Hi there,
I cannot make my GPU to be used by the Vulkan properly
First of all, this is a fresh installation of Manjaro and I used proprietary drivers option during installation. Automatically it selected and installed video-hybrid-intel-nvidia-390xx-bumblebee for me. From what I figured out it does not work with Vulkan. Even with pvkrun. In short, it was not able to init GPU device. Additionally it has quite problematic performance. Since I was planning to play mostly Proton-based games from Steam and sometimes using Wine and Lutris, I decided to uninstall this driver completely and used video-nvidia-390xx + optimus manager how it is described here. However, I don’t understand why author used PROTON_USE_WINED3D=1 in the end since it switches to OpenGL completely ![]()
All my tests were made on the same game - Skyrim: Special Edition on Steam. I used to play it on High or Ultra High settings on Windows years ago, so I assume it should be quite possible to do the same now on Manjaro, I’m totally fine even with Medium. I was also able to play the same game very decently on OpenSuse Tumbleweed and most probably on Vulkan since I did not run anything else, just started from Steam and used Proton. So it’s not a hardware issue for sure
I welcome any ideas and advices, here is the info that can be useful ![]()
vkcube --gpu_number 0
Xlib: extension "NV-GLX" missing on display ":0.0".
MESA-INTEL: warning: Haswell Vulkan support is incomplete
Selected GPU 0: Intel(R) HD Graphics 4600 (HSW GT2), type: IntegratedGpu
vkcube --gpu_number 1
GPU 1 specified is not present, GPU count = 1
Specified GPU number is not present
vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.3.279
Instance Extensions: count = 24
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_headless_surface : extension revision 1
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 21
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Layers: count = 4
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Layer Extensions: count = 0
Devices: count = 1
GPU id = 0 (Intel(R) HD Graphics 4600 (HSW GT2))
Layer-Device Extensions: count = 0
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.3.207, layer version 1:
Devices: count = 1
Presentable Surfaces:
GPU id : 0 (Intel(R) HD Graphics 4600 (HSW GT2)):
Surface types: count = 2
VK_KHR_xcb_surface
VK_KHR_xlib_surface
Formats: count = 2
SurfaceFormat[0]:
format = FORMAT_B8G8R8A8_SRGB
colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
SurfaceFormat[1]:
format = FORMAT_B8G8R8A8_UNORM
Present Modes: count = 4
PRESENT_MODE_IMMEDIATE_KHR
PRESENT_MODE_MAILBOX_KHR
PRESENT_MODE_FIFO_KHR
PRESENT_MODE_FIFO_RELAXED_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransforms: count = 1
SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
supportedCompositeAlpha: count = 2
COMPOSITE_ALPHA_OPAQUE_BIT_KHR
COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags: count = 6
IMAGE_USAGE_TRANSFER_SRC_BIT
IMAGE_USAGE_TRANSFER_DST_BIT
IMAGE_USAGE_SAMPLED_BIT
IMAGE_USAGE_STORAGE_BIT
IMAGE_USAGE_COLOR_ATTACHMENT_BIT
IMAGE_USAGE_INPUT_ATTACHMENT_BIT
VkSurfaceProtectedCapabilitiesKHR:
supportsProtected = false
VK_EXT_surface_maintenance_1:
PRESENT_MODE_IMMEDIATE_KHR:
VkSurfacePresentScalingCapabilitiesEXT:
supportedPresentScaling:
None
supportedPresentGravityX:
None
supportedPresentGravityY:
None
minScaledImageExtent:
width = 256
height = 256
maxScaledImageExtent:
width = 256
height = 256
VkSurfacePresentModeCompatibilityEXT:
presentModeCount = 4
pPresentModes: count = 4
PRESENT_MODE_MAILBOX_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
PRESENT_MODE_FIFO_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
PRESENT_MODE_FIFO_RELAXED_KHR:
None
None
None
width = 256
height = 256
width = 256
height = 256
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
apiVersion = 1.2.278 (4202774)
driverVersion = 24.1.6 (100667398)
vendorID = 0x8086
deviceID = 0x0416
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = Intel(R) HD Graphics 4600 (HSW GT2)
pipelineCacheUUID = bacfa54c-4b8d-44a7-1d04-88b1dcbb171b
VkPhysicalDeviceLimits:
maxImageDimension1D = 16384
maxImageDimension2D = 8192
maxImageDimension3D = 2048
maxImageDimensionCube = 16384
maxImageArrayLayers = 2048
maxTexelBufferElements = 134217728
maxUniformBufferRange = 134217728
maxStorageBufferRange = 1073741824
