Nvidia GPU fan turning on and off every 3 seconds
Just installed Manjaro. Didn’t have an issue with the fan under another linux distro. When I tried Manjaro on a thumbdrive, I first noticed the revving up, but thought it was because of using it on a thumbdrive. After installation, it is still revving up, turning on and off, every 3 seconds or so.
My GPU is Nvidia GeForce 750.
I searched on Perplexity, and it came up with this:
The fan on your NVIDIA GeForce GTX 750 spinning up and down every few seconds in Manjaro is most likely due to the GPU’s “zero fan mode” combined with how your current system and driver control the fan curve and thermal thresholds. Here’s what’s happening:
** Zero Fan Mode: Many modern GPUs, including the GTX 750, turn their fans off completely when temperatures are low (typically under 50–55°C). When idle or under light load, if the temperature crosses this threshold by even a degree or two, the fan spins up to cool it, then quickly turns back off as temps drop. This causes the fans to cycle on and off repeatedly if the temperature is hovering around that threshold, which is especially common in cases with good airflow or cooler ambient temperatures.*
** Manjaro Driver Behavior: Different Linux distributions and NVIDIA driver versions handle fan curves and zero fan mode slightly differently. It’s possible that Manjaro’s driver is more aggressive, or the fan curve/thermal threshold is set right at your idle temperature, causing frequent fan toggling, while the other distro either did not engage this feature or had a slightly different threshold or fan control.*
** Custom Fan Curve: You can solve this with a custom fan curve, disabling zero fan mode, or setting the minimum fan speed to a low constant value so the fans don’t cycle on and off – this way, they hum quietly all the time instead of ramping up and down.*
## What You Can Do
** Set a Fan Curve: Use NVIDIA X Server Settings, “Coolbits”, or tools like GreenWithEnvy to set a custom fan profile, starting the fan at a low RPM even at idle.*
** Disable Zero RPM: Set fans to always run at a low speed (e.g. 10–20%), which prevents the start-stop behavior.*
** Monitor Temps: Ensure your case is clean and airflow is good; if temps are unusually high, check for dust or poor thermal paste.*
** Driver/Kernel Choice: Sometimes newer or different NVIDIA drivers in Manjaro respond differently to hardware – if your problem arose after a driver update, consider trying an older driver.*
This issue isn’t a sign of hardware failure but rather of how your OS and driver are handling the fan profile. Adjusting your fan control settings should resolve it.
I tried using Nvidia X Server Settings by adding Coolbits, and GreenWithEnvy to make a custom fan profile, but it didn’t seem to help, just varied the timing of the surge a little. In Nvidia Settings, under Thermal Settings, I tried clicking on Enable GPU Fan Settings to maybe set a constant fan speed, but the error came up: Failed to enable GPU Fan Settings.
I’m not sure I have the Coolbits running correctly or at all. Found this:
Enable Fan Control with Coolbits
You must enable NVIDIA’s “Coolbits” in your Xorg configuration:
  • Edit (or create) /etc/X11/mhwd.d/nvidia.conf or /etc/X11/xorg.conf.d/20-nvidia.conf, under the Section "Device" block.
  • Add:
text
Option "Coolbits" "12"
(or "8" for only fan control; "12" enables both overclocking and fan control).
Example:
  • text
Section "Device"
    Identifier "Device0"
    Driver "nvidia"
EndSection
  • Save and reboot to enable Coolbits.
I’ve also tried using 8, for fan only, and 4, which I read elsewhere. Nothing worked.
Any help would be appreciated.
Thanks!
