Nvidia driver 390 error
I need help when I click the “install proprietary drivers” button, the intel nvidia driver is installed and only the Intel graphics on bumblebee are used. When I try to remove it and install the driver for nvidia “nvidia 390”, I reboot and the system does not turn on.
using inxi in a terminal or in console
Kernel: 6.6.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=c73bb738-2123-4465-bdfe-dc489caff8e3 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
  Type: Laptop System: Packard Bell product: EasyNote TS44HR v: V1.12
    serial: <filter> Chassis: type: 10 v: 1.12 serial: N/A
  Mobo: Packard Bell model: SJV50_HR serial: N/A BIOS: Packard Bell v: 1.12
    date: 07/11/2011
  ID-1: BAT0 charge: 34.5 Wh (100.0%) condition: 34.5/47.5 Wh (72.7%)
    volts: 12.2 min: 10.8 model: SANYO Li_Ion_4000mA type: Li-ion
    serial: <filter> status: full
  System RAM: total: 4 GiB available: 3.68 GiB used: 1.71 GiB (46.3%)
    igpu: 128 MiB
  Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
    max-module-size: 8 GiB
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 info: single-bank type: DDR3 detail: synchronous
    size: 4 GiB speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: N/A part-no: RMT3160ED58E9W1600 serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i3-2310M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1124 high: 2100 min/max: 800/2100 base/boost: 2100/4000
    scaling: driver: intel_cpufreq governor: schedutil volts: 0.0 V
    ext-clock: 1333 MHz cores: 1: 800 2: 2100 3: 798 4: 798 bogomips: 16768
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
    mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-6
    code: Sandybridge process: Intel 32nm built: 2011 ports: active: LVDS-1
    empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
    class-ID: 0300
  Device-2: NVIDIA GF119M [GeForce GT 520M] vendor: Acer Incorporated ALI
    driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: series: 390.xx+
    status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
    xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
    speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1050 class-ID: 0300
  Device-3: Chicony 1.3M HD WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:3 chip-ID: 04f2:b23d
    class-ID: 0e02
  Display: server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: LG Display 0x02e3 built: 2010 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
    inactive: gbm,wayland
  API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
    device-ID: 8086:0116 memory: 1.46 GiB unified: yes
    vendor: Acer Incorporated ALI 6 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF119 HDMI Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
    gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:0e08 class-ID: 0403
  API: ALSA v: k6.6.8-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: n/a (root, process) with:
  Device-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
    vendor: Acer Incorporated ALI driver: tg3 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14e4:16b5
    class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Broadcom BCM43225 802.11b/g/n driver: wl v: kernel modules: bcma
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4357
    class-ID: 0280
  Local Storage: total: 1.13 TiB used: 7.82 GiB (0.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: AMD Radeon model: R5SL240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0A0 temp: 54 C
    scheme: MBR
  SMART: yes state: enabled health: PASSED on: 293d 10h cycles: 2152
    read: 840.8 MiB written: 420.6 MiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST1000LM025 HN-M101ABB
    family: Seagate SpinPoint M8U (USB) size: 931.51 GiB block-size:
    physical: 4096 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1
    mode: 2.0 sata: 3.0 speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1301 drive-rev: 2BA30002 temp: 32 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 82 hrs cycles: 156
  Optical-1: /dev/sr0 vendor: PIONEER model: DVD-RW DVRTD11RS rev: 1.01
    dev-links: cdrom
  ID-1: / raw-size: 55.89 GiB size: 54.71 GiB (97.89%) used: 7.82 GiB (14.3%)
    fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: c73bb738-2123-4465-bdfe-dc489caff8e3
  ID-1: /dev/sda1 maj-min: 8:1 size: 55.89 GiB fs: ntfs label: N/A
    uuid: 5EC6ABFAC6ABD097
  ID-2: /dev/sda2 maj-min: 8:2 size: 111.78 GiB fs: ntfs label: N/A
    uuid: 94E6583EE65822B2
  ID-3: /dev/sdb1 maj-min: 8:17 size: 931.48 GiB fs: exfat label: Ventoy
    uuid: 4E21-0000
  ID-4: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
    uuid: B2C8-40D2
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.3:3 info: Chicony 1.3M HD WebCam type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b23d class-ID: 0e02
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.1:3 info: SINOWEALTH Wired Gaming Mouse type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 480mA chip-ID: 258a:0029 class-ID: 0301
  Device-2: 2-1.2:4 info: INSTANT USB Keyboard type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 100mA chip-ID: 30fa:2031 class-ID: 0300
  Device-3: 2-1.3:5 info: Samsung M3 Portable Hard Drive 1TB
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 30mA
    chip-ID: 04e8:61b6 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 201 Uptime: 4m wakeups: 0 Init: systemd v: 254 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1122 libs: 319 tools: pamac pm: flatpak pkgs: 0 Shell: Sudo (sudo)
  v: 1.9.15p4 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Google — ваш друг и переведет его для вас.
You have a hybrid system.
With an iGPU (intel) and a dGPU (nvidia).
The nvidia profile just is not correct for your system.
Please see this in general:
And you can show us about mhwd
mhwd -li -l
But from your description and info … it appears its quite old so using the older bumblebee implementation. So video-hybrid-intel-nvidia-390xx-bumblebee profile.
Basically you can test it with these commands
glxinfo | grep 'renderer string'
optirun glxinfo | grep 'renderer string'
primusrun glxinfo | grep 'renderer string'
Please don’t create duplicate topics. Your first post in the Pусской section of #languages was posted in English, so I’ve merged them and moved it to Support > Graphics & Display.
mhwd -li -l         ✔
> Installed PCI configs:
   network-broadcom-wl            2018.10.07               false            PCI
video-hybrid-intel-nvidia-390xx-bumblebee            2023.03.23               false            PCI
> 0000:03:00.0 (0200:14e4:4357) Network controller Broadcom:
> 0000:01:00.0 (0300:10de:1050) Display controller nVidia Corporation:
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:00:02.0 (0300:8086:0116) Display controller Intel Corporation:
OpenGL renderer string: Mesa Intel(R) HD Graphics 3000 (SNB GT2)
OpenGL renderer string: GeForce GT 520M/PCIe/SSE2
Seems to be working.
Whenever you want to use the nvidia you can call it with primusrun.
In the case of steam do not launch steam itself this way, but edit a game launch options to:
primusrun %command%
