I tried to fix the Flickering issue in
Now lightdm won’t start
mhwd -i pci video-nvidia-570xx
sudo mhwd -i pci video-nvidia-570xx
> Installing video-nvidia-570xx...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-570xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading...
extra downloading...
multilib downloading...
resolving dependencies...
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-570xx-utils dependency
Packages (9) egl-gbm-1.1.2.1-1 egl-wayland-4:1.1.21-1 egl-x11-1.0.4-1 eglexternalplatform-1.2.1-1 lib32-nvidia-570xx-utils-570.207-1 linux617-nvidia-570xx-open-570.207-6 linux618-nvidia-570xx-open-570.207-4 nvidia-570xx-settings-570.207-2 nvidia-570xx-utils-570.207-2
Total Installed Size: 1055.87 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing eglexternalplatform...
installing egl-wayland...
installing egl-gbm...
installing egl-x11...
installing nvidia-570xx-utils...
Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-resume.service' → '/usr/lib/systemd/system/nvidia-resume.service'.
Created symlink '/etc/systemd/system/systemd-hibernate.service.wants/nvidia-hibernate.service' → '/usr/lib/systemd/system/nvidia-hibernate.service'.
Created symlink '/etc/systemd/system/systemd-suspend.service.wants/nvidia-suspend.service' → '/usr/lib/systemd/system/nvidia-suspend.service'.
Created symlink '/etc/systemd/system/systemd-suspend-then-hibernate.service.wants/nvidia-suspend-then-hibernate.service' → '/usr/lib/systemd/system/nvidia-suspend-then-hibernate.service'.
Optional dependencies for nvidia-570xx-utils
nvidia-570xx-settings: configuration tool [pending]
xorg-server: Xorg support [installed]
xorg-server-devel: nvidia-xconfig
opencl-nvidia-570xx=570.207: OpenCL support
installing nvidia-570xx-settings...
installing lib32-nvidia-570xx-utils...
Optional dependencies for lib32-nvidia-570xx-utils
lib32-opencl-nvidia-570xx
installing linux617-nvidia-570xx-open...
installing linux618-nvidia-570xx-open...
(1/8) Creating system user accounts...
(2/8) Reloading system manager configuration...
(3/8) Reloading device manager configuration...
(4/8) Arming ConditionNeedsUpdate...
(5/8) Updating module dependencies...
(6/8) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux617.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.17-x86_64 -g /boot/initramfs-6.17-x86_64.img
==> Starting build: '6.17.12-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.17-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux618.preset: 'default'
-> -k /boot/vmlinuz-6.18-x86_64 -g /boot/initramfs-6.18-x86_64.img
==> Starting build: '6.18.1-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.18-x86_64.img'
(7/8) Reloading system bus configuration...
(8/8) Updating the desktop file MIME type cache...
nvidia-570xx-utils: install reason has been set to 'explicitly installed'
nvidia-570xx-settings: install reason has been set to 'explicitly installed'
lib32-nvidia-570xx-utils: install reason has been set to 'explicitly installed'
linux617-nvidia-570xx-open: install reason has been set to 'explicitly installed'
linux618-nvidia-570xx-open: install reason has been set to 'explicitly installed'
rmmod: ERROR: could not remove 'nouveau': No such file or directory
rmmod: ERROR: could not remove module nouveau: No such file or directory
rmmod: ERROR: could not remove 'ttm': No such file or directory
rmmod: ERROR: could not remove module ttm: No such file or directory
rmmod: ERROR: could not remove 'drm_kms_helper': No such file or directory
rmmod: ERROR: could not remove module drm_kms_helper: No such file or directory
rmmod: ERROR: could not remove 'drm': No such file or directory
rmmod: ERROR: could not remove module drm: No such file or directory
modprobe: FATAL: Module nvidia not found in directory /lib/modules/6.17.12-1-MANJARO
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
modprobe: FATAL: Module nvidia_drm not found in directory /lib/modules/6.17.12-1-MANJARO
> Successfully installed video-nvidia-570xx
Xorg.0.log
cat /var/log/Xorg.0.log
[ 6.721]
X.Org X Server 1.21.1.21
[ 6.721] Current Operating System: Linux joel-man 6.17.12-1-MANJARO #1 SMP PREEMPT_DYNAMIC Fri, 12 Dec 2025 19:42:49 +0000 x86_64
[ 6.721] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64 root=UUID=b32fec85-6680-4f13-90d2-4704491d2a55 rw quiet splash udev.log_priority=3
[ 6.721]
[ 6.721] Current version of pixman: 0.46.4
[ 6.721] Before reporting problems, check http://wiki.x.org
[ 6.721] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.721] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec 20 14:02:13 2025
[ 6.721] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.721] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.721] (==) ServerLayout "Layout0"
[ 6.721] (**) |-->Screen "Screen0" (0)
[ 6.721] (**) | |-->Monitor "Monitor0"
[ 6.721] (**) | |-->Device "Device0"
[ 6.721] (**) |-->Input Device "Keyboard0"
[ 6.721] (**) |-->Input Device "Mouse0"
[ 6.721] (**) Allowing byte-swapped clients
[ 6.721] (==) Automatically adding devices
[ 6.721] (==) Automatically enabling devices
[ 6.721] (==) Automatically adding GPU devices
[ 6.721] (==) Automatically binding GPU devices
[ 6.721] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.721] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.721] Entry deleted from font path.