maxPushConstantsSize = 128
maxMemoryAllocationCount = 4294967295
maxSamplerAllocationCount = 65536
bufferImageGranularity = 0x00000001
sparseAddressSpaceSize = 0x00000000
maxBoundDescriptorSets = 32
maxPerStageDescriptorSamplers = 128
maxPerStageDescriptorUniformBuffers = 64
maxPerStageDescriptorStorageBuffers = 64
maxPerStageDescriptorSampledImages = 128
maxPerStageDescriptorStorageImages = 64
maxPerStageDescriptorInputAttachments = 64
maxPerStageResources = 231
maxDescriptorSetSamplers = 768
maxDescriptorSetUniformBuffers = 384
maxDescriptorSetUniformBuffersDynamic = 8
maxDescriptorSetStorageBuffers = 384
maxDescriptorSetStorageBuffersDynamic = 8
maxDescriptorSetSampledImages = 768
maxDescriptorSetStorageImages = 384
maxDescriptorSetInputAttachments = 256
maxVertexInputAttributes = 29
maxVertexInputBindings = 31
maxVertexInputAttributeOffset = 2047
maxVertexInputBindingStride = 2048
maxVertexOutputComponents = 128
maxTessellationGenerationLevel = 64
maxTessellationPatchSize = 32
maxTessellationControlPerVertexInputComponents = 128
maxTessellationControlPerVertexOutputComponents = 128
maxTessellationControlPerPatchOutputComponents = 128
maxTessellationControlTotalOutputComponents = 2048
maxTessellationEvaluationInputComponents = 128
maxTessellationEvaluationOutputComponents = 128
maxGeometryShaderInvocations = 32
maxGeometryInputComponents = 64
maxGeometryOutputComponents = 128
maxGeometryOutputVertices = 256
maxGeometryTotalOutputComponents = 1024
maxFragmentInputComponents = 116
maxFragmentOutputAttachments = 8
maxFragmentDualSrcAttachments = 1
maxFragmentCombinedOutputResources = 136
maxComputeSharedMemorySize = 65536
maxComputeWorkGroupCount: count = 3
65535
65535
65535
maxComputeWorkGroupInvocations = 1024
maxComputeWorkGroupSize: count = 3
1024
1024
1024
subPixelPrecisionBits = 8
subTexelPrecisionBits = 8
mipmapPrecisionBits = 8
maxDrawIndexedIndexValue = 4294967295
maxDrawIndirectCount = 4294967295
maxSamplerLodBias = 16
maxSamplerAnisotropy = 16
maxViewports = 16
maxViewportDimensions: count = 2
16384
16384
viewportBoundsRange: count = 2
-32768
32767
viewportSubPixelBits = 13
minMemoryMapAlignment = 4096
minTexelBufferOffsetAlignment = 0x00000010
minUniformBufferOffsetAlignment = 0x00000040
minStorageBufferOffsetAlignment = 0x00000004
minTexelOffset = -8
maxTexelOffset = 7
minTexelGatherOffset = -32
maxTexelGatherOffset = 31
minInterpolationOffset = -0.5
maxInterpolationOffset = 0.4375
subPixelInterpolationOffsetBits = 4
maxFramebufferWidth = 16384
maxFramebufferHeight = 16384
maxFramebufferLayers = 2048
framebufferColorSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferDepthSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferStencilSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
framebufferNoAttachmentsSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxColorAttachments = 8
sampledImageColorSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageIntegerSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
sampledImageDepthSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
sampledImageStencilSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
storageImageSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
maxSampleMaskWords = 1
timestampComputeAndGraphics = true
timestampPeriod = 80
maxClipDistances = 8
maxCullDistances = 8
maxCombinedClipAndCullDistances = 8
discreteQueuePriorities = 2
pointSizeRange: count = 2
0.125
255.875
lineWidthRange: count = 2
0
7.99219
pointSizeGranularity = 0.125
lineWidthGranularity = 0.0078125
strictLines = false
standardSampleLocations = true
optimalBufferCopyOffsetAlignment = 0x00000080
optimalBufferCopyRowPitchAlignment = 0x00000080
nonCoherentAtomSize = 0x00000040
VkPhysicalDeviceSparseProperties:
residencyStandard2DBlockShape = false
residencyStandard2DMultisampleBlockShape = false
residencyStandard3DBlockShape = false
residencyAlignedMipSize = false
residencyNonResidentStrict = false
VkPhysicalDeviceDepthStencilResolveProperties:
supportedDepthResolveModes: count = 4
RESOLVE_MODE_SAMPLE_ZERO_BIT
RESOLVE_MODE_AVERAGE_BIT
RESOLVE_MODE_MIN_BIT
RESOLVE_MODE_MAX_BIT
supportedStencilResolveModes: count = 1
independentResolveNone = true
independentResolve = true
VkPhysicalDeviceDescriptorIndexingProperties:
maxUpdateAfterBindDescriptorsInAllPools = 1048576
shaderUniformBufferArrayNonUniformIndexingNative = false
