i replace a chars to not be detected a “links”
with hybrid driver
~ >>> inxi -G [22]
Device-1: Intel CometLake-H GT2 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: N/A
Display: x11 server: X . org 1 . 20 . 10 driver: loaded: modesetting
unloaded: intel resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4 . 6 Mesa 20 . 3 . 4
~ >>> xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 1 associated providers: 0 name:modesetting
~ >>> head -n999 /etc/X11/xorg . conf . d/* /etc/X11/xorg . conf,
==> /etc/X11/xorg . conf . d/00-keyboard . conf <==
# Written by systemd-localed(8), read by systemd-localed and Xorg . It s
# probably wise not to edit this file manually . Use localectl(1) to
# instruct systemd-localed to update it .
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "fr"
Option "XkbModel" "pc105"
EndSection
==> /etc/X11/xorg . conf . d/90-mhwd . conf <==
## Generated by mhwd - Manjaro Hardware Detection
head: impossible d ouvrir /etc/X11/xorg . conf, en lecture: Aucun fichier ou dossier de ce type
when i run startx on terminal with only video-nvidia i have a error like no scren found .
with video-nvidia driver
~/. ../share/xorg >>> head -n999 /etc/X11/xorg.conf.d/* /etc/X11/xorg.conf [1]
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section InputClass
Identifier system-keyboard
MatchIsKeyboard on
Option XkbLayout fr
Option XkbModel pc105
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf <==
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 460.56
Section ServerLayout
Identifier Layout0
Screen 0 Screen0
InputDevice Keyboard0 CoreKeyboard
InputDevice Mouse0 CorePointer
EndSection
Section Files
EndSection
Section InputDevice
# generated from default
Identifier Mouse0
Driver mouse
Option Protocol auto
Option Device /dev/psaux
Option Emulate3Buttons no
Option ZAxisMapping 4 5
EndSection
Section InputDevice
Identifier Keyboard0
Driver kbd
EndSection
Section Monitor
Identifier Monitor0
VendorName Unknown
ModelName Unknown
Option DPMS
EndSection
Section Device
Identifier Device0
Driver nvidia
VendorName NVIDIA Corporation
Option NoLogo 1
EndSection
Section Screen
Identifier Screen0
Device Device0
Monitor Monitor0
DefaultDepth 24
SubSection Display
Depth 24
EndSubSection
EndSection
Section Extensions
Option COMPOSITE Enable
EndSection
Section InputClass
Identifier Keyboard Defaults
MatchIsKeyboard yes
Option XkbOptions terminate:ctrl_alt_bksp
EndSection
head: impossible d'ouvrir '/etc/X11/xorg.conf' en lecture: Aucun fichier ou dossier de ce type
and the xorg log :
~/ . . . /share/xorg >>> cat Xorg . 0 . log
[ 14 . 384] (--) Log file renamed from "/home/jean-raphael/ . local/share/xorg/Xorg . pid-8718 . log" to "/home/jean-raphael/ . local/share/xorg/Xorg . 0 . log"
[ 14 . 385] (WW) Failed to open protocol names file lib/xorg/protocol . txt
[ 14 . 385]
X . Org X Server 1 . 20 . 10
[ 14 . 385] Build Operating System: Linux Manjaro Linux
[ 14 . 385] Current Operating System: Linux manjaro 5 . 11 . 6-1-MANJARO #1 SMP PREEMPT Thu Mar 11 19:05:51 UTC 2021 x86_64
[ 14 . 385] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5 . 11-x86_64 root=UUID=b8082871-855e-4564-a0f9-9fe6deab7342 rw quiet splash apparmor=1 security=apparmor udev . log_priority=3
[ 14 . 385] Build Date: 16 December 2020 10:33:32PM
[ 14 . 385]
[ 14 . 385] Current version of pixman: 0 . 40 . 0
[ 14 . 385] Before reporting problems, check http:wiki . x . org
to make sure that you have the latest version .
[ 14 . 385] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (//) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown .
[ 14 . 386] (==) Log file: "/home/jean-raphael/ . local/share/xorg/Xorg . 0 . log", Time: Tue Mar 23 00:07:13 2021
[ 14 . 386] (==) Using config directory: "/etc/X11/xorg . conf . d"
[ 14 . 387] (==) Using system config directory "/usr/share/X11/xorg . conf . d"
[ 14 . 390] (==) ServerLayout "layout"
[ 14 . 390] (==) No screen section available . Using defaults .
[ 14 . 390] (**) |-->Screen "Default Screen Section" (0)
[ 14 . 390] (**) | |-->Monitor "<default monitor>"
[ 14 . 390] (==) No monitor specified for screen "Default Screen Section" .
Using a default monitor configuration .
[ 14 . 390] (==) Automatically adding devices
[ 14 . 390] (==) Automatically enabling devices
[ 14 . 390] (==) Automatically adding GPU devices
[ 14 . 390] (==) Automatically binding GPU devices
[ 14 . 390] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 14 . 390] (WW) The directory "/usr/share/fonts/misc" does not exist .
[ 14 . 390] Entry deleted from font path .
[ 14 . 390] (WW) The directory "/usr/share/fonts/OTF" does not exist .
[ 14 . 390] (WW) The directory "/usr/share/fonts/Type1" does not exist .
[ 14 . 390] (WW) The directory "/usr/share/fonts/100dpi" does not exist .
[ 14 . 390] (WW) The directory "/usr/share/fonts/75dpi" does not exist .
[ 14 . 390] (==) FontPath set to:
/usr/share/fonts/TTF
[ 14 . 390] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 14 . 390] (II) The server relies on udev to provide the list of input devices .
If no devices become available, reconfigure udev or disable AutoAddDevices .
