hello everybody,
is there a way to get DLSS working? i got a 3080 max-q laptop gpu with 16gb. the latest 470.63.01 drivers are installed.
i tried different proton versions, experimental also of course.
any suggestions what i can try?
thanks
hello everybody,
thanks
Is it even possible right now? I don’t think so.
//EDIT: actually reading the release notes of latest Proton is clear:
Add optional support for Nvidia’s NVAPI GPU support library and DLSS. It is disabled by default and can be enabled with
PROTON_ENABLE_NVAPI=1
So try, add the startup parameter in your game properties on Steam
PROTON_ENABLE_NVAPI=1 %command%
thanks very much.
well, what can i say - reading helps …