Welcome to the Manjaro community @kah5683
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
# inxi -zv8
  Kernel: 6.12.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    root=UUID=9f0a320c-8514-4546-a10e-fae5295b8129 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Desktop Mobo: ASUSTeK model: P8Z68-V PRO GEN3 v: Rev 1.xx
    serial: <filter> uuid: 1f006dc0-00c6-1b00-6454-c8600005dbab
    UEFI: American Megatrends v: 0402 date: 11/16/2011
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  System RAM: total: 16 GiB available: 15.59 GiB used: 2.88 GiB (18.5%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: DIMM0 type: no module installed
  Device-2: DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMZ16GX3M2A1600C10 serial: N/A
  Device-3: DIMM2 type: no module installed
  Device-4: DIMM3 type: DDR3 detail: synchronous size: 8 GiB
  Slot: 1 type: PCIe status: in use length: short volts: 3.3 bus-ID: 00:01.0
    children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1 class-ID: 0403
    type: audio
  Slot: 2 type: PCIe status: in use length: short volts: 3.3 bus-ID: 00:1c.3
    children: 1: 05:00.0 class-ID: 0106 type: mass-storage
  Slot: 3 type: PCIe status: in use length: short volts: 3.3 bus-ID: 00:1c.4
    children: 1: 06:00.0 class-ID: 0c03 type: serialbus
  Slot: 4 type: PCI status: in use length: short volts: 3.3 bus-ID: 00:1c.6
    children: 1: 07:00.0 class-ID: 0604 type: bridge children: 1: 08:02.0
    class-ID: 0c00 type: serialbus
  Info: model: Intel Core i5-2500K socket: LGA1155 bits: 64 type: MCP
    arch: Sandy Bridge gen: core 2 level: v2 built: 2010-12 process: Intel 32nm
    family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1605 min/max: 1600/3700 base/boost: 3300/3800 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.0 V ext-clock: 100 MHz
    cores: 1: 1605 2: 1605 3: 1605 4: 1605 bogomips: 26495
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GM107 [GeForce GTX 750] vendor: ASUSTeK driver: nvidia
    v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 2 speed: 5 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DVI-D-1,VGA-1 bus-ID: 01:00.0
    chip-ID: 10de:1381 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
    s-diag: 554mm (21.82") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: LG (GoldStar) FULL HD built: 2016
    res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green:
    x: 0.306 y: 0.631 blue: x: 0.149 y: 0.047 white: x: 0.314 y: 0.329
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1400x1050, 1600x900, 1280x1024, 1440x900,
    1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 750/PCIe/SSE2
    memory: 1000 MiB
  API: Vulkan v: 1.4.321 layers: 2 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 750 driver: nvidia v: 575.64.05
    device-ID: 10de:1381 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings,
    nvidia-smi wl: wayland-info x11: xdpyinfo,xprop
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
  API: ALSA v: k6.12.41-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
    driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503
    class-ID: 0200
  Device-2: Realtek RTL8192CE PCIe Wireless Network Adapter vendor: ASUSTeK
    driver: rtl8192ce v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 04:00.0 chip-ID: 10ec:8178 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Local Storage: total: 10.97 TiB used: 5.99 TiB (54.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: Pyro size: 55.9 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: BBF0 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWE160 size: 5.46 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: FS2A scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA200
    tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: MBR
  Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 B rev: AL0S
    dev-links: cdrom
  Optical-2: /dev/sr1 vendor: ATAPI model: iHAS124 B rev: AL0S
    dev-links: N/A
  ID-1: / raw-size: 107.42 GiB size: 105.18 GiB (97.91%)
    used: 17.35 GiB (16.5%) fs: ext4 block-size: 4096 B dev: /dev/sdc3
    maj-min: 8:35 label: N/A uuid: 9f0a320c-8514-4546-a10e-fae5295b8129
    used: 320 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdc2 maj-min: 8:34
    label: N/A uuid: FCF7-D929
  ID-3: /data raw-size: 3.22 TiB size: 3.17 TiB (98.40%)
    used: 504.18 GiB (15.5%) fs: ext4 block-size: 4096 B dev: /dev/sdc6
    maj-min: 8:38 label: Data uuid: 8e762f69-6dfa-4c97-94d5-a98d24ec3a9e
  ID-4: /home raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
    used: 11.53 GiB (6.0%) fs: ext4 block-size: 4096 B dev: /dev/sdc5
    maj-min: 8:37 label: Home uuid: b7b1bd07-595e-4f14-969e-a3e9d634a1de
  ID-5: /oldbackup raw-size: 1.82 TiB size: 1.79 TiB (98.42%)
    used: 1.69 TiB (94.2%) fs: ext4 block-size: 4096 B dev: /dev/sdd1
    maj-min: 8:49 label: OldBackup uuid: e253cfe3-196c-4210-a26e-13561fb89ddc
  ID-6: /oldhome raw-size: 5.45 TiB size: 5.41 TiB (99.21%)
    used: 3.76 TiB (69.6%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
    maj-min: 8:18 label: OldHome uuid: 21822c8a-3d49-4ba2-9483-1dd46da15512
  ID-7: /ssd55 raw-size: 55.9 GiB size: 54.72 GiB (97.89%)
