No, I originally had it all set to auto. What’s annoying is the manufacturer does in fact say it supports the refresh rate, but it doesn’t say specifically which resolutions these rates apply too, I noticed the lower ones had 75Hz appear for them.
what is output of command xrandr?
PS: I don’t see manufacturer claims about the 75Hz refresh rate.
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DP-2.8 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 476mm x 268mm
1920x1080 60.00*+ 59.94 50.00
1680x1050 59.95
1600x1200 60.00
1600x900 60.00
1440x900 59.89
1440x576 50.00
1400x1050 59.98
1280x1024 75.02 60.02
1280x960 60.00
1280x720 60.00 59.94 50.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
Oh! What’s even stranger I noticed, when I go into the monitor’s panel settings, and I get the information for it; I see that the horizontal refresh rate is 67.7Hz and the vertical one is 60Hz
So nope, no 75Hz for that resolution. 60Hz at this resolution is the proper and selected current mode it’s how it should be (see the * and + signs).
//EDIT: don’t start bothering with the horizontal and vertical refresh rate this is out of the scope of this question.
Awh alright, thanks for the info. I’m still working on restoring my computer’s information and so far, the changes seem to have made the gpu alot more stable (but I’ve yet to test Vivaldi and Youtube). WIll update when the computer finally finishes restoring
I have unfortunate news, the issue is still occurring even with the changes suggested made. It seems to happen whenever I have a YouTube video playing in my browser (Vivaldi). I’m not real sure what to do now
This may be because your browser works on the CPU and not the GPU and it may struggle to properly play medias.
Look for Vivaldi hardware acceleration and see if you can configure it properly for that.
I’d start with another browser first, e.g. Firefox or Chrome.
I can turn it on and off, but I did go and turn it off and the issue still occurs
Happened on FireFox too