[ 14 . 390] (II) Module ABI versions:
[ 14 . 390] X . Org ANSI C Emulation: 0 . 4
[ 14 . 390] X . Org Video Driver: 24 . 1
[ 14 . 390] X . Org XInput driver : 24 . 1
[ 14 . 390] X . Org Server Extension : 10 . 0
[ 14 . 391] (++) using VT number 2
[ 14 . 391] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 14 . 392] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 14 . 392] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 14 . 393] (--) PCI:*(0@0:2:0) 8086:9bc4:1462:12a7 rev 5, Mem @ 0xb0000000/16777216, 0xa0000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 14 . 393] (--) PCI: (1@0:0:0) 10de:2520:1462:12f1 rev 161, Mem @ 0x4200000000/8589934592, 0x4100000000/33554432, I/O @ 0x00005000/128, BIOS @ 0x????????/524288
[ 14 . 393] (WW) Open ACPI failed (/var/run/acpid . socket) (No such file or directory)
[ 14 . 393] (II) LoadModule: "glx"
[ 14 . 394] (II) Loading /usr/lib/xorg/modules/extensions/libglx . so
[ 14 . 397] (II) Module glx: vendor="X . Org Foundation"
[ 14 . 397] compiled for 1 . 20 . 10, module version = 1 . 0 . 0
[ 14 . 397] ABI class: X . Org Server Extension, version 10 . 0
[ 14 . 397] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 14 . 397] loading driver: modesetting
[ 14 . 397] (==) Matched modesetting as autoconfigured driver 0
[ 14 . 397] (==) Matched intel as autoconfigured driver 1
[ 14 . 397] (==) Matched fbdev as autoconfigured driver 2
[ 14 . 397] (==) Matched vesa as autoconfigured driver 3
[ 14 . 397] (==) Assigned the driver to the xf86ConfigLayout
[ 14 . 397] (II) LoadModule: "modesetting"
[ 14 . 398] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv . so
[ 14 . 400] (II) Module modesetting: vendor="X . Org Foundation"
[ 14 . 400] compiled for 1 . 20 . 10, module version = 1 . 20 . 10
[ 14 . 400] Module class: X . Org Video Driver
[ 14 . 400] ABI class: X . Org Video Driver, version 24 . 1
[ 14 . 400] (II) LoadModule: "intel"
[ 14 . 400] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv . so
[ 14 . 403] (II) Module intel: vendor="X . Org Foundation"
[ 14 . 403] compiled for 1 . 20 . 10, module version = 2 . 99 . 917
[ 14 . 403] Module class: X . Org Video Driver
[ 14 . 403] ABI class: X . Org Video Driver, version 24 . 1
[ 14 . 403] (II) LoadModule: "fbdev"
[ 14 . 404] (WW) Warning, couldn t open module fbdev
[ 14 . 404] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 14 . 404] (II) LoadModule: "vesa"
[ 14 . 404] (WW) Warning, couldn t open module vesa
[ 14 . 404] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 14 . 404] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 14 . 404] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 14 . 404] (II) intel: Driver for Intel(R) HD Graphics
[ 14 . 404] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 14 . 404] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 14 . 404] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 14 . 404] (II) modeset(0): using drv /dev/dri/card0
[ 14 . 404] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 14 . 404] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14 . 404] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 14 . 404] (==) modeset(0): RGB weight 888
[ 14 . 404] (==) modeset(0): Default visual is TrueColor
[ 14 . 404] (II) Loading sub module "glamoregl"
[ 14 . 404] (II) LoadModule: "glamoregl"
[ 14 . 404] (II) Loading /usr/lib/xorg/modules/libglamoregl . so
[ 14 . 408] (II) Module glamoregl: vendor="X . Org Foundation"
[ 14 . 408] compiled for 1 . 20 . 10, module version = 1 . 0 . 1
[ 14 . 408] ABI class: X . Org ANSI C Emulation, version 0 . 4
[ 14 . 440] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (CML GT2)
[ 14 . 440] (II) modeset(0): glamor initialized
[ 14 . 441] (II) modeset(0): Output eDP-1 has no monitor section
[ 14 . 443] (II) modeset(0): EDID for output eDP-1
[ 14 . 443] (II) modeset(0): Manufacturer: AUO Model: 978f Serial#: 0
[ 14 . 443] (II) modeset(0): Year: 2020 Week: 3
[ 14 . 443] (II) modeset(0): EDID Version: 1 . 4
[ 14 . 443] (II) modeset(0): Digital Display Input
[ 14 . 443] (II) modeset(0): 8 bits per channel
[ 14 . 443] (II) modeset(0): Digital interface is DisplayPort
[ 14 . 443] (II) modeset(0): Max Image Size [cm]: horiz . : 38 vert . : 22
[ 14 . 443] (II) modeset(0): Gamma: 2 . 20
[ 14 . 443] (II) modeset(0): No DPMS capabilities specified
[ 14 . 443] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 14 . 443] (II) modeset(0): First detailed timing is preferred mode
[ 14 . 443] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 14 . 443] (II) modeset(0): Display is continuous-frequency
[ 14 . 443] (II) modeset(0): redX: 0 . 575 redY: 0 . 347 greenX: 0 . 352 greenY: 0 . 578
[ 14 . 443] (II) modeset(0): blueX: 0 . 161 blueY: 0 . 128 whiteX: 0 . 313 whiteY: 0 . 329
[ 14 . 443] (II) modeset(0): Manufacturer s mask: 0
[ 14 . 443] (II) modeset(0): Supported detailed timing:
[ 14 . 443] (II) modeset(0): clock: 368 . 1 MHz Image Size: 382 x 215 mm
[ 14 . 443] (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2102 h_border: 0
[ 14 . 443] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1095 v_blanking: 1216 v_border: 0
[ 14 . 443] (II) modeset(0): clock: 153 . 4 MHz Image Size: 382 x 215 mm
[ 14 . 443] (II) modeset(0): Ranges: V min: 60 V max: 144 Hz, H min: 176 H max: 176 kHz, PixClock max 375 MHz
[ 14 . 443] (II) modeset(0): B173HAN04 . 9
[ 14 . 443] (II) modeset(0): EDID (in hex):
[ 14 . 443] (II) modeset(0): 00ffffffffffff0006af8f9700000000
[ 14 . 443] (II) modeset(0): 031e0104a526167803707593585a9429
[ 14 . 443] (II) modeset(0): 20505400000001010101010101010101
[ 14 . 443] (II) modeset(0): 010101010101ce8f80b6703888403020
[ 14 . 443] (II) modeset(0): a5007ed710000018ec3b80b670388840
[ 14 . 443] (II) modeset(0): 3020a5007ed710000018000000fd003c
[ 14 . 443] (II) modeset(0): 90b0b025010a202020202020000000fe
[ 14 . 443] (II) modeset(0): 004231373348414e30342e39200a007a
[ 14 . 443] (II) modeset(0): Printing probed modes for output eDP-1
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x144 . 0 368 . 14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175 . 1 kHz eP)
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x60 . 0 356 . 38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x60 . 0 266 . 50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x60 . 0 173 . 00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x60 . 0 153 . 40 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (73 . 0 kHz e)
[ 14 . 443] (II) modeset(0): Modeline "1920x1080"x59 . 9 138 . 50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66 . 6 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1680x1050"x60 . 0 146 . 25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1680x1050"x59 . 9 119 . 00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1400x1050"x74 . 8 155 . 80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1400x1050"x60 . 0 122 . 00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1600x900"x60 . 0 246 . 00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1600x900"x59 . 9 186 . 50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1600x900"x59 . 9 118 . 25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1600x900"x59 . 8 97 . 50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x1024"x85 . 0 157 . 50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x1024"x75 . 0 135 . 00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x1024"x60 . 0 108 . 00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1400x900"x60 . 0 103 . 50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1400x900"x59 . 9 86 . 50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x960"x85 . 0 148 . 50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x960"x60 . 0 108 . 00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1440x810"x60 . 0 198 . 12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1440x810"x60 . 0 151 . 