My GPU is a piece of junk 2080 that I’ve already mentioned before, it requires you to enable and run the fans manually. Been doing that for years now. I currently am on the latest kernel 5.12.0-1 and the gpu fans still don’t spin without user intervention, but it’s not just me and my GPU. I’ve seen other threads on the web about 460.73 breaking the ability to change fan speed.
With the new 460.73.01 nVidia update, now the nvidia-settings program will not allow me to change the speed of the fans, at the bottom left of the program I get an error “Failed to set new Fan Speed!” Yes, I’ve enabled Coolbit flag 4 and in the nvidia-settings app, the applicaiton itself doesn’t allow changing the fan speed.
So I’m looking for help to roll back from 460.73.01 or test some future version as 460.73.01 is unusable.
Attempting to use the command line Errors out:
$ nvidia-settings -a "GPUTargetFanSpeed=40"
ERROR: Error assigning value 40 to attribute 'GPUTargetFanSpeed' (pc:1[fan:0]) as
specified in assignment 'GPUTargetFanSpeed=40' (Unknown Error).
$ nvidia-settings -a "[fan:0]/GPUTargetFanSpeed=40"
specified in assignment '[fan:0]/GPUTargetFanSpeed=40' (Unknown Error).
$ nvidia-settings -q fans
2 Fans on pc:1
[0] pc:1[fan:0] (Fan 0)
Has the following name:
FAN-0
[1] pc:1[fan:1] (Fan 1)
FAN-1
$ nvidia-settings -a "[FAN-0]/GPUTargetFanSpeed=40"
ERROR: Error assigning value 40 to attribute 'GPUTargetFanSpeed' (pc:1[fan:0]) as specified in assignment '[FAN-0]/GPUTargetFanSpeed=40' (Unknown Error).
$ nvidia-settings -q all
Attributes queryable via pc:1.0:
Attribute 'OperatingSystem' (pc:1.0): 0.
The valid values for 'OperatingSystem' are in the range 0 - 2 (inclusive).
'OperatingSystem' is a read-only attribute.
'OperatingSystem' can use the following target types: X Screen, GPU.
Attribute 'NvidiaDriverVersion' (pc:1.0): 460.73.01
'NvidiaDriverVersion' is a string attribute.
'NvidiaDriverVersion' is a read-only attribute.
'NvidiaDriverVersion' can use the following target types: X Screen, GPU.
Attribute 'NvControlVersion' (pc:1.0): 1.29
'NvControlVersion' is a string attribute.
'NvControlVersion' is a read-only attribute.
'NvControlVersion' can use the following target types: X Screen.
Attribute 'GLXServerVersion' (pc:1.0): 1.4
'GLXServerVersion' is a string attribute.
'GLXServerVersion' is a read-only attribute.
'GLXServerVersion' can use the following target types: X Screen.
Attribute 'GLXClientVersion' (pc:1.0): 1.4
'GLXClientVersion' is a string attribute.
'GLXClientVersion' is a read-only attribute.
'GLXClientVersion' can use the following target types: X Screen.
Attribute 'OpenGLVersion' (pc:1.0): 4.6.0 NVIDIA 460.73.01
'OpenGLVersion' is a string attribute.
'OpenGLVersion' is a read-only attribute.
'OpenGLVersion' can use the following target types: X Screen.
Attribute 'XRandRVersion' (pc:1.0): 1.6
'XRandRVersion' is a string attribute.
'XRandRVersion' is a read-only attribute.
'XRandRVersion' can use the following target types: X Screen.
Attribute 'XF86VidModeVersion' (pc:1.0): 2.2
'XF86VidModeVersion' is a string attribute.
'XF86VidModeVersion' is a read-only attribute.
'XF86VidModeVersion' can use the following target types: X Screen.
Attribute 'XvVersion' (pc:1.0): 2.2
'XvVersion' is a string attribute.
'XvVersion' is a read-only attribute.
'XvVersion' can use the following target types: X Screen.
Attribute 'TwinView' (pc:1.0): 1.
'TwinView' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'TwinView' is a read-only attribute.
