Hi there,
I use to be able to install the 470.xx driver and the website below confirms I am running a Kepler card as per this Arch site NVIDIA - ArchWiki and also What's a legacy driver? | NVIDIA
mhwd detects my card wrong as needing 390.xx drivers instead of 470.xx
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-390xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-390xx-utils dependency
Packages (7) egl-wayland-2:1.1.12-1 eglexternalplatform-1.1-2 lib32-nvidia-390xx-utils-390.157-4 libxnvctrl-390xx-390.157-4 linux65-nvidia-390xx-390.157-3 nvidia-390xx-settings-390.157-4 nvidia-390xx-utils-390.157-8
Same with the GUI settings.
core downloading...
If I install with yay nvidia-dkms I get a blank-screen at reboot.
I definitely ran on 470.xx before I decided to reinstall and use another distribution for a while.
Would appreciate any help in this regard, thanks
lspci output:
01:00.0 VGA compatible controller: NVIDIA Corporation GK104M [GeForce GTX 670MX] (rev a1) (prog-if 00 [VGA contro
ller])
Subsystem: ASUSTeK Computer Inc. GK104M [GeForce GTX 670MX]
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at f4000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Kernel driver in use: nouveau
Kernel modules: nouveau
inxi:
Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.5-x86_64
root=UUID=f3ebd7dd-1a4a-4017-a8d5-150a85f2e60b rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=140b4f0f-91a6-4f16-a031-17c59fb9fa9c udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: G75VX v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G75VX v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G75VX.206 date: 02/27/2013
ID-1: BAT0 charge: 35.5 Wh (88.3%) condition: 40.2/77.0 Wh (52.3%)
volts: 14.8 min: 14.8 model: ASUSTek G75--52 type: Li-ion serial: N/A
status: charging cycles: 769
System RAM: total: 16 GiB available: 15.57 GiB used: 2.55 GiB (16.4%)
Info: model: Intel Core i7-3630QM bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1349 high: 2200 min/max: 1200/3400 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1197 3: 2200
4: 1400 5: 1200 6: 1200 7: 1200 8: 1200 bogomips: 38334
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GK104M [GeForce GTX 670MX] vendor: ASUSTeK driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: VGA-1,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:11a1
class-ID: 0300 temp: 46.0 C
Device-2: Sunplus Innovation ASUS Webcam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.3:4
chip-ID: 1bcf:2885 class-ID: 0e02
Device-3: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.6:5
chip-ID: 045e:075d class-ID: 0102
Display: x11 server: X.org v: 1.21.1.8 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: VGA-1 model: Samsung SA300/SA350 serial: <filter> built: 2011
res: 1920x1080 dpi: 96 gamma: 1.2 size: 510x287mm (20.08x11.3")
diag: 585mm (23") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: Seiko Epson 0x5044 built: 2010 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: max: 1920x1080 min: 800x600
API: OpenGL v: 4.3 Mesa 23.1.7-1 renderer: NVE4 direct-render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: AzureWave
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 168c:0032 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1083 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter driver: btusb
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:3
chip-ID: 13d3:3362 class-ID: e001 serial: <filter>
Local Storage: total: 8.15 TiB used: 642.99 GiB (7.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Corsair model: Force GS
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 5.07 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Force GS
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ04UBB400
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400 serial: <filter>
fw-rev: 5438 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MQ04UBB400
Optical-1: /dev/sr0 vendor: MATSHITA model: BD-MLT UJ260 rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 429.7 GiB size: 429.7 GiB (100.00%) used: 7.49 GiB (1.7%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: f3ebd7dd-1a4a-4017-a8d5-150a85f2e60b
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 7E20-A7F6
ID-3: /home raw-size: 429.7 GiB size: 429.7 GiB (100.00%)
used: 7.49 GiB (1.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: N/A
ID-4: /run/media/dirkdp/Ext_D1 raw-size: 3.64 TiB size: 3.58 TiB (98.40%)
used: 635.49 GiB (17.3%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: Ext_D1
uuid: 36f2f58a-e298-41db-9f69-01f0f52f8c2e
ID-5: /var/cache raw-size: 429.7 GiB size: 429.7 GiB (100.00%)
ID-6: /var/log raw-size: 429.7 GiB size: 429.7 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: 140b4f0f-91a6-4f16-a031-17c59fb9fa9c
ID-1: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: N/A
uuid: 5A82-8E99
ID-2: /dev/sdb2 maj-min: 8:18 size: 446.84 GiB fs: btrfs label: N/A
uuid: eee1427b-2f31-4c29-ae45-8c11f5ff5afe
ID-3: /dev/sdc1 maj-min: 8:33 size: 3.64 TiB fs: ext4 label: Ext_D2
uuid: 2f9c084e-8203-430b-a005-7c22afbb1f3e
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.5:3 info: NVIDIA stereo controller type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 400mA chip-ID: 0955:7002 class-ID: 0000
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 1.1
Device-2: 2-1.3:4 info: Sunplus Innovation ASUS Webcam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 1bcf:2885 class-ID: 0e02
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
chip-ID: 1a40:0201 class-ID: 0900
Device-1: 3-1.3:3 info: Evoluent VerticalMouse D type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 1a7c:0197 class-ID: 0301
Device-2: 3-1.4:4 info: Microsoft Wireless Receiver 1461C
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 045e:07a5 class-ID: 0300
Device-3: 3-1.6:5 info: Microsoft LifeCam Cinema type: video,audio
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Device-1: 4-2:2 info: Toshiba America MQ04UBF100 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0480:0900 class-ID: 0806
serial: <filter>
Device-2: 4-4:3 info: Toshiba America MQ04UBF100 type: mass storage
serial: <filter>
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 46.0 C
Fan Speeds (rpm): cpu: 2100
Processes: 385 Uptime: 16m wakeups: 1 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
pkgs: 1020 libs: 306 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.29
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