88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1368x768"x59 . 9 85 . 25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1368x768"x59 . 9 72 . 25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x800"x60 . 0 174 . 25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x800"x60 . 0 134 . 25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x800"x59 . 8 83 . 50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x800"x59 . 9 71 . 00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1152x864"x75 . 0 108 . 00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x720"x60 . 0 156 . 12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x720"x60 . 0 120 . 75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x720"x59 . 9 74 . 50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1280x720"x59 . 7 63 . 75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x85 . 0 194 . 02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x75 . 0 170 . 24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x60 . 0 133 . 47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x85 . 0 94 . 50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x75 . 0 78 . 75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x70 . 1 75 . 00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768"x60 . 0 65 . 00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x768i"x87 . 0 44 . 90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x720"x85 . 0 170 . 68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x720"x75 . 0 148 . 50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x720"x60 . 0 117 . 00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "928x696"x75 . 0 144 . 00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "928x696"x60 . 1 109 . 15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "896x672"x75 . 0 130 . 50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "896x672"x60 . 0 102 . 40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x576"x60 . 0 98 . 50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71 . 6 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x576"x60 . 0 78 . 38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x576"x59 . 9 46 . 50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "1024x576"x59 . 8 42 . 00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x600"x59 . 9 96 . 62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74 . 6 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x600"x60 . 0 77 . 00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "832x624"x74 . 6 57 . 28 832 864 928 1152 624 625 628 667 -hsync -vsync (49 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x540"x60 . 0 86 . 50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x540"x60 . 0 69 . 25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66 . 6 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x540"x59 . 6 40 . 75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "960x540"x59 . 8 37 . 25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x85 . 0 114 . 75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x75 . 0 101 . 25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x70 . 0 94 . 50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x65 . 0 87 . 75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x60 . 0 81 . 00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x85 . 1 56 . 30 800 832 896 1048 600 601 604 631 +hsync +vsync (53 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x72 . 2 50 . 00 800 856 976 1040 600 637 643 666 +hsync +vsync (48 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x75 . 0 49 . 50 800 816 896 1056 600 601 604 625 +hsync +vsync (46 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x60 . 3 40 . 00 800 840 968 1056 600 601 605 628 +hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x600"x56 . 2 36 . 00 800 824 896 1024 600 601 603 625 +hsync +vsync (35 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "840x525"x60 . 0 73 . 12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "840x525"x59 . 9 59 . 50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "864x486"x59 . 9 32 . 50 864 888 968 1072 486 489 494 506 -hsync +vsync (30 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "864x486"x59 . 6 30 . 50 864 912 944 1024 486 489 494 500 +hsync -vsync (29 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "700x525"x74 . 8 77 . 90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "700x525"x60 . 0 61 . 00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x450"x59 . 9 59 . 12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "800x450"x59 . 8 48 . 75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x512"x85 . 0 78 . 75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x512"x75 . 0 67 . 50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x512"x60 . 0 54 . 00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "700x450"x60 . 0 51 . 75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "700x450"x59 . 9 43 . 25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x85 . 1 74 . 25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x60 . 0 54 . 00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x85 . 0 36 . 00 640 696 752 832 480 481 484 509 -hsync -vsync (43 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x72 . 8 31 . 50 640 664 704 832 480 489 492 520 -hsync -vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x75 . 0 31 . 50 640 656 720 840 480 481 484 500 -hsync -vsync (37 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x480"x59 . 9 25 . 18 640 656 752 800 480 490 492 525 -hsync -vsync (31 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "720x405"x59 . 5 22 . 50 720 744 808 896 405 408 413 422 -hsync +vsync (25 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "720x405"x59 . 0 21 . 75 720 768 800 880 405 408 413 419 +hsync -vsync (24 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "720x400"x85 . 0 35 . 50 720 756 828 936 400 401 404 446 -hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "684x384"x59 . 9 42 . 62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "684x384"x59 . 9 36 . 12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x400"x59 . 9 41 . 75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x400"x60 . 0 35 . 50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x400"x85 . 1 31 . 50 640 672 736 832 400 401 404 445 -hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "576x432"x75 . 0 54 . 00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x360"x59 . 9 37 . 25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x360"x59 . 8 31 . 88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x360"x59 . 8 18 . 00 640 664 720 800 360 363 368 376 -hsync +vsync (22 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x360"x59 . 3 17 . 75 640 688 720 800 360 363 368 374 +hsync -vsync (22 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "640x350"x85 . 1 31 . 50 640 672 736 832 350 382 385 445 +hsync -vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x384"x85 . 0 47 . 25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x384"x75 . 0 39 . 38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60 . 0 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x384"x70 . 1 37 . 50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x384"x60 . 0 32 . 50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48 . 4 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x384i"x87 . 1 22 . 45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x288"x60 . 0 23 . 25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "512x288"x59 . 9 21 . 00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "416x312"x74 . 7 28 . 64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "480x270"x59 . 6 20 . 38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "480x270"x59 . 8 18 . 62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "400x300"x85 . 3 28 . 