Nvidia GPU usage is 0%
Hi there, my process units are like this:
neofetch
Screenshot from 2021-09-16 01-12-12
so then I used a program and the name is glmark2 what its doing is Stress-testing GPU performance so my problem is, it tested the wrong GPU, the AMD one, or better say APU (i guess) so there is the result:
gdmark2
so it made me think my Nvidia GPU is doing nothing at pc and I monitor GPU activity:
nvtop
as you see my Nvidia GPU usage is 0% while I was running a full HD movie.
am i right? if yes, what can I do, or looking for what should I search?
my laptop full information is:
  Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=02990d34-9c1c-4722-9b78-e89e8e98469f rw quiet
  resume=UUID=9c6ed132-9401-47c9-bba2-9d4dfa304e1c udev.log_priority=3
  Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
  Type: Laptop System: ASUSTeK product: ZenBook UX434IQ_UM433IQ v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: UX434IQ v: 1.0 serial: <filter>
  UEFI: American Megatrends v: UX434IQ_UM433IQ.302 date: 07/10/2020
  ID-1: BAT0 charge: 24.8 Wh (50.6%) condition: 49.0/50.0 Wh (97.9%)
  volts: 11.9 min: 11.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Discharging cycles: 49
  RAM: total: 15.06 GiB used: 2.55 GiB (17.0%)
  Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 4 MiB bogomips: 31948
  Speed: 1397 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
  v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
  xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: disabled, RSB filling
  Device-1: NVIDIA GP107M [GeForce MX350] vendor: ASUSTeK driver: nvidia
  v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1c96 class-ID: 0302
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
  bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
  bus-ID: 3-2:2 chip-ID: 13d3:56cb class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.13 compositor: gnome-shell driver:
  loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
  alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.13-1-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.1 direct render: Yes
  Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1
  chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.34 running: no
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
  bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 11.1 GiB (1.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
  size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: EXA7301Q temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 937 GiB size: 921.22 GiB (98.32%) used: 11.1 GiB (1.2%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 02990d34-9c1c-4722-9b78-e89e8e98469f
  label: NO_LABEL uuid: D837-37D9
  ID-1: swap-1 type: partition size: 16.56 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
  uuid: 9c6ed132-9401-47c9-bba2-9d4dfa304e1c
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-3:2 info: SiGma Micro Usb Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
  power: 98mA chip-ID: 1c4f:0048 class-ID: 0301
  Device-2: 1-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-2:2 info: IMC Networks USB2.0 HD IR UVC WebCam type: Video
  driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 3-3:3 info: Realtek RTS5129 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
  class-ID: ff00 serial: <filter>
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 45.5 C mobo: 40.0 C gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): cpu: 2500
  Processes: 295 Uptime: 1h 37m wakeups: 3756 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1040
  lib: 291 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Please post your system info as outlined here:
thank you, i edited the post and add all of my pc information.
No, you didn’t.
EDIT: Thanks for editing and posting your full system info.
okay i just thought nobody will care about the full version so I summarized it.
I’m kind of newbie, sorry
See Configure Graphics Cards - Manjaro
Does that laptop gpu of yours support PRIME offloading?
Did you try prime-run glmark2 ?
The GL_RENDERER string will show which card is being used. How to select which card can be read from the link @Yochanan gave.
for the PRIME option, you should use open source drivers, but I’m not.
somehow it doesn’t work and shows just a black screen after the first reboot.
No no no, PRIME is for proprietary drivers, not open source. But if it doesn’t work, well I don’t know this MX line of GPUs so I don’t know for sure if they should support prime offloading or not. I’m only familiar with GTX and RTX, pretty sure Quadro are also supposed to support it.