'TwinView' can use the following target types: X Screen.
Attribute 'ConnectedDisplays' (pc:1.0): 0x00000900.
'ConnectedDisplays' is a bitmask attribute.
'ConnectedDisplays' is a read-only attribute.
'ConnectedDisplays' can use the following target types: X Screen, GPU.
Attribute 'EnabledDisplays' (pc:1.0): 0x00000900.
'EnabledDisplays' is a bitmask attribute.
'EnabledDisplays' is a read-only attribute.
'EnabledDisplays' can use the following target types: X Screen, GPU.
Attribute 'AssociatedDisplays' (pc:1.0): 0x0000ff00.
'AssociatedDisplays' is a bitmask attribute.
'AssociatedDisplays' can use the following target types: X Screen.
Attribute 'InitialPixmapPlacement' (pc:1.0): 2.
The valid values for 'InitialPixmapPlacement' are in the range 0 - 4 (inclusive).
'InitialPixmapPlacement' can use the following target types: X Screen.
Attribute 'MultiGpuDisplayOwner' (pc:1.0): 0.
'MultiGpuDisplayOwner' is an integer attribute.
'MultiGpuDisplayOwner' is a read-only attribute.
'MultiGpuDisplayOwner' can use the following target types: X Screen.
Attribute 'GlyphCache' (pc:1.0): 1.
'GlyphCache' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'GlyphCache' can use the following target types: X Screen.
Attribute 'Depth30Allowed' (pc:1.0): 1.
'Depth30Allowed' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'Depth30Allowed' is a read-only attribute.
'Depth30Allowed' can use the following target types: X Screen, GPU.
Attribute 'NoScanout' (pc:1.0): 0.
'NoScanout' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'NoScanout' is a read-only attribute.
'NoScanout' can use the following target types: X Screen, GPU.
Attribute 'XServerUniqueId' (pc:1.0): -231828629.
'XServerUniqueId' is an integer attribute.
'XServerUniqueId' is a read-only attribute.
'XServerUniqueId' can use the following target types: X Screen.
Attribute 'PixmapCache' (pc:1.0): 1.
'PixmapCache' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'PixmapCache' can use the following target types: X Screen.
Attribute 'PixmapCacheRoundSizeKB' (pc:1.0): 1024.
The valid values for 'PixmapCacheRoundSizeKB' are in the range 4 - 1048576 (inclusive).
'PixmapCacheRoundSizeKB' can use the following target types: X Screen.
Attribute 'AccelerateTrapezoids' (pc:1.0): 1.
'AccelerateTrapezoids' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'AccelerateTrapezoids' can use the following target types: X Screen.
Attribute 'ScreenPosition' (pc:1.0): x=0, y=0, width=3840, height=1080
'ScreenPosition' is a string attribute.
'ScreenPosition' is a read-only attribute.
'ScreenPosition' can use the following target types: X Screen.
Attribute 'SyncToVBlank' (pc:1.0): 1.
'SyncToVBlank' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'SyncToVBlank' can use the following target types: X Screen.
Attribute 'LogAniso' (pc:1.0): 0.
The valid values for 'LogAniso' are in the range 0 - 4 (inclusive).
'LogAniso' can use the following target types: X Screen.
Attribute 'FSAA' (pc:1.0): 0.
Valid values for 'FSAA' are: 0, 1, 5, 9, 10 and 11.
'FSAA' can use the following target types: X Screen.
Attribute 'TextureClamping' (pc:1.0): 1.
'TextureClamping' is an integer attribute.
'TextureClamping' can use the following target types: X Screen.
Attribute 'FXAA' (pc:1.0): 0.
'FXAA' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'FXAA' can use the following target types: X Screen.
Attribute 'AllowFlipping' (pc:1.0): 1.
'AllowFlipping' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'AllowFlipping' can use the following target types: X Screen.
Attribute 'FSAAAppControlled' (pc:1.0): 1.
'FSAAAppControlled' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'FSAAAppControlled' can use the following target types: X Screen.
Attribute 'LogAnisoAppControlled' (pc:1.0): 1.
