Nvidia can't change power state from D3cold to D0 (config space inaccessible)
Hi everyone,
When I reboot Manjaro sometimes (not always) I get this message: nvidia can’t change power state from D3cold to D0 (config space inaccessible)
I have to power off and on a couple of times before I’m able to start the system.
I have a Dell XPS15 9560 with Nvidia GTX 1050 and Intel 630 HD Graphics and I have “video-hybrid-intel-nvidia-450xx-prime” driver.
What should I do?
Thanks for taking the time!
Hello,
This seems to have been discussed on Nvidia forum
But i still can’t make much of it.
Also seem to be mentioned here, since 2019
https://patchwork.kernel.org/project/dri-devel/patch/20191017121901.13699-1-kherbst@redhat.com/
I wonder if with the upcoming to stable of the 455xx driver this issue will not happen…
Thanks Bogdan! I saw that too but couldn’t figure out if there’s a solution or not… it seems it’s not…
Sadly i can’t confirm either way or another, but hopefully someone else using a hybrid intel-nvidia GPUs laptop will pass by with some ideas.
Did all this came out while fixing the overheating, or it still does that too?
No, that was separate from the power thing… it happened right after the installation but I ignored it because I couldn’t find a solution and the power off and start again worked…
Since I’m at the troubleshooting day :slight_smile: do you have any idea what should I do so my mouse connected to an USB port be visible at the login screen? Now I have to unplug and plug the mouse USB port to be visible to the system.
Many thanks for taking the time!
That sounds like a TLP thing. Install tlpui package and disable the power management on that port, or the power saving.
I tried that… I changed USB_AUTOSUSPEND from ON to OFF but still can’t see the mouse at startup…
Is it a USB3 port? Change to a USB2 one.
Hello @theodore,
Yesterday night I installed kernel 5.10 and when checking for errors with sudo journalctl -p 3 -xb ,
I have these two errors
snd_hda_intel 0000:01:00.1: can't change power state from D3cold to D0 (config space inaccessible)
snd_hda_intel 0000:01:00.1: can't change power state from D3hot to D0 (config space inaccessible)
so I googled and stumbled upon this thread.
Do you experience anything out of the ordinary with the error ?
Did you resolve your error and if so, how ??
Thanks…
I’m also having this error when trying to use primusrun to require a program to use my NVIDIA GPU. I’ve been using optimus-manager but I’ve disabled it for now before enabling bumblebeed. Anyone have any other ideas? I’m at a loss here.
The key issue seems to be the cannot change power state portion. But what’s strange is that optimus-manager seems to have no problem switching the card on and off. Maybe the issue is switching the GPU while in an X session? Is there something I need to change in my xinit to allow the GPU to be switched on without logging out first?
From dmesg:
bbswitch: version 0.8
bbswitch: Found integrated VGA device 0000:00:02.0: \_SB_.PCI0.GFX0
bbswitch: Found discrete VGA device 0000:01:00.0: \_SB_.PCI0.PEG0.PEGP
bbswitch: detected an Optimus _DSM function
bbswitch: Succesfully loaded. Discrete card 0000:01:00.0 is on
nvidia-nvlink: Unregistered the Nvlink Core, major device number 511
bbswitch: disabling discrete graphics
bbswitch: enabling discrete graphics
pci 0000:01:00.0: can't change power state from D3cold to D0 (config space inaccessible)
nvidia-nvlink: Nvlink Core is being initialized, major device number 511
nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=none
NVRM: loading NVIDIA UNIX x86_64 Kernel Module  460.39  Thu Jan 21 21:54:06 UTC 2021
NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x65:1290)
NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
From journalctl -u bumblebeed
Mar 15 08:41:43 kratos bumblebeed[2910]: /usr/bin/bumblebeed 3.2.1-2017-02-27-Format:%h$ started
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(GPU-0):     check your system's kernel log for additional error
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(GPU-0):     messages and refer to Chapter 8: Common Problems in the
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(GPU-0):     README for additional information.
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) NVIDIA(0): Failing initialization of X screen
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) Screen(s) found, but none have a usable configuration.
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) no screens found(EE)
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) Please also check the log file at "/var/log/Xorg.8.log" for additional information.
Mar 15 08:42:05 kratos bumblebeed[2910]: [XORG] (EE) Server terminated with error (1). Closing log file.
Mar 15 08:42:05 kratos bumblebeed[2910]: X did not start properly