[ 6.721] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.721] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.721] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 6.721] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.721] (**) Extension "COMPOSITE" is enabled
[ 6.721] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 6.721] (WW) Disabling Keyboard0
[ 6.721] (WW) Disabling Mouse0
[ 6.721] (II) Module ABI versions:
[ 6.721] X.Org ANSI C Emulation: 0.4
[ 6.721] X.Org Video Driver: 25.2
[ 6.721] X.Org XInput driver : 24.4
[ 6.721] X.Org Server Extension : 10.0
[ 6.721] (++) using VT number 7
[ 6.721] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.722] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.722] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/simple-framebuffer.0/drm/card0
[ 6.727] (--) PCI:*(1@0:0:0) 10de:1b81:1028:3301 rev 161, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 6.727] (II) LoadModule: "glx"
[ 6.727] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.728] (II) Module glx: vendor="X.Org Foundation"
[ 6.728] compiled for 1.21.1.21, module version = 1.0.0
[ 6.728] ABI class: X.Org Server Extension, version 10.0
[ 6.728] (II) LoadModule: "nvidia"
[ 6.728] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 6.728] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 6.728] compiled for 1.6.99.901, module version = 1.0.0
[ 6.728] Module class: X.Org Video Driver
[ 6.728] (II) NVIDIA dlloader X Driver 570.207 Fri Nov 14 21:30:43 UTC 2025
[ 6.728] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 6.728] (II) Loading sub module "fb"
[ 6.728] (II) LoadModule: "fb"
[ 6.728] (II) Module "fb" already built-in
[ 6.728] (II) Loading sub module "wfb"
[ 6.728] (II) LoadModule: "wfb"
[ 6.728] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 6.728] (II) Module wfb: vendor="X.Org Foundation"
[ 6.728] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.730] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 6.730] (EE) NVIDIA: system's kernel log for additional error messages and
[ 6.730] (EE) NVIDIA: consult the NVIDIA README for details.
[ 6.732] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 6.732] (EE) NVIDIA: system's kernel log for additional error messages and
[ 6.732] (EE) NVIDIA: consult the NVIDIA README for details.
[ 6.734] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 6.734] (EE) NVIDIA: system's kernel log for additional error messages and
[ 6.734] (EE) NVIDIA: consult the NVIDIA README for details.
[ 6.736] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 6.736] (EE) NVIDIA: system's kernel log for additional error messages and
[ 6.736] (EE) NVIDIA: consult the NVIDIA README for details.
[ 6.736] (EE) No devices detected.
[ 6.736] (EE)
Fatal server error:
[ 6.736] (EE) no screens found(EE)
[ 6.736] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 6.736] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 6.736] (EE)
[ 6.736] (EE) Server terminated with error (1). Closing log file.
inxi -Fazy
inxi -Fazy
Kernel: 6.17.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
udev.log_priority=3
Console: pty pts/0 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
Type: Desktop System: Dell product: Inspiron 5680 v: 2.2.0
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Dell model: 0PXWHK v: A00 serial: <superuser required> part-nu: 0874
uuid: <superuser required> Firmware: UEFI vendor: Dell v: 2.2.0
date: 12/05/2019
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 76799
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Dell driver: N/A
alternate: nouveau, nova_core non-free: 550-580.xx+ status: current (as of
2025-11; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: unspecified server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
driver: X: loaded: N/A failed: nvidia gpu: N/A tty: 102x51
Monitor-1: Unknown-1 size-res: N/A in console modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
inactive: gbm,wayland,x11
API: OpenGL v: 4.5 vendor: mesa v: 25.3.1-arch1.2
note: console (EGL sourced) renderer: llvmpipe (LLVM 21.1.6 256 bits)
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
gpu: lact, nvidia-settings, nvidia-smi wl: wayland-info x11: xprop,xrandr
Device-1: Intel 200 Series PCH HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.17.12-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: off with: 1: pipewire-pulse status: off
2: wireplumber status: off 3: pipewire-alsa type: plugin
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 0cf3:e009
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 104
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.05 TiB used: 279.17 GiB (13.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC43 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 279.17 GiB (30.5%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34
used: 364 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): cpu: 1186 fan-2: 748
Memory: total: 32 GiB note: est. available: 31.14 GiB used: 792.8 MiB (2.5%)
Processes: 209 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB Init: systemd v: 258
Packages: 1499 pm: pacman pkgs: 1479 libs: 384 tools: pamac pm: flatpak
pkgs: 20 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.8
running-in: pty pts/0 inxi: 3.3.40