'LogAnisoAppControlled' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'LogAnisoAppControlled' can use the following target types: X Screen.
Attribute 'OpenGLImageSettings' (pc:1.0): 3.
The valid values for 'OpenGLImageSettings' are in the range 0 - 3 (inclusive).
'OpenGLImageSettings' can use the following target types: X Screen.
Attribute 'FSAAAppEnhanced' (pc:1.0): 0.
'FSAAAppEnhanced' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'FSAAAppEnhanced' can use the following target types: X Screen.
Attribute 'SliMosaicModeAvailable' (pc:1.0): 0.
'SliMosaicModeAvailable' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'SliMosaicModeAvailable' is a read-only attribute.
'SliMosaicModeAvailable' can use the following target types: X Screen, GPU.
Attribute 'ShowGraphicsVisualIndicator' (pc:1.0): 0.
'ShowGraphicsVisualIndicator' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'ShowGraphicsVisualIndicator' can use the following target types: X Screen.
Attribute 'BusType' (pc:1.0): 2.
The valid values for 'BusType' are in the range 0 - 3 (inclusive).
'BusType' is a read-only attribute.
'BusType' can use the following target types: X Screen, GPU.
Attribute 'PCIEMaxLinkSpeed' (pc:1.0): 8000.
'PCIEMaxLinkSpeed' is an integer attribute.
'PCIEMaxLinkSpeed' is a read-only attribute.
'PCIEMaxLinkSpeed' can use the following target types: X Screen, GPU.
Attribute 'PCIEMaxLinkWidth' (pc:1.0): 16.
The valid values for 'PCIEMaxLinkWidth' are in the range 1 - 16 (inclusive).
'PCIEMaxLinkWidth' is a read-only attribute.
'PCIEMaxLinkWidth' can use the following target types: X Screen, GPU.
Attribute 'PCIECurrentLinkSpeed' (pc:1.0): 8000.
'PCIECurrentLinkSpeed' is an integer attribute.
'PCIECurrentLinkSpeed' is a read-only attribute.
'PCIECurrentLinkSpeed' can use the following target types: X Screen, GPU.
Attribute 'PCIECurrentLinkWidth' (pc:1.0): 8.
'PCIECurrentLinkWidth' is an integer attribute.
'PCIECurrentLinkWidth' is a read-only attribute.
'PCIECurrentLinkWidth' can use the following target types: X Screen, GPU.
Attribute 'VideoRam' (pc:1.0): 8388608.
'VideoRam' is an integer attribute.
'VideoRam' is a read-only attribute.
'VideoRam' can use the following target types: X Screen, GPU.
Attribute 'Irq' (pc:1.0): 44.
'Irq' is an integer attribute.
'Irq' is a read-only attribute.
'Irq' can use the following target types: X Screen, GPU.
Attribute 'CUDACores' (pc:1.0): 2944.
'CUDACores' is an integer attribute.
'CUDACores' is a read-only attribute.
'CUDACores' can use the following target types: X Screen, GPU.
Attribute 'GPUMemoryInterface' (pc:1.0): 256.
'GPUMemoryInterface' is an integer attribute.
'GPUMemoryInterface' is a read-only attribute.
'GPUMemoryInterface' can use the following target types: X Screen, GPU.
Attribute 'GPUCoreTemp' (pc:1.0): 41.
'GPUCoreTemp' is an integer attribute.
'GPUCoreTemp' is a read-only attribute.
'GPUCoreTemp' can use the following target types: X Screen, GPU.
Attribute 'GPUCurrentClockFreqs' (pc:1.0): 1515,7000.
'GPUCurrentClockFreqs' is a packed integer attribute.
'GPUCurrentClockFreqs' is a read-only attribute.
'GPUCurrentClockFreqs' can use the following target types: X Screen, GPU.
Attribute 'BusRate' (pc:1.0): 16.
The valid values for 'BusRate' are in the range 1 - 16 (inclusive).
'BusRate' is a read-only attribute.
'BusRate' can use the following target types: X Screen, GPU.