shaderSampledImageArrayNonUniformIndexingNative = false
shaderStorageBufferArrayNonUniformIndexingNative = true
shaderStorageImageArrayNonUniformIndexingNative = false
shaderInputAttachmentArrayNonUniformIndexingNative = false
robustBufferAccessUpdateAfterBind = true
quadDivergentImplicitLod = false
maxPerStageDescriptorUpdateAfterBindSamplers = 1048576
maxPerStageDescriptorUpdateAfterBindUniformBuffers = 64
maxPerStageDescriptorUpdateAfterBindStorageBuffers = 4294967295
maxPerStageDescriptorUpdateAfterBindSampledImages = 1048576
maxPerStageDescriptorUpdateAfterBindStorageImages = 1048576
maxPerStageDescriptorUpdateAfterBindInputAttachments = 64
maxPerStageUpdateAfterBindResources = 4294967295
maxDescriptorSetUpdateAfterBindSamplers = 1048576
maxDescriptorSetUpdateAfterBindUniformBuffers = 384
maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindStorageBuffers = 4294967295
maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
maxDescriptorSetUpdateAfterBindSampledImages = 1048576
maxDescriptorSetUpdateAfterBindStorageImages = 1048576
maxDescriptorSetUpdateAfterBindInputAttachments = 256
VkPhysicalDeviceDriverProperties:
driverID = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
driverName = Intel open-source Mesa driver
driverInfo = Mesa 24.1.6-arch1.1
conformanceVersion:
major = 0
minor = 0
subminor = 0
patch = 0
VkPhysicalDeviceDrmPropertiesEXT:
hasPrimary = true
hasRender = true
primaryMajor = 226
primaryMinor = 1
renderMajor = 226
renderMinor = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
denormBehaviorIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
roundingModeIndependence = SHADER_FLOAT_CONTROLS_INDEPENDENCE_NONE
shaderSignedZeroInfNanPreserveFloat16 = true
shaderSignedZeroInfNanPreserveFloat32 = true
shaderSignedZeroInfNanPreserveFloat64 = true
shaderDenormPreserveFloat16 = false
shaderDenormPreserveFloat32 = false
shaderDenormPreserveFloat64 = true
shaderDenormFlushToZeroFloat16 = false
shaderDenormFlushToZeroFloat32 = true
shaderDenormFlushToZeroFloat64 = true
shaderRoundingModeRTEFloat16 = true
shaderRoundingModeRTEFloat32 = true
shaderRoundingModeRTEFloat64 = true
shaderRoundingModeRTZFloat16 = true
shaderRoundingModeRTZFloat32 = true
shaderRoundingModeRTZFloat64 = true
VkPhysicalDeviceIDProperties:
deviceUUID = 86801604-0600-0000-0002-000000000000
driverUUID = 3432abb2-75bd-7f08-0561-20fc4e57a19d
deviceNodeMask = 0
deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
maxInlineUniformBlockSize = 4096
maxPerStageDescriptorInlineUniformBlocks = 32
maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
maxDescriptorSetInlineUniformBlocks = 32
maxDescriptorSetUpdateAfterBindInlineUniformBlocks = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
maxPerSetDescriptors = 1024
maxMemoryAllocationSize = 0x80000000
VkPhysicalDeviceMaintenance4PropertiesKHR:
maxBufferSize = 0x40000000
VkPhysicalDeviceMultiDrawPropertiesEXT:
maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
maxMultiviewViewCount = 16
maxMultiviewInstanceIndex = 268435455
VkPhysicalDevicePCIBusInfoPropertiesEXT:
pciDomain = 0
pciBus = 0
pciDevice = 2
pciFunction = 0
VkPhysicalDevicePointClippingProperties:
pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
provokingVertexModePerPipeline = true
transformFeedbackPreservesTriangleFanProvokingVertex = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
robustStorageBufferAccessSizeAlignment = 0x00000004
robustUniformBufferAccessSizeAlignment = 0x00000040
VkPhysicalDeviceSampleLocationsPropertiesEXT:
sampleLocationSampleCounts: count = 3
SAMPLE_COUNT_1_BIT
SAMPLE_COUNT_4_BIT
SAMPLE_COUNT_8_BIT
maxSampleLocationGridSize:
width = 1
height = 1
sampleLocationCoordinateRange: count = 2
0
0.9375
sampleLocationSubPixelBits = 4
variableSampleLocations = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
filterMinmaxSingleComponentFormats = false
filterMinmaxImageComponentMapping = false
VkPhysicalDeviceShaderIntegerDotProductPropertiesKHR:
integerDotProduct8BitUnsignedAccelerated = false
integerDotProduct8BitSignedAccelerated = false
integerDotProduct8BitMixedSignednessAccelerated = false
integerDotProduct4x8BitPackedUnsignedAccelerated = false
integerDotProduct4x8BitPackedSignedAccelerated = false
integerDotProduct4x8BitPackedMixedSignednessAccelerated = false
integerDotProduct16BitUnsignedAccelerated = false