    used: 2 MiB (0.0%) fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
    label: ssd55 uuid: 320a6859-248d-4d62-a270-b0d7ffa9d6d6
  ID-8: /timeshift raw-size: 117.19 GiB size: 114.79 GiB (97.95%)
    used: 20.07 GiB (17.5%) fs: ext4 block-size: 4096 B dev: /dev/sdc7
    maj-min: 8:39 label: N/A uuid: 8646934b-abb1-4511-b0d8-2626ba96e201
  ID-1: /dev/sdb1 maj-min: 8:17 size: 9.77 GiB fs: swap label: N/A
    uuid: 1cdf1cda-0184-4754-bdcb-10448240e157
  ID-2: /dev/sdc1 maj-min: 8:33 size: 8 MiB fs: N/A label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 3-1.1:3 info: Holtek Keyboard LKS02 type: keyboard,HID
    chip-ID: 04d9:1702 class-ID: 0300
  Device-2: 3-1.5:4 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-7: 4-1.3:3 info: Manufacturer Hub ports: 4 rev: 2.0
    chip-ID: 0a05:0001 class-ID: 0900
  Device-1: 4-1.4:4 info: Alcor Micro AU6375 4-LUN card reader
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 058f:6377 class-ID: 0806 serial: <filter>
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-9: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 30 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 69%
  Packages: 1352 pm: pacman pkgs: 1346 libs: 359 tools: pamac pm: flatpak
    pkgs: 6
    1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    5: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    10: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    12: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    13: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    15: https://mirrors2.manjaro.org/stable/$repo/$arch
    16: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    19: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    20: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    23: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    24: https://manjaro.kurdy.org/stable/$repo/$arch
    25: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    27: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    29: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    30: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    32: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    33: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    34: https://mirror.23m.com/manjaro/stable/$repo/$arch
    35: https://mirror.init7.net/manjaro/stable/$repo/$arch
    36: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    37: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    38: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    39: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    40: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    41: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    43: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    44: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    45: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    46: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    47: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    48: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    49: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    50: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    51: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    52: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    53: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    54: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    55: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    56: https://manjaro.ynh.ovh/stable/$repo/$arch
    57: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    58: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    59: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    60: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    61: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    62: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    63: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    64: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 246
  1: cpu: 8.2% command: firefox pid: 1652 mem: 652.4 MiB (4.0%)
  2: cpu: 5.3% command: /newerversion started-by: dropbox pid: 1287
    mem: 504.8 MiB (3.1%)
  3: cpu: 3.3% command: konsole pid: 2585 mem: 133.2 MiB (0.8%)
  4: cpu: 2.8% command: firefox pid: 1978 mem: 279.1 MiB (1.7%)
  5: cpu: 2.4% command: Xorg pid: 689 mem: 75.6 MiB (0.4%)
  Memory top: 5 of 246
  1: mem: 652.4 MiB (4.0%) command: firefox pid: 1652 cpu: 8.2%
  2: mem: 515.3 MiB (3.2%) command: firefox pid: 2047 cpu: 2.4%
  3: mem: 504.8 MiB (3.1%) command: /newerversion started-by: dropbox
    pid: 1287 cpu: 5.3%
  4: mem: 396.9 MiB (2.4%) command: plasmashell pid: 802 cpu: 0.8%
  5: mem: 333.1 MiB (2.0%) command: firefox pid: 1804 cpu: 1.8%
  Processes: 246 Power: uptime: 12m states: freeze,standby,mem,disk
    suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.21 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Bash (su) v: 5.3.3 running-in: konsole
    inxi: 3.3.38
Tried going to 6.6 kernel, and that didn’t help. Will keep on trying…
Did you run sudo nvidia-settings? To enable fan settings you need to do so.