Attribute 'PCIEGen' (pc:1.0): 3.
'PCIEGen' is an integer attribute.
'PCIEGen' is a read-only attribute.
'PCIEGen' can use the following target types: X Screen, GPU.
Attribute 'GPUErrors' (pc:1.0): 0.
'GPUErrors' is an integer attribute.
'GPUErrors' is a read-only attribute.
'GPUErrors' can use the following target types: X Screen.
Attribute 'GPUPowerSource' (pc:1.0): 0.
'GPUPowerSource' is an integer attribute.
'GPUPowerSource' is a read-only attribute.
'GPUPowerSource' can use the following target types: X Screen, GPU.
Attribute 'GPUCurrentPerfLevel' (pc:1.0): 4.
'GPUCurrentPerfLevel' is an integer attribute.
'GPUCurrentPerfLevel' is a read-only attribute.
'GPUCurrentPerfLevel' can use the following target types: X Screen, GPU.
Attribute 'GPUAdaptiveClockState' (pc:1.0): 1.
'GPUAdaptiveClockState' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'GPUAdaptiveClockState' is a read-only attribute.
'GPUAdaptiveClockState' can use the following target types: X Screen, GPU.
Attribute 'ECCConfigurationSupported' (pc:1.0): 0.
'ECCConfigurationSupported' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'ECCConfigurationSupported' is a read-only attribute.
'ECCConfigurationSupported' can use the following target types: X Screen, GPU.
Attribute 'GPUCurrentClockFreqsString' (pc:1.0): nvclock=1515, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=7000, memclockmin=7000, memclockmax=7000, memclockeditable=1, memTransferRate=14000, memTransferRatemin=14000, memTransferRatemax=14000, memTransferRateeditable=1
'GPUCurrentClockFreqsString' is a string attribute.
'GPUCurrentClockFreqsString' can use the following target types: X Screen, GPU.
Attribute 'GPUPerfModes' (pc:1.0): perf=0, nvclock=300, nvclockmin=300, nvclockmax=645, nvclockeditable=1, memclock=405, memclockmin=405, memclockmax=405, memclockeditable=1, memTransferRate=810, memTransferRatemin=810, memTransferRatemax=810, memTransferRateeditable=1 ; perf=1, nvclock=300, nvclockmin=300, nvclockmax=2100, nvclockeditable=1, memclock=810, memclockmin=810, memclockmax=810, memclockeditable=1, memTransferRate=1620, memTransferRatemin=1620, memTransferRatemax=1620, memTransferRateeditable=1 ; perf=2, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=5000, memclockmin=5000, memclockmax=5000, memclockeditable=1, memTransferRate=10000, memTransferRatemin=10000, memTransferRatemax=10000, memTransferRateeditable=1 ; perf=3, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=6800, memclockmin=6800, memclockmax=6800, memclockeditable=1, memTransferRate=13600, memTransferRatemin=13600, memTransferRatemax=13600, memTransferRateeditable=1 ; perf=4, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=7000, memclockmin=7000, memclockmax=7000, memclockeditable=1, memTransferRate=14000, memTransferRatemin=14000, memTransferRatemax=14000, memTransferRateeditable=1
'GPUPerfModes' is a string attribute.
'GPUPerfModes' is a read-only attribute.
'GPUPerfModes' can use the following target types: X Screen, GPU.
Attribute 'GPUSlowdownTempThreshold' (pc:1.0): 97.
'GPUSlowdownTempThreshold' is an integer attribute.
'GPUSlowdownTempThreshold' is a read-only attribute.
'GPUSlowdownTempThreshold' can use the following target types: X Screen, GPU.
Attribute 'GPUShutdownTempThreshold' (pc:1.0): 100.
'GPUShutdownTempThreshold' is an integer attribute.
'GPUShutdownTempThreshold' is a read-only attribute.
'GPUShutdownTempThreshold' can use the following target types: X Screen, GPU.
Attribute 'GPUMaxOperatingTempThreshold' (pc:1.0): 88.
'GPUMaxOperatingTempThreshold' is an integer attribute.
