hi folks,
may I ask for an advise on nvidia drivers. On last update I had some issues and it was proposed to not use proprietary drivers.
I use this computer for gaming, so what shall be used for best performance, compatibility (wine) etc.
For gaming, you definitely want the non-free (proprietary) driver. Just click the Auto Install Proprietary Driver button there to make sure the right profile is loaded.
thanks for that.
I did it and this is the output:
Starting
Warning: config ‘/var/lib/mhwd/local/pci/video-nvidia-455xx/MHWDCONFIG’ is invalid!
Skipping already installed config ‘video-nvidia’ for device: 0000:09:00.0 (0300:10de:1b06) Display controller nVidia Corporation GP102 [GeForce GTX 1080 Ti]
Done …
The proprietary drivers should already be installed based on the screenshot (“video-nvidia” - installed).
ahh okay, wasnt too sure because video-linux seems also installed.
so system takes whatever is most performant?
Hmm, apparently you’re not the only one:
Not exactly, though if video-nvidia is installed it will use that.
What’s the output of
mhwd -li
It should be:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2020.11.30 false PCI
Also the following should list nvidia as the driver:
inxi -G
> [desktop@desktop-systemproductname ~]$ mhwd -li
> Installed PCI configs:
video-nvidia 2020.11.30 false PCI video-linux 2018.05.04 true PCIWarning: No installed USB configs!
and the other one:
[desktop@desktop-systemproductname ~]$ inxi -N
Network: Device-1: Intel I211 Gigabit Network driver: igb
not exactly what is expected…
I think @Yochanan meant inxi -Gazy (or similar).
yep:
[desktop@desktop-systemproductname ~]$ inxi -Gazy
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 09:00.0
chip ID: 10de:1b06
Display: x11 server: X.Org 1.20.10 driver: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x572mm (40.0x22.5")
s-diag: 1166mm (45.9")
Monitor-1: DP-0 res: 3840x2160 hz: 60 dpi: 164 size: 596x335mm (23.5x13.2")
diag: 684mm (26.9")
OpenGL: renderer: GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Oops. Indeed I did. Post edited for posterity. ![]()
As you surmised, nvidia is taking priority so it really shouldn’t make any difference.
However, if you want to avoid MHWD errors, you can remove the free driver:
sudo mhwd -r pci video-linux
I was just wondering… I had the exact same problem. Is this the way forward for the mhwd? Meaning, Is it only me seeing a “video-nvidia” now instead of a list of specific drivers…aside from the older 390? Or is something still technically broken with my installs?
0000:01:00.0 (0300:10de:13c0) Display controller nVidia Corporation:
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Hi @abz7,
No, I don’t think anything’s broken. Yes, this is how things are going to stay.
The process has been changed significantly.
Also see here from earlier: Problems with new Manjaro update and nvidia
Ok Thanks so much!.. Since it’s arch… I can sometimes get OCD… want things to be up to date and look/work correct