I’ve had a few different nvidia cards over the years and never once needed to manually intervene with the fan settings. Makes me wonder if something else might not be right.
Just some general thoughts. If you tried something and it didn’t work it is best to completely revert again to avoid getting some interference from some of these leftover trials.
We should also keep in mind that LLMs are only text generators. They can’t reason or think. If the root cause of the problem would be a Zero fan mode you could first verify whether your GPU temperature is really hovering on a threshold.
Rather I would poke around some more. For instance you could try to run a Wayland session instead of X11. Or even boot into TTY - i mean runlevel 3 or target whatever it is called for systemd now. So if no display server is running, is the gpu fan still doing the same thing?
I’d start with a good clean-out of all fans (GPU but also PSU and CPU) using a hoover nozzle and a clean paint brush.
Yes, ran sudo nvidia-settings. Adjusted fan speed, but didn’t solve issue.
Wayland and TTY - I’m new here so not familiar with yet. You asked if no display server is running is gpu fan still doing the same thing…when I shut down the computer, as soon as Manjaro is off, and before the computer fully shuts down, the surging of the fan stops. Same when boot up. Fine until Manjaro kicks in.
I did blow out the computer a couple days ago, and still doing the same thing.
Dose this cause you any problems regarding performance? I ask this because mine dose the same thing and i have never had any performance issues regarding preformance
I don’t game. I occasionally use Handbrake and Avidemux. I haven’t seen a difference in any performance, other than the surging noise that is annoying.
Well i assumed you would be familiar with Linux. If this shouldn’t be the case you can ignore what i wrote since it was based on a wrong assumption. If you are currently looking for a Linux distro (you mentioned there wasn’t an issue with the fan under another distro) you could have a look at Aragon’s article
Or in short, if there is an important device on the system with shaky driver support (in your case it is the old Nvidia gpu - Nvidia doesn’t support it under Linux) then once you found a working driver-kernel combo (drivers are somehow attached to the Linux kernel) it’s a good idea to just stick to this. However, rolling releases by their very nature change frequently. You can find a similar consideration also for Tumbleweed
Due to the Linux kernel being updated very frequently, users who rely on 3rd party kernel driver modules including graphic drivers should not use the Tumbleweed distribution unless they are familiar with updating these drivers from source on their own …
but generalizing the thought a bit it would apply for any rolling release i think.
Oh I see, another question, dose it do the same on other operating systems or only manjaro?
Does not seem to affect performance
I’m trying to boot up with an with the old distro, but the old distro was wiped putting on Manjaro. The most up-to-date iso of the old distro boots up to a black screen. Still trying other options…
trying to figure that out. On my old distro, there was not an issue, but I overwrote that coming to Manjaro, so I can’t check what kernel and driver I was using. I’m going to try some others to check if something else works.
For a ten years old computer there is no need for the most up-to-date system software. You can still install the latest versions of application software via Flatpak. That is, it’s fine to install Ubuntu or Kubuntu (if you prefer KDE) 24.04 LTS and use flatpaks on top of it when needed. It may even be better if the old system software works with the computer, because a fix point LTS release guarantees the system won’t be changed. There will only be security patches or further bug fixes during the support lifespan.
I wound up buying another video card, an Radeon RX580 8gb. Worked out of the box with no surging. Thanks to everyone for the answers.