integerDotProduct16BitSignedAccelerated = false
integerDotProduct16BitMixedSignednessAccelerated = false
integerDotProduct32BitUnsignedAccelerated = false
integerDotProduct32BitSignedAccelerated = false
integerDotProduct32BitMixedSignednessAccelerated = false
integerDotProduct64BitUnsignedAccelerated = false
integerDotProduct64BitSignedAccelerated = false
integerDotProduct64BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating8BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating8BitSignedAccelerated = false
integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated = false
integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating16BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating16BitSignedAccelerated = false
integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating32BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating32BitSignedAccelerated = false
integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated = false
integerDotProductAccumulatingSaturating64BitUnsignedAccelerated = false
integerDotProductAccumulatingSaturating64BitSignedAccelerated = false
integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated = false
VkPhysicalDeviceShaderModuleIdentifierPropertiesEXT:
shaderModuleIdentifierAlgorithmUUID = 4d455341-2d42-4c41-4b45-330000000000
VkPhysicalDeviceSubgroupProperties:
subgroupSize = 32
supportedStages: count = 2
SHADER_STAGE_FRAGMENT_BIT
SHADER_STAGE_COMPUTE_BIT
supportedOperations: count = 6
SUBGROUP_FEATURE_BASIC_BIT
SUBGROUP_FEATURE_VOTE_BIT
SUBGROUP_FEATURE_BALLOT_BIT
SUBGROUP_FEATURE_SHUFFLE_BIT
SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
SUBGROUP_FEATURE_QUAD_BIT
quadOperationsInAllStages = false
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
minSubgroupSize = 8
maxSubgroupSize = 32
maxComputeWorkgroupSubgroups = 64
requiredSubgroupSizeStages: count = 1
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
storageTexelBufferOffsetAlignmentBytes = 0x00000010
storageTexelBufferOffsetSingleTexelAlignment = true
uniformTexelBufferOffsetAlignmentBytes = 0x00000001
uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
maxTransformFeedbackStreams = 4
maxTransformFeedbackBuffers = 4
maxTransformFeedbackBufferSize = 0x100000000
maxTransformFeedbackStreamDataSize = 512
maxTransformFeedbackBufferDataSize = 512
maxTransformFeedbackBufferDataStride = 2048
transformFeedbackQueries = true
transformFeedbackStreamsLinesTriangles = false
transformFeedbackRasterizationStreamSelect = false
transformFeedbackDraw = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
maxVertexAttribDivisor = 268435455
VkPhysicalDeviceVulkan11Properties:
deviceNodeMask = 0
subgroupSize = 32
subgroupSupportedStages: count = 2
subgroupSupportedOperations: count = 6
subgroupQuadOperationsInAllStages = false
VkPhysicalDeviceVulkan12Properties:
conformanceVersion:
major = 0
minor = 0
subminor = 0
patch = 0
framebufferIntegerColorSampleCounts: count = 1
SAMPLE_COUNT_1_BIT
VkPhysicalDeviceHostImageCopyPropertiesEXT:
copySrcLayoutCount = 0
pCopySrcLayouts:
copyDstLayoutCount = 0
pCopyDstLayouts:
optimalTilingLayoutUUID = 00000000-0000-0000-0000-000000000000
identicalMemoryTypeRequirements = false
Device Extensions: count = 105
VK_EXT_4444_formats : extension revision 1
VK_EXT_calibrated_timestamps : extension revision 2
VK_EXT_color_write_enable : extension revision 1
VK_EXT_conditional_rendering : extension revision 2
VK_EXT_depth_clamp_zero_one : extension revision 1
VK_EXT_depth_clip_control : extension revision 1
VK_EXT_depth_clip_enable : extension revision 1
VK_EXT_display_control : extension revision 1
VK_EXT_extended_dynamic_state : extension revision 1
VK_EXT_extended_dynamic_state2 : extension revision 1
VK_EXT_external_memory_dma_buf : extension revision 1
VK_EXT_external_memory_host : extension revision 1
VK_EXT_host_query_reset : extension revision 1
VK_EXT_image_2d_view_of_3d : extension revision 1
VK_EXT_image_drm_format_modifier : extension revision 2
VK_EXT_image_robustness : extension revision 1
VK_EXT_image_view_min_lod : extension revision 1
VK_EXT_index_type_uint8 : extension revision 1
VK_EXT_inline_uniform_block : extension revision 1
VK_EXT_line_rasterization : extension revision 1
VK_EXT_memory_budget : extension revision 1
VK_EXT_multi_draw : extension revision 1
VK_EXT_non_seamless_cube_map : extension revision 1