15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "400x300"x72 . 2 25 . 00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "400x300"x75 . 1 24 . 75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "400x300"x60 . 3 20 . 00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "400x300"x56 . 3 18 . 00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "432x243"x59 . 9 16 . 25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "432x243"x59 . 6 15 . 25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29 . 8 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x240"x85 . 2 18 . 00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43 . 3 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x240"x72 . 8 15 . 75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x240"x75 . 0 15 . 75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x240"x60 . 1 12 . 59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "360x202"x59 . 5 11 . 25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25 . 1 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "360x202"x59 . 1 10 . 88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24 . 7 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "360x200"x85 . 0 17 . 75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x200"x85 . 3 15 . 75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x180"x59 . 8 9 . 00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22 . 5 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x180"x59 . 3 8 . 88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22 . 2 kHz d)
[ 14 . 443] (II) modeset(0): Modeline "320x175"x85 . 3 15 . 75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37 . 9 kHz d)
[ 14 . 443] (II) modeset(0): Output eDP-1 connected
[ 14 . 443] (II) modeset(0): Using exact sizes for initial modes
[ 14 . 443] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 14 . 443] (==) modeset(0): Using gamma correction (1 . 0, 1 . 0, 1 . 0)
[ 14 . 443] (==) modeset(0): DPI set to (96, 96)
[ 14 . 443] (II) Loading sub module "fb"
[ 14 . 443] (II) LoadModule: "fb"
[ 14 . 443] (II) Loading /usr/lib/xorg/modules/libfb . so
[ 14 . 445] (II) Module fb: vendor="X . Org Foundation"
[ 14 . 445] compiled for 1 . 20 . 10, module version = 1 . 0 . 0
[ 14 . 445] ABI class: X . Org ANSI C Emulation, version 0 . 4
[ 14 . 445] (II) UnloadModule: "intel"
[ 14 . 445] (II) Unloading intel
[ 14 . 459] (==) modeset(0): Backing store enabled
[ 14 . 459] (==) modeset(0): Silken mouse disabled
[ 14 . 494] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc .
[ 14 . 494] (==) modeset(0): DPMS enabled
[ 14 . 494] (II) modeset(0): [DRI2] Setup complete
[ 14 . 494] (II) modeset(0): [DRI2] DRI driver: iris
[ 14 . 494] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 14 . 494] (II) Initializing extension Generic Event Extension
[ 14 . 494] (II) Initializing extension SHAPE
[ 14 . 494] (II) Initializing extension MIT-SHM
[ 14 . 494] (II) Initializing extension XInputExtension
[ 14 . 494] (II) Initializing extension XTEST
[ 14 . 494] (II) Initializing extension BIG-REQUESTS
[ 14 . 494] (II) Initializing extension SYNC
[ 14 . 494] (II) Initializing extension XKEYBOARD
[ 14 . 494] (II) Initializing extension XC-MISC
[ 14 . 494] (II) Initializing extension SECURITY
[ 14 . 494] (II) Initializing extension XFIXES
[ 14 . 494] (II) Initializing extension RENDER
[ 14 . 494] (II) Initializing extension RANDR
[ 14 . 494] (II) Initializing extension COMPOSITE
[ 14 . 494] (II) Initializing extension DAMAGE
[ 14 . 494] (II) Initializing extension MIT-SCREEN-SAVER
[ 14 . 494] (II) Initializing extension DOUBLE-BUFFER
[ 14 . 494] (II) Initializing extension RECORD
[ 14 . 494] (II) Initializing extension DPMS
[ 14 . 494] (II) Initializing extension Present
[ 14 . 494] (II) Initializing extension DRI3
[ 14 . 494] (II) Initializing extension X-Resource
[ 14 . 494] (II) Initializing extension XVideo
[ 14 . 494] (II) Initializing extension XVideo-MotionCompensation
[ 14 . 494] (II) Initializing extension GLX
[ 14 . 499] (II) AIGLX: Loaded and initialized iris
[ 14 . 499] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 14 . 499] (II) Initializing extension XFree86-VidModeExtension
[ 14 . 499] (II) Initializing extension XFree86-DGA
[ 14 . 499] (II) Initializing extension XFree86-DRI
[ 14 . 499] (II) Initializing extension DRI2
[ 14 . 500] (II) modeset(0): Damage tracking initialized
[ 14 . 500] (II) modeset(0): Setting screen physical size to 508 x 285
[ 14 . 524] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 14 . 524] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14 . 524] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14 . 524] (**) Power Button: Applying InputClass "system-keyboard"
[ 14 . 524] (II) LoadModule: "libinput"
[ 14 . 524] (II) Loading /usr/lib/xorg/modules/input/libinput_drv . so
[ 14 . 525] (II) Module libinput: vendor="X . Org Foundation"
[ 14 . 525] compiled for 1 . 20 . 8, module version = 0 . 30 . 0
[ 14 . 525] Module class: X . Org XInput Driver
[ 14 . 525] ABI class: X . Org XInput driver, version 24 . 1
[ 14 . 525] (II) Using input driver libinput for Power Button
[ 14 . 526] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 20 paused 0
[ 14 . 526] (**) Power Button: always reports core events
[ 14 . 526] (**) Option "Device" "/dev/input/event3"
[ 14 . 526] (**) Option "_source" "server/udev"
[ 14 . 527] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 14 . 527] (II) event3 - Power Button: device is a keyboard
[ 14 . 527] (II) event3 - Power Button: device removed
[ 14 . 527] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 14 . 527] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 14 . 527] (**) Option "xkb_model" "pc105"
[ 14 . 527] (**) Option "xkb_layout" "fr"
[ 14 . 538] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 14 . 538] (II) event3 - Power Button: device is a keyboard
[ 14 . 539] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 14 . 539] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 14 . 539] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 14 . 539] (**) Video Bus: Applying InputClass "system-keyboard"
[ 14 . 539] (II) Using input driver libinput for Video Bus
[ 14 . 539] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 23 paused 0
[ 14 . 539] (**) Video Bus: always reports core events
[ 14 . 539] (**) Option "Device" "/dev/input/event8"
[ 14 . 539] (**) Option "_source" "server/udev"
[ 14 . 540] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 14 . 540] (II) event8 - Video Bus: device is a keyboard
[ 14 . 540] (II) event8 - Video Bus: device removed
[ 14 . 540] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11/event8"
[ 14 . 540] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 14 . 540] (**) Option "xkb_model" "pc105"
[ 14 . 540] (**) Option "xkb_layout" "fr"
[ 14 . 541] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 14 . 541] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 14 . 541] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 14 . 541] (**) Video Bus: Applying InputClass "system-keyboard"
[ 14 . 541] (II) Using input driver libinput for Video Bus
[ 14 . 541] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 24 paused 0
[ 14 . 541] (**) Video Bus: always reports core events
[ 14 . 541] (**) Option "Device" "/dev/input/event9"
[ 14 . 541] (**) Option "_source" "server/udev"
[ 14 . 542] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 14 . 542] (II) event9 - Video Bus: device is a keyboard
[ 14 . 542] (II) event9 - Video Bus: device removed
[ 14 . 542] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input12/event9"
[ 14 . 542] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 14 . 542] (**) Option "xkb_model" "pc105"
[ 14 . 542] (**) Option "xkb_layout" "fr"
[ 14 . 543] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 14 . 543] (II) No input driver specified, ignoring this device .
