For some time now my NVIDIA driver is not used anymore, thus no hardware acceleration. I hope you could help me getting the NVIDIA graphics card running again.
I’m running kernel 5.10 (although I tried with 5.9 and an old 5.4 as well with the same results):
[user@host ~]$ uname -r 5.10.2-2-MANJARO
I have an on-board Intel card, but I intend to only use the NVIDIA GPU. lspci only lists the NVIDIA card anyway:
[user@host ~]$ sudo lspci | grep -i vga 01:00.0 VGA compatible controller: NVIDIA Corporation GP107 [GeForce GTX 1050] (rev a1)
The video-nvidia driver is installed via mhwd:
[user@host ~]$ sudo mhwd -li > Installed PCI configs: -------------------------------------------------------------------------------- NAME VERSION FREEDRIVER TYPE -------------------------------------------------------------------------------- video-nvidia 2020.11.30 false PCI Warning: No installed USB configs!
The following related packages are installed:
[user@host ~]$ pacman -Qs 'nvidia' | grep '^[^ ]' local/bumblebee 3.2.1-22 local/egl-wayland 1.1.6-1 local/lib32-libvdpau 1.4-1 local/lib32-nvidia-utils 455.45.01-3 local/lib32-opencl-nvidia 455.45.01-3 local/libvdpau 1.4-1 local/linux-latest-nvidia 5.10-1 (linux-latest-extramodules) local/linux510-nvidia 455.45.01-10.0 (linux510-extramodules) local/linux54-nvidia 455.45.01-6 (linux54-extramodules) local/linux59-nvidia 455.45.01-6 (linux59-extramodules) local/mhwd-nvidia 455.45.01-3 local/mhwd-nvidia-340xx 340.108-1 local/mhwd-nvidia-390xx 390.138-1 local/nvidia-utils 455.45.01-2 local/opencl-nvidia 455.45.01-2
And the corresponding kernel module seems to be loaded:
[user@host ~]$ sudo dmesg | grep -i nvidia [ 3.983095] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5 [ 3.983211] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6 [ 3.983312] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7 [ 3.983418] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8 [ 3.983519] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9 [ 3.983616] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10 [ 5.387167] nvidia: loading out-of-tree module taints kernel. [ 5.387175] nvidia: module license 'NVIDIA' taints kernel. [ 5.393123] nvidia: module verification failed: signature and/or required key missing - tainting kernel [ 5.405536] nvidia-nvlink: Nvlink Core is being initialized, major device number 236 [ 5.405915] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem [ 5.522505] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020 [ 6.203500] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 455.45.01 Thu Nov 5 22:55:44 UTC 2020
Yet a warning regarding missing hardware acceleration is displayed after login. glxinfo reports accordingly:
[user@host ~]$ glxinfo | grep -i vendor server glx vendor string: SGI client glx vendor string: Mesa Project and SGI Vendor: Mesa/X.org (0xffffffff) OpenGL vendor string: Mesa/X.org
What could I do to get the NVIDIA card running?
Thanks for your help.