VK_EXT_pci_bus_info : extension revision 2
VK_EXT_physical_device_drm : extension revision 1
VK_EXT_pipeline_creation_cache_control : extension revision 3
VK_EXT_pipeline_creation_feedback : extension revision 1
VK_EXT_primitive_topology_list_restart : extension revision 1
VK_EXT_primitives_generated_query : extension revision 1
VK_EXT_private_data : extension revision 1
VK_EXT_provoking_vertex : extension revision 1
VK_EXT_queue_family_foreign : extension revision 1
VK_EXT_robustness2 : extension revision 1
VK_EXT_sample_locations : extension revision 1
VK_EXT_scalar_block_layout : extension revision 1
VK_EXT_separate_stencil_usage : extension revision 1
VK_EXT_shader_atomic_float : extension revision 1
VK_EXT_shader_demote_to_helper_invocation : extension revision 1
VK_EXT_shader_module_identifier : extension revision 1
VK_EXT_shader_subgroup_ballot : extension revision 1
VK_EXT_shader_subgroup_vote : extension revision 1
VK_EXT_shader_viewport_index_layer : extension revision 1
VK_EXT_subgroup_size_control : extension revision 2
VK_EXT_texel_buffer_alignment : extension revision 1
VK_EXT_tooling_info : extension revision 1
VK_EXT_transform_feedback : extension revision 1
VK_EXT_vertex_attribute_divisor : extension revision 3
VK_EXT_ycbcr_image_arrays : extension revision 1
VK_GOOGLE_decorate_string : extension revision 1
VK_GOOGLE_hlsl_functionality1 : extension revision 1
VK_GOOGLE_user_type : extension revision 1
VK_KHR_bind_memory2 : extension revision 1
VK_KHR_copy_commands2 : extension revision 1
VK_KHR_create_renderpass2 : extension revision 1
VK_KHR_dedicated_allocation : extension revision 3
VK_KHR_deferred_host_operations : extension revision 4
VK_KHR_depth_stencil_resolve : extension revision 1
VK_KHR_descriptor_update_template : extension revision 1
VK_KHR_device_group : extension revision 4
VK_KHR_draw_indirect_count : extension revision 1
VK_KHR_driver_properties : extension revision 1
VK_KHR_dynamic_rendering : extension revision 1
VK_KHR_external_fence : extension revision 1
VK_KHR_external_fence_fd : extension revision 1
VK_KHR_external_memory : extension revision 1
VK_KHR_external_memory_fd : extension revision 1
VK_KHR_external_semaphore : extension revision 1
VK_KHR_external_semaphore_fd : extension revision 1
VK_KHR_format_feature_flags2 : extension revision 2
VK_KHR_get_memory_requirements2 : extension revision 1
VK_KHR_image_format_list : extension revision 1
VK_KHR_imageless_framebuffer : extension revision 1
VK_KHR_incremental_present : extension revision 2
VK_KHR_maintenance1 : extension revision 2
VK_KHR_maintenance2 : extension revision 1
VK_KHR_maintenance3 : extension revision 1
VK_KHR_maintenance4 : extension revision 2
VK_KHR_multiview : extension revision 1
VK_KHR_pipeline_executable_properties : extension revision 1
VK_KHR_push_descriptor : extension revision 2
VK_KHR_relaxed_block_layout : extension revision 1
VK_KHR_sampler_mirror_clamp_to_edge : extension revision 3
VK_KHR_sampler_ycbcr_conversion : extension revision 14
VK_KHR_separate_depth_stencil_layouts : extension revision 1
VK_KHR_shader_clock : extension revision 1
VK_KHR_shader_draw_parameters : extension revision 1
VK_KHR_shader_expect_assume : extension revision 1
VK_KHR_shader_float_controls : extension revision 4
VK_KHR_shader_integer_dot_product : extension revision 1
VK_KHR_shader_non_semantic_info : extension revision 1
VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
VK_KHR_shader_terminate_invocation : extension revision 1
VK_KHR_spirv_1_4 : extension revision 1
VK_KHR_storage_buffer_storage_class : extension revision 1
VK_KHR_swapchain : extension revision 70
VK_KHR_swapchain_mutable_format : extension revision 1
VK_KHR_synchronization2 : extension revision 1
VK_KHR_timeline_semaphore : extension revision 2
VK_KHR_uniform_buffer_standard_layout : extension revision 1
VK_KHR_variable_pointers : extension revision 1
VK_KHR_vulkan_memory_model : extension revision 3
VK_KHR_workgroup_memory_explicit_layout : extension revision 1
VK_KHR_zero_initialize_workgroup_memory : extension revision 1
VK_NV_compute_shader_derivatives : extension revision 1
VK_VALVE_mutable_descriptor_type : extension revision 1
VkQueueFamilyProperties:
queueProperties[0]:
minImageTransferGranularity = (1,1,1)
queueCount = 1
queueFlags = QUEUE_GRAPHICS_BIT | QUEUE_COMPUTE_BIT | QUEUE_TRANSFER_BIT