[ 14 . 543] (II) This device may have been added with another device file .
[ 14 . 543] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 14 . 543] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 14 . 543] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 14 . 543] (**) Power Button: Applying InputClass "system-keyboard"
[ 14 . 543] (II) Using input driver libinput for Power Button
[ 14 . 543] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 25 paused 0
[ 14 . 543] (**) Power Button: always reports core events
[ 14 . 543] (**) Option "Device" "/dev/input/event2"
[ 14 . 543] (**) Option "_source" "server/udev"
[ 14 . 544] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14 . 544] (II) event2 - Power Button: device is a keyboard
[ 14 . 544] (II) event2 - Power Button: device removed
[ 14 . 544] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 14 . 544] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 14 . 544] (**) Option "xkb_model" "pc105"
[ 14 . 544] (**) Option "xkb_layout" "fr"
[ 14 . 545] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 14 . 545] (II) event2 - Power Button: device is a keyboard
[ 14 . 545] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 14 . 545] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 14 . 545] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 14 . 545] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 14 . 545] (II) Using input driver libinput for Sleep Button
[ 14 . 545] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 26 paused 0
[ 14 . 545] (**) Sleep Button: always reports core events
[ 14 . 545] (**) Option "Device" "/dev/input/event1"
[ 14 . 545] (**) Option "_source" "server/udev"
[ 14 . 546] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 14 . 546] (II) event1 - Sleep Button: device is a keyboard
[ 14 . 546] (II) event1 - Sleep Button: device removed
[ 14 . 546] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 14 . 546] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 14 . 546] (**) Option "xkb_model" "pc105"
[ 14 . 546] (**) Option "xkb_layout" "fr"
[ 14 . 547] (II) config/udev: Adding input device Compx 2 . 4G Receiver (/dev/input/event20)
[ 14 . 547] (**) Compx 2 . 4G Receiver: Applying InputClass "evdev keyboard catchall"
[ 14 . 547] (**) Compx 2 . 4G Receiver: Applying InputClass "libinput keyboard catchall"
[ 14 . 547] (**) Compx 2 . 4G Receiver: Applying InputClass "system-keyboard"
[ 14 . 547] (II) Using input driver libinput for Compx 2 . 4G Receiver
[ 14 . 547] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 27 paused 0
[ 14 . 547] (**) Compx 2 . 4G Receiver: always reports core events
[ 14 . 547] (**) Option "Device" "/dev/input/event20"
[ 14 . 547] (**) Option "_source" "server/udev"
[ 14 . 548] (II) event20 - Compx 2 . 4G Receiver: is tagged by udev as: Keyboard
[ 14 . 548] (II) event20 - Compx 2 . 4G Receiver: device is a keyboard
[ 14 . 548] (II) event20 - Compx 2 . 4G Receiver: device removed
[ 14 . 548] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-3/1-3:1 . 0/0003:25A7:FA61 . 0002/input/input25/event20"
[ 14 . 548] (II) XINPUT: Adding extended input device "Compx 2 . 4G Receiver" (type: KEYBOARD, id 11)
[ 14 . 548] (**) Option "xkb_model" "pc105"
[ 14 . 548] (**) Option "xkb_layout" "fr"
[ 14 . 549] (II) event20 - Compx 2 . 4G Receiver: is tagged by udev as: Keyboard
[ 14 . 549] (II) event20 - Compx 2 . 4G Receiver: device is a keyboard
[ 14 . 549] (II) config/udev: Adding input device Compx 2 . 4G Receiver Mouse (/dev/input/event21)
[ 14 . 549] (**) Compx 2 . 4G Receiver Mouse: Applying InputClass "evdev pointer catchall"
[ 14 . 549] (**) Compx 2 . 4G Receiver Mouse: Applying InputClass "libinput pointer catchall"
[ 14 . 549] (II) Using input driver libinput for Compx 2 . 4G Receiver Mouse
[ 14 . 550] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 28 paused 0
[ 14 . 550] (**) Compx 2 . 4G Receiver Mouse: always reports core events
[ 14 . 550] (**) Option "Device" "/dev/input/event21"
[ 14 . 550] (**) Option "_source" "server/udev"
[ 14 . 550] (II) event21 - Compx 2 . 4G Receiver Mouse: is tagged by udev as: Mouse
[ 14 . 550] (II) event21 - Compx 2 . 4G Receiver Mouse: device is a pointer
[ 14 . 551] (II) event21 - Compx 2 . 4G Receiver Mouse: device removed
[ 14 . 551] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-3/1-3:1 . 1/0003:25A7:FA61 . 0003/input/input26/event21"
[ 14 . 551] (II) XINPUT: Adding extended input device "Compx 2 . 4G Receiver Mouse" (type: MOUSE, id 12)
[ 14 . 551] (**) Option "AccelerationScheme" "none"
[ 14 . 551] (**) Compx 2 . 4G Receiver Mouse: (accel) selected scheme none/0
[ 14 . 551] (**) Compx 2 . 4G Receiver Mouse: (accel) acceleration factor: 2 . 000
[ 14 . 551] (**) Compx 2 . 4G Receiver Mouse: (accel) acceleration threshold: 4
[ 14 . 551] (II) event21 - Compx 2 . 4G Receiver Mouse: is tagged by udev as: Mouse
[ 14 . 551] (II) event21 - Compx 2 . 4G Receiver Mouse: device is a pointer
[ 14 . 552] (II) config/udev: Adding input device Compx 2 . 4G Receiver Mouse (/dev/input/mouse3)
[ 14 . 552] (II) No input driver specified, ignoring this device .
