Hello,
I installed Manjaro KDE using the 5.15 installer. Everything worked using video-hybrid-intel-nvidia-prime aside from some major DPI issues. I would like to upgrade my kernel version, though. And no matter what other kernel I try, my nvidia card is no longer recognized. I can only see my nvidia card when I run kernel 5.15. Running kernel 5.19, I see the following system information
inxi --full --verbosity=7 --filter --no-host ✔
Kernel: 5.19.13-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 012MMP v: A01 serial: <superuser required> UEFI: Dell
v: 1.9.1 date: 04/18/2022
ID-1: BAT0 charge: 60.0 Wh (85.1%) condition: 70.5/95.1 Wh (74.2%)
volts: 12.6 min: 11.4 model: BYD DELL F8CPG17 type: Li-poly
serial: <filter> status: charging
RAM: total: 62.54 GiB used: 4.31 GiB (6.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: 8-core model: 11th Gen Intel Core i9-11980HK bits: 64 type: MT MCP
smt: enabled arch: Tiger Lake rev: 1 cache: L1: 640 KiB L2: 10 MiB
L3: 24 MiB
Speed (MHz): avg: 2871 high: 3300 min/max: 800/4900:5000 cores: 1: 3300
2: 3300 3: 3300 4: 3300 5: 3300 6: 952 7: 3300 8: 3300 9: 1004 10: 3300
11: 3300 12: 1085 13: 3300 14: 3300 15: 3300 16: 3300 bogomips: 105712
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: N/A arch: Ampere pcie: speed: 16 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:5 chip-ID: 0c45:672e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 model: Sharp 0x1517 res: 3840x2400 hz: 60 dpi: 266
size: 366x229mm (14.41x9.02") diag: 432mm (17") modes: 3840x2400
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Sound API: ALSA v: k5.19.13-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-4.4:4 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp0s13f0u4u4 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 3-14:8 chip-ID: 8087:0026 class-ID: e001
Device-1: luks-ee202c72-64ae-4916-bb74-d317153be0eb type: LUKS dm: dm-0
Components: p-1: nvme0n1p7
Local Storage: total: 3.73 TiB used: 122.27 GiB (3.2%)
ID-1: /dev/nvme0n1 vendor: KIOXIA model: KXG70PN84T09 NVMe 4096GB
size: 3.73 TiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 10904105 temp: 34.9 C scheme: GPT
ID-1: / size: 1.78 TiB used: 122.18 GiB (6.7%) fs: ext4 dev: /dev/dm-0
mapped: luks-ee202c72-64ae-4916-bb74-d317153be0eb label: N/A
uuid: c82bc853-4eb5-445d-a618-3ccb26991433
ID-2: /boot/efi size: 146 MiB used: 89.5 MiB (61.3%) fs: vfat
dev: /dev/nvme0n1p1 label: ESP uuid: 7019-72CC
ID-1: /dev/nvme0n1p2 size: 128 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 size: 1.9 TiB fs: bitlocker label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: AC4C9FD14C9F94A4
ID-4: /dev/nvme0n1p5 size: 16.39 GiB fs: ntfs label: Image
uuid: A6569FFC569FCB85
ID-5: /dev/nvme0n1p6 size: 1.37 GiB fs: ntfs label: DELLSUPPORT
uuid: 7486356B86352F4C
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 2-4:2 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 0bda:0487 class-ID: 0900
Hub-4: 2-4.3:3 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0413 class-ID: 0900
Device-1: 2-4.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-6: 3-5:2 info: Realtek Dell dock ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5487 class-ID: 0900
Hub-7: 3-5.3:4 info: Realtek Dell dock ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5413 class-ID: 0900
Device-1: 3-5.3.5:7 info: Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 413c:b06f
class-ID: 0300
Device-2: 3-5.5:6 info: Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 413c:b06e
class-ID: 0300
Device-3: 3-10:3 info: Shenzhen Goodix USB2.0 MISC
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-4: 3-11:5 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-5: 3-14:8 info: Intel AX201 Bluetooth type: Bluetooth
Hub-8: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 338 Uptime: 10m wakeups: 1068 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1297
pm: pacman pkgs: 1284 pm: flatpak pkgs: 13 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