'GPUMaxOperatingTempThreshold' is a read-only attribute.
'GPUMaxOperatingTempThreshold' can use the following target types: X Screen, GPU.
Attribute 'FrameLockAvailable' (pc:1.0; display device: TV-0): 0.
'FrameLockAvailable' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'FrameLockAvailable' is a read-only attribute.
'FrameLockAvailable' is display device specific.
'FrameLockAvailable' can use the following target types: X Screen, GPU, Display Device.
Attribute 'FrameLockAvailable' (pc:1.0; display device: TV-3): 0.
Attribute 'FrameLockFirmwareUnsupported' (pc:1.0): 0.
'FrameLockFirmwareUnsupported' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'FrameLockFirmwareUnsupported' is a read-only attribute.
'FrameLockFirmwareUnsupported' can use the following target types: X Screen, GPU.
Attribute 'DigitalVibrance' (pc:1.0; display device: TV-0): 0.
The valid values for 'DigitalVibrance' are in the range -1024 - 1023 (inclusive).
'DigitalVibrance' is display device specific.
'DigitalVibrance' can use the following target types: X Screen, GPU, Display Device.
Attribute 'DigitalVibrance' (pc:1.0; display device: TV-3): 0.
Attribute 'ImageSharpeningDefault' (pc:1.0; display device: TV-0): 127.
'ImageSharpeningDefault' is an integer attribute.
'ImageSharpeningDefault' is a read-only attribute.
'ImageSharpeningDefault' is display device specific.
'ImageSharpeningDefault' can use the following target types: X Screen, GPU, Display Device.
Attribute 'ImageSharpeningDefault' (pc:1.0; display device: TV-3): 127.
Attribute 'RefreshRate' (pc:1.0; display device: TV-0): 239.76 Hz.
'RefreshRate' is an integer attribute.
'RefreshRate' is a read-only attribute.
'RefreshRate' is display device specific.
'RefreshRate' can use the following target types: X Screen, GPU, Display Device.
Attribute 'RefreshRate' (pc:1.0; display device: TV-3): 239.76 Hz.
Attribute 'RefreshRate3' (pc:1.0; display device: TV-0): 239.764 Hz.
'RefreshRate3' is an integer attribute.
'RefreshRate3' is a read-only attribute.
'RefreshRate3' is display device specific.
'RefreshRate3' can use the following target types: X Screen, GPU, Display Device.
Attribute 'RefreshRate3' (pc:1.0; display device: TV-3): 239.764 Hz.
Attribute 'ColorSpace' (pc:1.0; display device: TV-0): 0.
Valid values for 'ColorSpace' are: 0.
'ColorSpace' is display device specific.
'ColorSpace' can use the following target types: X Screen, GPU, Display Device.
Attribute 'ColorSpace' (pc:1.0; display device: TV-3): 0.
Attribute 'ColorRange' (pc:1.0; display device: TV-0): 0.
Valid values for 'ColorRange' are: 0 and 1.
'ColorRange' is display device specific.
'ColorRange' can use the following target types: X Screen, GPU, Display Device.
Attribute 'ColorRange' (pc:1.0; display device: TV-3): 0.
Attribute 'CurrentColorSpace' (pc:1.0; display device: TV-0): 0.
Valid values for 'CurrentColorSpace' are: 0 and 3.
'CurrentColorSpace' is a read-only attribute.
'CurrentColorSpace' is display device specific.
'CurrentColorSpace' can use the following target types: X Screen, GPU, Display Device.
Attribute 'CurrentColorSpace' (pc:1.0; display device: TV-3): 0.
Attribute 'CurrentColorRange' (pc:1.0; display device: TV-0): 0.
Valid values for 'CurrentColorRange' are: 0 and 1.
'CurrentColorRange' is a read-only attribute.
'CurrentColorRange' is display device specific.
'CurrentColorRange' can use the following target types: X Screen, GPU, Display Device.
Attribute 'CurrentColorRange' (pc:1.0; display device: TV-3): 0.
Attribute 'CurrentMetaModeID' (pc:1.0): 50.