[ 14 . 552] (II) This device may have been added with another device file .
[ 14 . 552] (II) config/udev: Adding input device Compx 2 . 4G Receiver (/dev/input/event22)
[ 14 . 553] (II) config/udev: Adding input device Compx 2 . 4G Receiver Consumer Control (/dev/input/event23)
[ 14 . 553] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 14 . 553] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 14 . 553] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 14 . 553] (II) Using input driver libinput for Compx 2 . 4G Receiver Consumer Control
[ 14 . 553] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 29 paused 0
[ 14 . 553] (**) Compx 2 . 4G Receiver Consumer Control: always reports core events
[ 14 . 553] (**) Option "Device" "/dev/input/event23"
[ 14 . 553] (**) Option "_source" "server/udev"
[ 14 . 554] (II) event23 - Compx 2 . 4G Receiver Consumer Control: is tagged by udev as: Keyboard
[ 14 . 554] (II) event23 - Compx 2 . 4G Receiver Consumer Control: device is a keyboard
[ 14 . 554] (II) event23 - Compx 2 . 4G Receiver Consumer Control: device removed
[ 14 . 554] (II) libinput: Compx 2 . 4G Receiver Consumer Control: needs a virtual subdevice
[ 14 . 554] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-3/1-3:1 . 1/0003:25A7:FA61 . 0003/input/input28/event23"
[ 14 . 554] (II) XINPUT: Adding extended input device "Compx 2 . 4G Receiver Consumer Control" (type: MOUSE, id 13)
[ 14 . 554] (**) Option "AccelerationScheme" "none"
[ 14 . 554] (**) Compx 2 . 4G Receiver Consumer Control: (accel) selected scheme none/0
[ 14 . 554] (**) Compx 2 . 4G Receiver Consumer Control: (accel) acceleration factor: 2 . 000
[ 14 . 554] (**) Compx 2 . 4G Receiver Consumer Control: (accel) acceleration threshold: 4
[ 14 . 555] (II) event23 - Compx 2 . 4G Receiver Consumer Control: is tagged by udev as: Keyboard
[ 14 . 555] (II) event23 - Compx 2 . 4G Receiver Consumer Control: device is a keyboard
[ 14 . 555] (II) config/udev: Adding input device Compx 2 . 4G Receiver System Control (/dev/input/event24)
[ 14 . 555] (**) Compx 2 . 4G Receiver System Control: Applying InputClass "evdev keyboard catchall"
[ 14 . 555] (**) Compx 2 . 4G Receiver System Control: Applying InputClass "libinput keyboard catchall"
[ 14 . 555] (**) Compx 2 . 4G Receiver System Control: Applying InputClass "system-keyboard"
[ 14 . 555] (II) Using input driver libinput for Compx 2 . 4G Receiver System Control
[ 14 . 555] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 30 paused 0
[ 14 . 555] (**) Compx 2 . 4G Receiver System Control: always reports core events
[ 14 . 555] (**) Option "Device" "/dev/input/event24"
[ 14 . 555] (**) Option "_source" "server/udev"
[ 14 . 556] (II) event24 - Compx 2 . 4G Receiver System Control: is tagged by udev as: Keyboard
[ 14 . 556] (II) event24 - Compx 2 . 4G Receiver System Control: device is a keyboard
[ 14 . 556] (II) event24 - Compx 2 . 4G Receiver System Control: device removed
[ 14 . 556] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-3/1-3:1 . 1/0003:25A7:FA61 . 0003/input/input29/event24"
[ 14 . 556] (II) XINPUT: Adding extended input device "Compx 2 . 4G Receiver System Control" (type: KEYBOARD, id 14)
[ 14 . 556] (**) Option "xkb_model" "pc105"
[ 14 . 556] (**) Option "xkb_layout" "fr"
[ 14 . 557] (II) event24 - Compx 2 . 4G Receiver System Control: is tagged by udev as: Keyboard
[ 14 . 557] (II) event24 - Compx 2 . 4G Receiver System Control: device is a keyboard
[ 14 . 557] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/event26)
[ 14 . 557] (II) No input driver specified, ignoring this device .
[ 14 . 557] (II) This device may have been added with another device file .
[ 14 . 558] (II) config/udev: Adding input device Microsoft X-Box 360 pad (/dev/input/js0)
[ 14 . 558] (II) No input driver specified, ignoring this device .
[ 14 . 558] (II) This device may have been added with another device file .
