I’ve tried the Nvidia drivers on the USB drive and then can’t boot into the USB drive. I’ve tried installing the drivers after installing the OS using the Open source drivers and then I can’t get back into the DE. Under no circumstances can I use the Nvidia drivers. I have a dual booth of Manjaro KDE and Manjaro Gnome and both must use the Open Source drivers.
Kernel: 5.11.16-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=1b24c3b1-e405-4586-a862-5a33ac595aac rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Apple product: MacBookPro10,1 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-C3EC7CD22292981F serial: <filter>
Mobo: Apple model: Mac-C3EC7CD22292981F v: MacBookPro10,1 serial: <filter>
UEFI: Apple v: 421.0.0.0.0 date: 12/17/2020
ID-1: BAT0 charge: 93.6 Wh (99.9%) condition: 93.7/91.6 Wh (102.3%)
volts: 12.7 min: 10.9 model: Newer Tech A1417 type: Li-ion serial: N/A
status: Full cycles: 70
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1
model: Logitech K780 Multi-Device Wireless Keyboard serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 15.54 GiB used: 4.01 GiB (25.8%)
Info: Quad Core model: Intel Core i7-3740QM bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
cache: L2: 6 MiB bogomips: 43112
Speed: 1197 MHz min/max: 1200/3700 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1262 4: 1197 5: 1197 6: 1203 7: 1645 8: 1197
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8510 class-ID: 0e02 serial: <filter>
Device-4: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
bus-ID: 3-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
Device-5: Apple FaceTime HD Camera (Display) type: USB driver: uvcvideo
bus-ID: 4-1.5:4 chip-ID: 05ac:1112 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: NVE7 v: 4.3 Mesa 21.0.3 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-3: Apple Thunderbolt Display Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:3 chip-ID: 05ac:1107
class-ID: 0300 serial: <filter>
Device-4: Apple Thunderbolt Display Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 4-1.4:3 chip-ID: 05ac:1107
Device-5: Logitech H600 [Wireless Headset] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-2.3:8 chip-ID: 046d:0a29
Sound Server-1: ALSA v: k5.11.16-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Broadcom NetXtreme BCM57786 Gigabit Ethernet PCIe driver: N/A
port: 2000 bus-ID: 03:00.0 chip-ID: 14e4:16a3 class-ID: 0200
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
driver: wl v: kernel modules: bcma port: 2000 bus-ID: 04:00.0
chip-ID: 14e4:4331 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-3: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
driver: tg3 v: kernel port: 2000 bus-ID: 0d:00.0 chip-ID: 14e4:16b0
class-ID: 0200
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-4: Broadcom NetXtreme BCM57761 Gigabit Ethernet PCIe vendor: Apple
driver: tg3 v: kernel port: 2000 bus-ID: 3e:00.0 chip-ID: 14e4:16b0
class-ID: 0200
IF: enp62s0 state: down mac: <filter>
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:8 chip-ID: 05ac:8286 class-ID: fe01
Local Storage: total: 8.19 TiB used: 2.44 TiB (29.8%)
ID-1: /dev/sda maj-min: 8:0 model: Aura Pro S MB258 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 6ANR scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Backup+ Hub BK
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B serial: <filter>
rev: D781 scheme: GPT
ID-1: / raw-size: 186.06 GiB size: 182.08 GiB (97.86%)
used: 23.99 GiB (13.2%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 1b24c3b1-e405-4586-a862-5a33ac595aac
ID-2: /boot/efi raw-size: 200 MiB size: 196.9 MiB (98.45%)
used: 8.4 MiB (4.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: EFI
uuid: 67E3-17ED
ID-3: /run/media/bryankarlan/Manjaro External raw-size: 933.72 GiB
size: 918 GiB (98.32%) used: 28.75 GiB (3.1%) fs: ext4 dev: /dev/sdb3
maj-min: 8:19 label: Manjaro External
uuid: c9710831-4d6c-4c5f-b85c-fa6e616c18cb
ID-4: /run/media/bryankarlan/Seagate 8TB raw-size: 6.37 TiB
size: 6.37 TiB (100.00%) used: 2.33 TiB (36.6%) fs: hfsplus dev: /dev/sdb2
maj-min: 8:18 label: Seagate 8TB uuid: 900e39fb-e11f-391c-b3eb-e23951153d08
ID-5: /run/timeshift/backup raw-size: 202.81 GiB size: 198.57 GiB (97.91%)
used: 60.28 GiB (30.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Data
uuid: 118bfd46-6603-48f5-b56c-2fd577082f14
ID-1: swap-1 type: partition size: 16.77 GiB used: 101.2 MiB (0.6%)
priority: -2 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 2feb6cc8-3860-4730-8947-66bdfab3c1f6
ID-1: /dev/sda2 maj-min: 8:2 size: 525.56 GiB fs: ext4 label: N/A
uuid: 2888ee6c-3156-40cc-ab58-b2efb0745350
ID-2: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera (Built-in) type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 2 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2512 class-ID: 0900
Hub-6: 2-1.8.1:4
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.8.1.3:8 info: Apple Bluetooth Host Controller type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8286
class-ID: fe01
Device-2: 2-1.8.2:5 info: Apple Apple Internal Keyboard / Trackpad
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0262 class-ID: 0301
Hub-7: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-8: 3-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 05ac:9127 class-ID: 0900
Device-1: 3-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 2mA chip-ID: 05ac:1107 class-ID: 0300 serial: <filter>
Device-2: 3-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
Device-3: 3-1.7:5 info: Apple Thunderbolt Display type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 2mA
chip-ID: 05ac:9227 class-ID: 0300 serial: <filter>
Hub-9: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-10: 4-1:2 info: Apple Hub in Thunderbolt Display ports: 7 rev: 2.0
Device-1: 4-1.4:3 info: Apple Thunderbolt Display Audio type: Audio,HID
Device-2: 4-1.5:4 info: Apple FaceTime HD Camera (Display) type: Video
Device-3: 4-1.7:5 info: Apple Thunderbolt Display type: HID
Hub-11: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
speed: 12 Mb/s chip-ID: 1d6b:0001 class-ID: 0900
Hub-12: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-13: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-14: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1
Hub-15: 9-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 9-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-16: 9-2:5 info: Seagate RSS LLC Backup Plus Hub ports: 3 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 0bc2:ab44 class-ID: 0900
Device-1: 9-2.3:8 info: Logitech H600 [Wireless Headset] type: Audio,HID
speed: 12 Mb/s power: 144mA chip-ID: 046d:0a29 class-ID: 0300
serial: <filter>
Hub-17: 10-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-18: 10-2:2 info: Seagate RSS LLC Backup+ Hub ports: 3 rev: 3.0
speed: 5 Gb/s chip-ID: 0bc2:ab45 class-ID: 0900
Device-1: 10-2.1:3 info: Seagate RSS LLC Backup Plus Hub (Mass Storage)
type: Mass Storage driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bc2:ab38 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 72.0 C mobo: 54.0 C gpu: nouveau temp: 60.0 C
Processes: 330 Uptime: 5h 13m wakeups: 30 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: 1251 pacman: 1231 lib: 300
flatpak: 14 snap: 6 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.04