'CurrentMetaModeID' is an integer attribute.
'CurrentMetaModeID' can use the following target types: X Screen.
Attribute 'CurrentMetaMode' (pc:1.0): id=50, switchable=no, source=nv-control :: DPY-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DPY-3: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}
'CurrentMetaMode' is a string attribute.
'CurrentMetaMode' can use the following target types: X Screen.
Attribute 'XineramaInfoOrder' (pc:1.0): DP-2
'XineramaInfoOrder' is a string attribute.
'XineramaInfoOrder' can use the following target types: X Screen.
Attribute 'DisplayPortConnectorType' (pc:1.0; display device: TV-0): 1.
'DisplayPortConnectorType' is an integer attribute.
'DisplayPortConnectorType' is a read-only attribute.
'DisplayPortConnectorType' is display device specific.
'DisplayPortConnectorType' can use the following target types: X Screen, GPU, Display Device.
Attribute 'DisplayPortConnectorType' (pc:1.0; display device: TV-3): 1.
Attribute 'DisplayPortIsMultiStream' (pc:1.0; display device: TV-0): 0.
'DisplayPortIsMultiStream' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'DisplayPortIsMultiStream' is a read-only attribute.
'DisplayPortIsMultiStream' is display device specific.
'DisplayPortIsMultiStream' can use the following target types: X Screen, GPU, Display Device.
Attribute 'DisplayPortIsMultiStream' (pc:1.0; display device: TV-3): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1.0; display device: TV-0): 1.
'DisplayPortSinkIsAudioCapable' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'DisplayPortSinkIsAudioCapable' is a read-only attribute.
'DisplayPortSinkIsAudioCapable' is display device specific.
'DisplayPortSinkIsAudioCapable' can use the following target types: X Screen, GPU, Display Device.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1.0; display device: TV-3): 1.
Attribute 'XVideoSyncToDisplay' (pc:1.0): 0x00000100.
'XVideoSyncToDisplay' is a bitmask attribute.
'XVideoSyncToDisplay' can use the following target types: X Screen.
Attribute 'XVideoSyncToDisplayID' (pc:1.0): 5.
'XVideoSyncToDisplayID' is an integer attribute.
'XVideoSyncToDisplayID' can use the following target types: X Screen.
Attribute 'CurrentXVideoSyncToDisplayID' (pc:1.0): 0.
'CurrentXVideoSyncToDisplayID' is an integer attribute.
'CurrentXVideoSyncToDisplayID' is a read-only attribute.
'CurrentXVideoSyncToDisplayID' can use the following target types: X Screen.
Attributes queryable via pc:1[gpu:0]:
Attribute 'OperatingSystem' (pc:1[gpu:0]): 0.
Attribute 'NvidiaDriverVersion' (pc:1[gpu:0]): 460.73.01
Attribute 'ConnectedDisplays' (pc:1[gpu:0]): 0x00000900.
Attribute 'EnabledDisplays' (pc:1[gpu:0]): 0x00000900.
Attribute 'Depth30Allowed' (pc:1[gpu:0]): 1.
Attribute 'NoScanout' (pc:1[gpu:0]): 0.
Attribute 'SliMosaicModeAvailable' (pc:1[gpu:0]): 0.
Attribute 'BusType' (pc:1[gpu:0]): 2.
Attribute 'PCIEMaxLinkSpeed' (pc:1[gpu:0]): 8000.
Attribute 'PCIEMaxLinkWidth' (pc:1[gpu:0]): 16.
Attribute 'PCIECurrentLinkSpeed' (pc:1[gpu:0]): 8000.
Attribute 'PCIECurrentLinkWidth' (pc:1[gpu:0]): 8.
Attribute 'VideoRam' (pc:1[gpu:0]): 8388608.
Attribute 'TotalDedicatedGPUMemory' (pc:1[gpu:0]): 7979.
'TotalDedicatedGPUMemory' is an integer attribute.
'TotalDedicatedGPUMemory' is a read-only attribute.
'TotalDedicatedGPUMemory' can use the following target types: GPU.