[ 14 . 558] (II) config/udev: Adding input device SteelSeries SteelSeries KLC (/dev/input/event25)
[ 14 . 558] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 14 . 558] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 14 . 558] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 14 . 558] (II) Using input driver libinput for SteelSeries SteelSeries KLC
[ 14 . 559] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 31 paused 0
[ 14 . 559] (**) SteelSeries SteelSeries KLC: always reports core events
[ 14 . 559] (**) Option "Device" "/dev/input/event25"
[ 14 . 559] (**) Option "_source" "server/udev"
[ 14 . 559] (II) event25 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 14 . 559] (II) event25 - SteelSeries SteelSeries KLC: device is a keyboard
[ 14 . 559] (II) event25 - SteelSeries SteelSeries KLC: device removed
[ 14 . 559] (II) libinput: SteelSeries SteelSeries KLC: needs a virtual subdevice
[ 14 . 559] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-7/1-7:1 . 1/0003:1038:1122 . 0005/input/input31/event25"
[ 14 . 559] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: MOUSE, id 15)
[ 14 . 559] (**) Option "AccelerationScheme" "none"
[ 14 . 559] (**) SteelSeries SteelSeries KLC: (accel) selected scheme none/0
[ 14 . 559] (**) SteelSeries SteelSeries KLC: (accel) acceleration factor: 2 . 000
[ 14 . 559] (**) SteelSeries SteelSeries KLC: (accel) acceleration threshold: 4
[ 14 . 560] (II) event25 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 14 . 560] (II) event25 - SteelSeries SteelSeries KLC: device is a keyboard
[ 14 . 560] (II) config/udev: Adding input device CUST0001:00 04F3:30AA Mouse (/dev/input/event6)
[ 14 . 561] (**) CUST0001:00 04F3:30AA Mouse: Applying InputClass "evdev pointer catchall"
[ 14 . 561] (**) CUST0001:00 04F3:30AA Mouse: Applying InputClass "libinput pointer catchall"
[ 14 . 561] (II) Using input driver libinput for CUST0001:00 04F3:30AA Mouse
[ 14 . 561] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 32 paused 0
[ 14 . 561] (**) CUST0001:00 04F3:30AA Mouse: always reports core events
[ 14 . 561] (**) Option "Device" "/dev/input/event6"
[ 14 . 561] (**) Option "_source" "server/udev"
[ 14 . 561] (II) event6 - CUST0001:00 04F3:30AA Mouse: is tagged by udev as: Mouse Pointingstick
[ 14 . 562] (II) event6 - CUST0001:00 04F3:30AA Mouse: device is a pointer
[ 14 . 562] (II) event6 - CUST0001:00 04F3:30AA Mouse: device removed
[ 14 . 562] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15 . 2/i2c_designware . 1/i2c-1/i2c-CUST0001:00/0018:04F3:30AA . 0001/input/input15/event6"
[ 14 . 562] (II) XINPUT: Adding extended input device "CUST0001:00 04F3:30AA Mouse" (type: MOUSE, id 16)
[ 14 . 562] (**) Option "AccelerationScheme" "none"
[ 14 . 562] (**) CUST0001:00 04F3:30AA Mouse: (accel) selected scheme none/0
[ 14 . 562] (**) CUST0001:00 04F3:30AA Mouse: (accel) acceleration factor: 2 . 000
[ 14 . 562] (**) CUST0001:00 04F3:30AA Mouse: (accel) acceleration threshold: 4
[ 14 . 563] (II) event6 - CUST0001:00 04F3:30AA Mouse: is tagged by udev as: Mouse Pointingstick
[ 14 . 563] (II) event6 - CUST0001:00 04F3:30AA Mouse: device is a pointer
[ 14 . 564] (II) config/udev: Adding input device CUST0001:00 04F3:30AA Mouse (/dev/input/mouse0)
[ 14 . 564] (II) No input driver specified, ignoring this device .
[ 14 . 564] (II) This device may have been added with another device file .
[ 14 . 564] (II) config/udev: Adding input device CUST0001:00 04F3:30AA Touchpad (/dev/input/event7)
[ 14 . 564] (**) CUST0001:00 04F3:30AA Touchpad: Applying InputClass "evdev touchpad catchall"
[ 14 . 564] (**) CUST0001:00 04F3:30AA Touchpad: Applying InputClass "libinput touchpad catchall"
[ 14 . 564] (II) Using input driver libinput for CUST0001:00 04F3:30AA Touchpad
[ 14 . 565] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 33 paused 0
[ 14 . 565] (**) CUST0001:00 04F3:30AA Touchpad: always reports core events
[ 14 . 565] (**) Option "Device" "/dev/input/event7"
[ 14 . 565] (**) Option "_source" "server/udev"
[ 14 . 566] (II) event7 - CUST0001:00 04F3:30AA Touchpad: is tagged by udev as: Touchpad
[ 14 . 567] (II) event7 - CUST0001:00 04F3:30AA Touchpad: device is a touchpad
[ 14 . 567] (II) event7 - CUST0001:00 04F3:30AA Touchpad: device removed
[ 14 . 567] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15 . 2/i2c_designware . 1/i2c-1/i2c-CUST0001:00/0018:04F3:30AA . 0001/input/input17/event7"
[ 14 . 567] (II) XINPUT: Adding extended input device "CUST0001:00 04F3:30AA Touchpad" (type: TOUCHPAD, id 17)
[ 14 . 568] (**) Option "AccelerationScheme" "none"
[ 14 . 568] (**) CUST0001:00 04F3:30AA Touchpad: (accel) selected scheme none/0
[ 14 . 568] (**) CUST0001:00 04F3:30AA Touchpad: (accel) acceleration factor: 2 . 000
[ 14 . 568] (**) CUST0001:00 04F3:30AA Touchpad: (accel) acceleration threshold: 4
[ 14 . 568] (II) event7 - CUST0001:00 04F3:30AA Touchpad: is tagged by udev as: Touchpad
[ 14 . 569] (II) event7 - CUST0001:00 04F3:30AA Touchpad: device is a touchpad
[ 14 . 570] (II) config/udev: Adding input device CUST0001:00 04F3:30AA Touchpad (/dev/input/mouse1)
[ 14 . 570] (II) No input driver specified, ignoring this device .
[ 14 . 570] (II) This device may have been added with another device file .
[ 14 . 570] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 14 . 570] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[ 14 . 571] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event15)
[ 14 . 571] (II) No input driver specified, ignoring this device .
[ 14 . 571] (II) This device may have been added with another device file .
[ 14 . 571] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event16)
[ 14 . 571] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event17)
[ 14 . 571] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event18)
[ 14 . 571] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event19)
[ 14 . 572] (II) config/udev: Adding input device gpio-keys (/dev/input/event10)
[ 14 . 572] (II) No input driver specified, ignoring this device .
[ 14 . 572] (II) This device may have been added with another device file .