timestampValidBits = 36
present support = true
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 1
memoryHeaps[0]:
size = 1610612736 (0x60000000) (1.50 GiB)
budget = 1610612736 (0x60000000) (1.50 GiB)
usage = 0 (0x00000000) (0.00 B)
flags: count = 1
MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 2
memoryTypes[0]:
heapIndex = 0
propertyFlags = 0x0001: count = 1
MEMORY_PROPERTY_DEVICE_LOCAL_BIT
usable for:
IMAGE_TILING_OPTIMAL:
color images
FORMAT_D16_UNORM
FORMAT_X8_D24_UNORM_PACK32
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
FORMAT_D24_UNORM_S8_UINT
FORMAT_D32_SFLOAT_S8_UINT
(non-sparse)
IMAGE_TILING_LINEAR:
color images
(non-sparse)
memoryTypes[1]:
heapIndex = 0
propertyFlags = 0x000f: count = 4
MEMORY_PROPERTY_HOST_VISIBLE_BIT
MEMORY_PROPERTY_HOST_COHERENT_BIT
MEMORY_PROPERTY_HOST_CACHED_BIT
usable for:
color images
FORMAT_D16_UNORM
FORMAT_D32_SFLOAT
FORMAT_S8_UINT
(non-sparse)
color images
(non-sparse)
VkPhysicalDeviceFeatures:
robustBufferAccess = true
fullDrawIndexUint32 = true
imageCubeArray = true
independentBlend = true
geometryShader = true
tessellationShader = true
sampleRateShading = true
dualSrcBlend = true
logicOp = true
multiDrawIndirect = true
drawIndirectFirstInstance = true
depthClamp = true
depthBiasClamp = true
fillModeNonSolid = true
depthBounds = false
wideLines = true
largePoints = true
alphaToOne = true
multiViewport = true
samplerAnisotropy = true
textureCompressionETC2 = false
textureCompressionASTC_LDR = false
textureCompressionBC = true
occlusionQueryPrecise = true
pipelineStatisticsQuery = true
vertexPipelineStoresAndAtomics = false
fragmentStoresAndAtomics = true
shaderTessellationAndGeometryPointSize = true
shaderImageGatherExtended = true
shaderStorageImageExtendedFormats = true
shaderStorageImageMultisample = false
shaderStorageImageReadWithoutFormat = false
shaderStorageImageWriteWithoutFormat = true
shaderUniformBufferArrayDynamicIndexing = true
shaderSampledImageArrayDynamicIndexing = true
shaderStorageBufferArrayDynamicIndexing = true
shaderStorageImageArrayDynamicIndexing = true
shaderClipDistance = true
shaderCullDistance = true
shaderFloat64 = false
shaderInt64 = false
shaderInt16 = false
shaderResourceResidency = false
shaderResourceMinLod = false
sparseBinding = false
sparseResidencyBuffer = false
sparseResidencyImage2D = false
sparseResidencyImage3D = false
sparseResidency2Samples = false
sparseResidency4Samples = false
sparseResidency8Samples = false
sparseResidency16Samples = false
sparseResidencyAliased = false
variableMultisampleRate = true
inheritedQueries = true
VkPhysicalDevice16BitStorageFeatures:
storageBuffer16BitAccess = false
uniformAndStorageBuffer16BitAccess = false
storagePushConstant16 = false
storageInputOutput16 = false
VkPhysicalDevice4444FormatsFeaturesEXT:
formatA4R4G4B4 = true
formatA4B4G4R4 = false
VkPhysicalDevice8BitStorageFeatures:
storageBuffer8BitAccess = false
uniformAndStorageBuffer8BitAccess = false
storagePushConstant8 = false
VkPhysicalDeviceBufferDeviceAddressFeatures:
bufferDeviceAddress = false
bufferDeviceAddressCaptureReplay = false
bufferDeviceAddressMultiDevice = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
colorWriteEnable = true
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
conditionalRendering = true
inheritedConditionalRendering = true
VkPhysicalDeviceDepthClampZeroOneFeaturesEXT:
depthClampZeroOne = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
shaderInputAttachmentArrayDynamicIndexing = false
shaderUniformTexelBufferArrayDynamicIndexing = false
shaderStorageTexelBufferArrayDynamicIndexing = false
shaderUniformBufferArrayNonUniformIndexing = false
shaderSampledImageArrayNonUniformIndexing = false
shaderStorageBufferArrayNonUniformIndexing = false
shaderStorageImageArrayNonUniformIndexing = false
shaderInputAttachmentArrayNonUniformIndexing = false
shaderUniformTexelBufferArrayNonUniformIndexing = false
shaderStorageTexelBufferArrayNonUniformIndexing = false
descriptorBindingUniformBufferUpdateAfterBind = false
descriptorBindingSampledImageUpdateAfterBind = false
descriptorBindingStorageImageUpdateAfterBind = false
descriptorBindingStorageBufferUpdateAfterBind = false
descriptorBindingUniformTexelBufferUpdateAfterBind = false
descriptorBindingStorageTexelBufferUpdateAfterBind = false
descriptorBindingUpdateUnusedWhilePending = false