Attribute 'UsedDedicatedGPUMemory' (pc:1[gpu:0]): 430.
'UsedDedicatedGPUMemory' is an integer attribute.
'UsedDedicatedGPUMemory' is a read-only attribute.
'UsedDedicatedGPUMemory' can use the following target types: GPU.
Attribute 'Irq' (pc:1[gpu:0]): 44.
Attribute 'CUDACores' (pc:1[gpu:0]): 2944.
Attribute 'GPUMemoryInterface' (pc:1[gpu:0]): 256.
Attribute 'GPUCoreTemp' (pc:1[gpu:0]): 41.
Attribute 'GPUCurrentClockFreqs' (pc:1[gpu:0]): 1515,7000.
Attribute 'BusRate' (pc:1[gpu:0]): 16.
Attribute 'PCIDomain' (pc:1[gpu:0]): 0.
'PCIDomain' is an integer attribute.
'PCIDomain' is a read-only attribute.
'PCIDomain' can use the following target types: GPU.
Attribute 'PCIBus' (pc:1[gpu:0]): 2.
'PCIBus' is an integer attribute.
'PCIBus' is a read-only attribute.
'PCIBus' can use the following target types: GPU.
Attribute 'PCIDevice' (pc:1[gpu:0]): 0.
'PCIDevice' is an integer attribute.
'PCIDevice' is a read-only attribute.
'PCIDevice' can use the following target types: GPU.
Attribute 'PCIFunc' (pc:1[gpu:0]): 0.
'PCIFunc' is an integer attribute.
'PCIFunc' is a read-only attribute.
'PCIFunc' can use the following target types: GPU.
Attribute 'PCIID' (pc:1[gpu:0]): 4318,7815.
'PCIID' is a packed integer attribute.
'PCIID' is a read-only attribute.
'PCIID' can use the following target types: GPU.
Attribute 'PCIEGen' (pc:1[gpu:0]): 3.
Attribute 'GPUPowerSource' (pc:1[gpu:0]): 0.
Attribute 'GPUCurrentPerfLevel' (pc:1[gpu:0]): 4.
Attribute 'GPUAdaptiveClockState' (pc:1[gpu:0]): 1.
Attribute 'GPUPowerMizerMode' (pc:1[gpu:0]): 2.
Valid values for 'GPUPowerMizerMode' are: 0, 1 and 2.
'GPUPowerMizerMode' can use the following target types: GPU.
Attribute 'GPUPowerMizerDefaultMode' (pc:1[gpu:0]): 0.
'GPUPowerMizerDefaultMode' is an integer attribute.
'GPUPowerMizerDefaultMode' is a read-only attribute.
'GPUPowerMizerDefaultMode' can use the following target types: GPU.
Attribute 'ECCSupported' (pc:1[gpu:0]): 0.
'ECCSupported' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'ECCSupported' is a read-only attribute.
'ECCSupported' can use the following target types: GPU.
Attribute 'ECCConfigurationSupported' (pc:1[gpu:0]): 0.
Attribute 'GPUFanControlState' (pc:1[gpu:0]): 1.
'GPUFanControlState' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'GPUFanControlState' can use the following target types: GPU.
Attribute 'BaseMosaic' (pc:1[gpu:0]): 0.
Valid values for 'BaseMosaic' are: 0.
'BaseMosaic' is a read-only attribute.
'BaseMosaic' can use the following target types: GPU.
Attribute 'MultiGpuPrimaryPossible' (pc:1[gpu:0]): 0.
'MultiGpuPrimaryPossible' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'MultiGpuPrimaryPossible' is a read-only attribute.
'MultiGpuPrimaryPossible' can use the following target types: GPU.
Attribute 'MultiGpuMasterPossible' (pc:1[gpu:0]): 0.
'MultiGpuMasterPossible' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'MultiGpuMasterPossible' is a read-only attribute.
'MultiGpuMasterPossible' can use the following target types: GPU.
Attribute 'VideoEncoderUtilization' (pc:1[gpu:0]): 0.
'VideoEncoderUtilization' is an integer attribute.
