when i run mhwd
nothing happens…? When I made the os i didnt know whether to choose Open-Source drivers
or Propriety drivers
so I chose open-source - do I have to remake or something?
What is your goal?
to be able to have the right nvidia drivers; if i change the display to 144hz my screen starts flickering and dims, but i dont want this to happen so I need the drivers
This should do it…
sudo mhwd --auto pci nonfree 0300
On the GUI… well you need to apply it
Error: invalid use of option: -a/--auto
What system do you have?
inxi -Fazy
Otherwise read this: Configure Graphics Cards - Manjaro
EDIT: sorry my failure… it have to be nonfree
not unfree
xD
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4dabba46-d73a-4342-96f5-859c2418cd86 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop System: Gigabyte product: B460MDS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B460M DS3H v: x.x serial: <filter>
UEFI: American Megatrends v: F3 date: 05/27/2020
Info: 6-Core model: Intel Core i5-10500 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 3 microcode: EA
cache: L2: 12 MiB
bogomips: 74427
Speed: 3050 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3050 2: 2212
3: 1428 4: 852 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel alternate: nvidia_drm,nvidia bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NV137 v: 4.3 Mesa 21.2.1 direct render: Yes
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a3f0
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Device-3: Corsair CORSAIR HS60 HAPTIC Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6:5 chip-ID: 1b1c:0a5f
class-ID: 0300
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
vendor: Gigabyte driver: r8169 v: kernel port: 4000 bus-ID: 03:00.0
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:818b class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Local Storage: total: 1.02 TiB used: 14.22 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Gigabyte model: GP-GSTFS31120GNTD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-1: / raw-size: 111.49 GiB size: 109.18 GiB (97.93%)
used: 14.22 GiB (13.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nouveau temp: 37.0 C
Processes: 267 Uptime: 1h 25m wakeups: 0 Memory: 15.56 GiB
used: 1.79 GiB (11.5%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1152 lib: 331 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
I ran this;
sudo mhwd -a pci nonfree 0300
and it worked
what do i do with this?
[caeden@caeden-b460mds3h ~]$ sudo mhwd -a pci nonfree 0300
> Using config 'video-nvidia' for device: 0000:01:00.0 (0300:10de:1c82) Display controller nVidia Corporation GP107 [GeForce GTX 1050 Ti]
> Installing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
:: Synchronising package databases...
core downloading...
extra downloading...
community downloading...
multilib downloading...
warning: nvidia-utils-470.63.01-1 is up to date -- skipping
warning: linux414-nvidia-470.63.01-3 is up to date -- skipping
warning: linux513-nvidia-470.63.01-5 is up to date -- skipping
resolving dependencies...
Packages (1) lib32-nvidia-utils-470.63.01-1
Total Download Size: 39.36 MiB
Total Installed Size: 115.56 MiB
:: Retrieving packages...
Y
lib32-nvidia-utils-470.63.01-1-x86_64 downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
(1/1) Arming ConditionNeedsUpdate...
nvidia-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux414-nvidia: install reason has been set to 'explicitly installed'
linux513-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia
after running the command nothing has changed - switching to 144hz still glitches, running mhwd did nothing, still cant run nvidia
You need to reboot normally or just unload nouveau, load nvidia and restart Xorg. However… for a Newbie the safest way is just a reboot.
oh sweet the restart worked! cheers!