[ 14 . 572] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 14 . 572] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 14 . 572] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 14 . 572] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 14 . 572] (II) Using input driver libinput for AT Translated Set 2 keyboard
[ 14 . 572] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 34 paused 0
[ 14 . 572] (**) AT Translated Set 2 keyboard: always reports core events
[ 14 . 572] (**) Option "Device" "/dev/input/event4"
[ 14 . 572] (**) Option "_source" "server/udev"
[ 14 . 573] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14 . 573] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 14 . 573] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 14 . 573] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 14 . 573] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[ 14 . 573] (**) Option "xkb_model" "pc105"
[ 14 . 573] (**) Option "xkb_layout" "fr"
[ 14 . 574] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 14 . 574] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 14 . 575] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event12)
[ 14 . 575] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 14 . 575] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 14 . 575] (II) Using input driver libinput for ETPS/2 Elantech Touchpad
[ 14 . 575] (II) systemd-logind: got fd for /dev/input/event12 13:76 fd 35 paused 0
[ 14 . 575] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 14 . 575] (**) Option "Device" "/dev/input/event12"
[ 14 . 575] (**) Option "_source" "server/udev"
[ 14 . 576] (II) event12 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14 . 576] (II) event12 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14 . 576] (II) event12 - ETPS/2 Elantech Touchpad: device removed
[ 14 . 577] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event12"
[ 14 . 577] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 19)
[ 14 . 577] (**) Option "AccelerationScheme" "none"
[ 14 . 577] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 14 . 577] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2 . 000
[ 14 . 577] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 14 . 578] (II) event12 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 14 . 578] (II) event12 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 14 . 579] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse2)
[ 14 . 579] (II) No input driver specified, ignoring this device .
[ 14 . 579] (II) This device may have been added with another device file .
[ 14 . 579] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 14 . 579] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event11)
[ 14 . 579] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 14 . 579] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 14 . 579] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[ 14 . 579] (II) Using input driver libinput for MSI WMI hotkeys
[ 14 . 580] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 36 paused 0
[ 14 . 580] (**) MSI WMI hotkeys: always reports core events
[ 14 . 580] (**) Option "Device" "/dev/input/event11"
[ 14 . 580] (**) Option "_source" "server/udev"
[ 14 . 580] (II) event11 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 14 . 580] (II) event11 - MSI WMI hotkeys: device is a keyboard
[ 14 . 580] (II) event11 - MSI WMI hotkeys: device removed
[ 14 . 580] (**) Option "config_info" "udev:/sys/devices/virtual/input/input14/event11"
[ 14 . 580] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 20)
[ 14 . 580] (**) Option "xkb_model" "pc105"
[ 14 . 580] (**) Option "xkb_layout" "fr"
[ 14 . 581] (II) event11 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 14 . 581] (II) event11 - MSI WMI hotkeys: device is a keyboard
[ 14 . 584] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 14 . 584] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 14 . 584] (**) Compx 2 . 4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[ 14 . 584] (II) Using input driver libinput for Compx 2 . 4G Receiver Consumer Control
[ 14 . 584] (II) systemd-logind: returning pre-existing fd for /dev/input/event23 13:87
[ 14 . 584] (**) Compx 2 . 4G Receiver Consumer Control: always reports core events
[ 14 . 584] (**) Option "Device" "/dev/input/event23"
[ 14 . 584] (**) Option "_source" "_driver/libinput"
[ 14 . 584] (II) libinput: Compx 2 . 4G Receiver Consumer Control: is a virtual subdevice
[ 14 . 584] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-3/1-3:1 . 1/0003:25A7:FA61 . 0003/input/input28/event23"
[ 14 . 584] (II) XINPUT: Adding extended input device "Compx 2 . 4G Receiver Consumer Control" (type: KEYBOARD, id 21)
[ 14 . 584] (**) Option "xkb_model" "pc105"
[ 14 . 584] (**) Option "xkb_layout" "fr"
[ 14 . 584] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 14 . 584] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 14 . 584] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 14 . 584] (II) Using input driver libinput for SteelSeries SteelSeries KLC
[ 14 . 584] (II) systemd-logind: returning pre-existing fd for /dev/input/event25 13:89
[ 14 . 585] (**) SteelSeries SteelSeries KLC: always reports core events
[ 14 . 585] (**) Option "Device" "/dev/input/event25"
[ 14 . 585] (**) Option "_source" "_driver/libinput"
[ 14 . 585] (II) libinput: SteelSeries SteelSeries KLC: is a virtual subdevice
[ 14 . 585] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14 . 0/usb1/1-7/1-7:1 . 1/0003:1038:1122 . 0005/input/input31/event25"
[ 14 . 585] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: KEYBOARD, id 22)
[ 14 . 585] (**) Option "xkb_model" "pc105"
[ 14 . 585] (**) Option "xkb_layout" "fr"
[ 14 . 888] (II) modeset(0): EDID vendor "AUO", prod id 38799
[ 14 . 888] (II) modeset(0): Using EDID range info for horizontal sync
[ 14 . 888] (II) modeset(0): Using EDID range info for vertical refresh
[ 14 . 888] (II) modeset(0): Printing DDC gathered Modelines:
[ 14 . 888] (II) modeset(0): Modeline "1920x1080"x0 . 0 368 . 14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175 . 1 kHz eP)
[ 14 . 888] (II) modeset(0): Modeline "1920x1080"x0 . 0 153 . 40 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (73 . 0 kHz e)
[ 74 . 331] (II) modeset(0): EDID vendor "AUO", prod id 38799
[ 74 . 331] (II) modeset(0): Using hsync ranges from config file
[ 74 . 331] (II) modeset(0): Using vrefresh ranges from config file
[ 74 . 331] (II) modeset(0): Printing DDC gathered Modelines:
[ 74 . 331] (II) modeset(0): Modeline "1920x1080"x0 . 0 368 . 14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175 . 1 kHz eP)
[ 74 . 331] (II) modeset(0): Modeline "1920x1080"x0 . 0 153 . 40 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (73 . 0 kHz e)
[ 74 . 332] (II) modeset(0): EDID vendor "AUO", prod id 38799
[ 74 . 332] (II) modeset(0): Using hsync ranges from config file
[ 74 . 332] (II) modeset(0): Using vrefresh ranges from config file
[ 74 . 332] (II) modeset(0): Printing DDC gathered Modelines:
[ 74 . 332] (II) modeset(0): Modeline "1920x1080"x0 . 0 368 . 14 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (175 . 1 kHz eP)
[ 74 . 332] (II) modeset(0): Modeline "1920x1080"x0 . 0 153 . 40 1920 1968 2000 2102 1080 1090 1095 1216 -hsync -vsync (73 . 0 kHz e)