descriptorBindingPartiallyBound = false
descriptorBindingVariableDescriptorCount = false
runtimeDescriptorArray = false
VkPhysicalDeviceDynamicRenderingFeaturesKHR:
dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
extendedDynamicState2 = true
extendedDynamicState2LogicOp = true
extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
extendedDynamicState = true
VkPhysicalDeviceHostQueryResetFeatures:
hostQueryReset = true
VkPhysicalDeviceImage2DViewOf3DFeaturesEXT:
image2DViewOf3D = true
sampler2DViewOf3D = false
VkPhysicalDeviceImageRobustnessFeaturesEXT:
robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
inlineUniformBlock = true
descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
rectangularLines = false
bresenhamLines = true
smoothLines = true
stippledRectangularLines = false
stippledBresenhamLines = true
stippledSmoothLines = false
VkPhysicalDeviceMaintenance4FeaturesKHR:
maintenance4 = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
multiview = true
multiviewGeometryShader = true
multiviewTessellationShader = true
VkPhysicalDeviceMutableDescriptorTypeFeaturesEXT:
mutableDescriptorType = true
VkPhysicalDeviceNonSeamlessCubeMapFeaturesEXT:
nonSeamlessCubeMap = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
primitiveTopologyListRestart = true
primitiveTopologyPatchListRestart = true
VkPhysicalDevicePrimitivesGeneratedQueryFeaturesEXT:
primitivesGeneratedQuery = true
primitivesGeneratedQueryWithRasterizerDiscard = false
primitivesGeneratedQueryWithNonZeroStreams = false
VkPhysicalDevicePrivateDataFeaturesEXT:
privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
provokingVertexLast = true
transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
robustBufferAccess2 = true
robustImageAccess2 = true
nullDescriptor = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
shaderBufferFloat32Atomics = true
shaderBufferFloat32AtomicAdd = false
shaderBufferFloat64Atomics = false
shaderBufferFloat64AtomicAdd = false
shaderSharedFloat32Atomics = true
shaderSharedFloat32AtomicAdd = false
shaderSharedFloat64Atomics = false
shaderSharedFloat64AtomicAdd = false
shaderImageFloat32Atomics = true
shaderImageFloat32AtomicAdd = false
sparseImageFloat32Atomics = false
sparseImageFloat32AtomicAdd = false
VkPhysicalDeviceShaderAtomicInt64Features:
shaderBufferInt64Atomics = false
shaderSharedInt64Atomics = false
VkPhysicalDeviceShaderClockFeaturesKHR:
shaderSubgroupClock = true
shaderDeviceClock = false
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
shaderFloat16 = false
shaderInt8 = false
VkPhysicalDeviceShaderIntegerDotProductFeaturesKHR:
shaderIntegerDotProduct = true
VkPhysicalDeviceShaderModuleIdentifierFeaturesEXT:
shaderModuleIdentifier = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
subgroupSizeControl = true
computeFullSubgroups = true
VkPhysicalDeviceSynchronization2FeaturesKHR:
synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
transformFeedback = true
geometryStreams = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
variablePointersStorageBuffer = true
variablePointers = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
vertexAttributeInstanceRateDivisor = true
vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
multiview = true
VkPhysicalDeviceVulkan12Features:
samplerMirrorClampToEdge = true
drawIndirectCount = true
shaderInt8 = false
descriptorIndexing = false
samplerFilterMinmax = false
vulkanMemoryModel = true
vulkanMemoryModelDeviceScope = true
vulkanMemoryModelAvailabilityVisibilityChains = true
shaderOutputViewportIndex = true
shaderOutputLayer = true
subgroupBroadcastDynamicId = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
workgroupMemoryExplicitLayout = true
workgroupMemoryExplicitLayoutScalarBlockLayout = true
workgroupMemoryExplicitLayout8BitAccess = true
workgroupMemoryExplicitLayout16BitAccess = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
shaderZeroInitializeWorkgroupMemory = true
PC info
Host: th-manjaro Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64
Desktop: Xfce v: 4.18.1 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20217 v: Lenovo IdeaPad Y510P
serial: <superuser required>
Mobo: LENOVO model: VIQY0Y1 v: 31900060STD serial: <superuser required>
UEFI: LENOVO v: 74CN44WW(V3.05) date: 09/18/2013
ID-1: BAT1 charge: 32.6 Wh (100.0%) condition: 32.6/52.8 Wh (61.7%)
