I noticed below, my nvidia driver is n/a and i opened the manjaro settings and then hardware configuration. I saw there is some drivers installed and i tried to remove and download another driver, but when i press remove it gives that error.
removing nvidia-450xx-utils breaks dependency nvidia-450xx-utils=450.80.02 required by linux59-rt-nvidia-450xx
Error: pacman failed!
Error: script failed!
Done ...
And when i try to download, it says they are in conflict. I don’t know what to do.
Kernel: 5.10.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=8d12cffe-8d67-43f7-8d3e-b1ef8e1b5ccf rw quiet apparmor=1
security=apparmor resume=UUID=61d29079-687e-4a30-8ec3-295e2274fb4b
udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion 15 Notebook PC
v: 0975110000405F10000610180 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Hewlett-Packard model: 2281 v: 77.25 serial: <filter> UEFI: Insyde
v: F.11 date: 08/07/2014
ID-1: BAT0 charge: 28.9 Wh condition: 28.9/28.9 Wh (100%) volts: 16.8/14.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
Info: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
L2 cache: 3072 KiB
bogomips: 19160
Speed: 2310 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 2310 2: 2224
3: 2406 4: 2263
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
Device-2: NVIDIA GM108M [GeForce 840M] vendor: Hewlett-Packard driver: N/A
alternate: nouveau bus ID: 0a:00.0 chip ID: 10de:1341
Device-3: Realtek HP Truevision HD laptop camera type: USB driver: uvcvideo
bus ID: 1-1.3:4 chip ID: 0bda:5775 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel,nouveau display ID: :0.0
screens: 1
Screen-1: 0 s-res: 2646x768 s-dpi: 96 s-size: 700x203mm (27.6x8.0")
s-diag: 729mm (28.7")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
Monitor-2: HDMI1 res: 1280x720 hz: 60 dpi: 203 size: 160x90mm (6.3x3.5")
diag: 184mm (7.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
Device-3: C-Media segment type: USB driver: hid-generic,snd-usb-audio,usbhid
bus ID: 2-6:3 chip ID: 0d8c:0012
Sound Server: ALSA v: k5.10.0-1-MANJARO
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 5000
bus ID: 08:00.0 chip ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus ID: 09:00.0 chip ID: 10ec:8136
Local Storage: total: 931.51 GiB used: 129.16 GiB (13.9%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM014-1EJ164-SSHD
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: HPP1 scheme: GPT
ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%)
used: 129.16 GiB (14.2%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 222 Uptime: 7h 23m Memory: 7.70 GiB used: 3.10 GiB (40.3%)
Init: systemd v: 246 target: graphical.target Compilers: gcc: 10.2.0
clang: 10.0.1 Packages: 1440 pacman: 1435 lib: 406 flatpak: 0 snap: 5
Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
