on my asus tuf a15 laptop, with amd ryzen and nvidia gpu, using Manjaro KDE, when i set Nvidia to use vfio-pci drivers through modprobe + mkinitcpio, or with using supergfxctl tool (same outcome), i get every second messages in dmesg like this:
[ +1.242258] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[ +0.000005] NVRM: The NVIDIA probe routine was not called for 1 device(s).
[ +0.000574] NVRM: This can occur when a driver such as:
NVRM: nouveau, rivafb, nvidiafb or rivatv
NVRM: was loaded and obtained ownership of the NVIDIA device(s).
[ +0.000001] NVRM: Try unloading the conflicting kernel module (and/or
NVRM: reconfigure your kernel without the conflicting
NVRM: driver(s)), then try loading the NVIDIA kernel module
NVRM: again.
[ +0.000001] NVRM: No NVIDIA devices probed.
[ +0.000155] nvidia-nvlink: Unregistered Nvlink Core, major device number 237
also i notice in ksysguard when i filter processes by name “modprobe”, modprobe and nvidia-modprobe processes are created and killed every second, which rises my cpu temps by 20 degrees celsius for nothing. why would this be happening? i tried just for test on fresh installed endeavourOs to recreate same situation, this message happens only one time when booting and thats it …? hopefully there is some solution
