiB (98.06%) used: 201.41 GiB
    (71.3%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.3 MiB
    (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: partition size: 4.91 GiB used: 322.7 MiB (6.4%)
    priority: -2 dev: /dev/sda7 maj-min: 8:7
  System Temperatures: cpu: 45.0 C mobo: N/A
  Processes: 294 Uptime: 2h 59m wakeups: 1 Memory: 15.42 GiB used: 6.24 GiB
  (40.5%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.1.0 clang: 14.0.6 Packages: 2316 pacman: 2259 lib: 541 flatpak: 31
  snap: 26 Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
I would like to enable it please.
Thank you
i would recommend to change to X11 and do not use wayland. install plasma-wayland-session and change to X11 at login (bottom-left-corner).
The X11 is my default actually. I installed plasma-wayland-session as you said and restarted the computer, but the output is the same as above. Should I restart and try with other options in the bottom-left list?
That means, each time you want to use an application via the dGPU (Nvidia GPU) then you have to use
prime-run <application>
Otherwise look into Optimus-Manager …