Info: dual core model: Intel Core i5-4200M bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 798 min/max: 800/3100 cores: 1: 798 2: 798 3: 798 4: 798
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK107M [GeForce GT 755M] driver: nouveau v: kernel
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB
Display: x11 server: X.org v: 1.21.1.13 driver: X: loaded: modesetting
dri: crocus,nouveau gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: crocus,nouveau,swrast
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.1.6-arch1.1
renderer: Mesa Intel HD Graphics 4600 (HSW GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
Device-3: NVIDIA GK107 HDMI Audio driver: snd_hda_intel
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api
Server-1: PipeWire v: 1.2.3 status: active
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
IF: enp7s0 state: down mac: 28:d2:44:63:b5:14
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi
IF: wlp8s0 state: up mac: 00:c2:c6:2c:dd:55
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb
type: USB
Local Storage: total: 1.02 TiB used: 36.92 GiB (3.5%)
ID-1: /dev/sda vendor: GOODRAM model: SSDPR-S400U-120-42 size: 111.79 GiB
ID-2: /dev/sdb vendor: Seagate model: ST1000LM014-SSHD-8GB
ID-1: / size: 100.52 GiB used: 35.93 GiB (35.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 8.8 GiB used: 1009.2 MiB (11.2%)
dev: /dev/sda3
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.67 GiB used: 3.02 GiB (39.3%)
Processes: 240 Uptime: 49m Shell: Bash inxi: 3.3.36
GPU & drivers info
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0416
class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 755M] vendor: Lenovo driver: nouveau
v: kernel alternate: nvidia_drm,nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler-2 code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:0fcd class-ID: 0300 temp: 37.0 C
Device-3: Realtek Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:58b9
class-ID: 0e02 serial: 200901010001
Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0
driver: X: loaded: modesetting dri: crocus,nouveau gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: LG Display 0x02d9 built: 2011 res: 1920x1080
hz: 60 dpi: 141 gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
device: 0 drv: crocus device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: crocus surfaceless: drv: crocus x11: drv: crocus inactive: wayland
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:0416 surfaces: xcb,xlib
pacman -Qs nvidia
local/egl-wayland 4:1.1.13.1-1
EGLStream-based Wayland external platform
local/lib32-nvidia-390xx-utils 390.157-4
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-3
Nvidia VDPAU library
local/libxnvctrl-390xx 390.157-4
NVIDIA NV-CONTROL X extension
local/linux69-nvidia-390xx 390.157-21 (linux69-extramodules)
NVIDIA drivers for linux
local/mhwd-nvidia 550.107.02-1
MHWD module-ids for nvidia 550.107.02
local/mhwd-nvidia-390xx 390.157-14
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-4
MHWD module-ids for nvidia 470.256.02
local/nvidia-390xx-settings 390.157-4
Tool for configuring the NVIDIA graphics driver
local/nvidia-390xx-utils 390.157-14
local/nvidia-prime 1.0-5
NVIDIA Prime Render Offload configuration and utilities
local/vulkan-nouveau 1:24.1.6-1
Open-source Vulkan driver for Nvidia GPUs
pacman -Qs vulkan
local/lib32-vulkan-icd-loader 1.3.279-1
Vulkan Installable Client Driver (ICD) Loader (32-bit)
local/spirv-tools 2024.2-1 (vulkan-devel)
API and commands for processing SPIR-V modules
local/vulkan-headers 1:1.3.285-1 (vulkan-devel)
Vulkan header files
local/vulkan-icd-loader 1.3.285-1
local/vulkan-intel 1:24.1.6-1
Open-source Vulkan driver for Intel GPUs
local/vulkan-tools 1.3.269-1 (vulkan-devel)
Vulkan Utilities and Tools
mhwd -l -d --pci
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:0fcd)
Display controller nVidia Corporation GK107M [GeForce GT 755M]
> INSTALLED:
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302
VENDORIDS: 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2024.05.06
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0416)
Display controller Intel Corporation 4th Gen Core Processor Integrated Graphics Controller
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2024.05.06
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