'VideoEncoderUtilization' is a read-only attribute.
'VideoEncoderUtilization' can use the following target types: GPU.
Attribute 'VideoDecoderUtilization' (pc:1[gpu:0]): 0.
'VideoDecoderUtilization' is an integer attribute.
'VideoDecoderUtilization' is a read-only attribute.
'VideoDecoderUtilization' can use the following target types: GPU.
Attribute 'GPUCurrentClockFreqsString' (pc:1[gpu:0]): nvclock=1515, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=7000, memclockmin=7000, memclockmax=7000, memclockeditable=1, memTransferRate=14000, memTransferRatemin=14000, memTransferRatemax=14000, memTransferRateeditable=1
Attribute 'GPUPerfModes' (pc:1[gpu:0]): perf=0, nvclock=300, nvclockmin=300, nvclockmax=645, nvclockeditable=1, memclock=405, memclockmin=405, memclockmax=405, memclockeditable=1, memTransferRate=810, memTransferRatemin=810, memTransferRatemax=810, memTransferRateeditable=1 ; perf=1, nvclock=300, nvclockmin=300, nvclockmax=2100, nvclockeditable=1, memclock=810, memclockmin=810, memclockmax=810, memclockeditable=1, memTransferRate=1620, memTransferRatemin=1620, memTransferRatemax=1620, memTransferRateeditable=1 ; perf=2, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=5000, memclockmin=5000, memclockmax=5000, memclockeditable=1, memTransferRate=10000, memTransferRatemin=10000, memTransferRatemax=10000, memTransferRateeditable=1 ; perf=3, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=6800, memclockmin=6800, memclockmax=6800, memclockeditable=1, memTransferRate=13600, memTransferRatemin=13600, memTransferRatemax=13600, memTransferRateeditable=1 ; perf=4, nvclock=300, nvclockmin=300, nvclockmax=2190, nvclockeditable=1, memclock=7000, memclockmin=7000, memclockmax=7000, memclockeditable=1, memTransferRate=14000, memTransferRatemin=14000, memTransferRatemax=14000, memTransferRateeditable=1
Attribute 'GpuUUID' (pc:1[gpu:0]): GPU-c5bcab0e-665f-fb27-ea04-e05f3716ffc3
'GpuUUID' is a string attribute.
'GpuUUID' is a read-only attribute.
'GpuUUID' can use the following target types: GPU.
Attribute 'GPUUtilization' (pc:1[gpu:0]): graphics=7, memory=20, video=0, PCIe=0
'GPUUtilization' is a string attribute.
'GPUUtilization' is a read-only attribute.
'GPUUtilization' can use the following target types: GPU.
Attribute 'GPUSlowdownTempThreshold' (pc:1[gpu:0]): 97.
Attribute 'GPUShutdownTempThreshold' (pc:1[gpu:0]): 100.
Attribute 'GPUMaxOperatingTempThreshold' (pc:1[gpu:0]): 88.
Attribute 'FrameLockAvailable' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'FrameLockAvailable' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'FrameLockFirmwareUnsupported' (pc:1[gpu:0]): 0.
Attribute 'Dithering' (pc:1[gpu:0]; display device: TV-0): 0.
'Dithering' is an integer attribute.
'Dithering' is display device specific.
'Dithering' can use the following target types: GPU, Display Device.
Attribute 'Dithering' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'CurrentDithering' (pc:1[gpu:0]; display device: TV-0): 1.
'CurrentDithering' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'CurrentDithering' is a read-only attribute.
'CurrentDithering' is display device specific.
'CurrentDithering' can use the following target types: GPU, Display Device.
Attribute 'CurrentDithering' (pc:1[gpu:0]; display device: TV-3): 1.
Attribute 'DitheringMode' (pc:1[gpu:0]; display device: TV-0): 0.
Valid values for 'DitheringMode' are: 0, 1, 2 and 3.
'DitheringMode' is display device specific.
'DitheringMode' can use the following target types: GPU, Display Device.
Attribute 'DitheringMode' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'CurrentDitheringMode' (pc:1[gpu:0]; display device: TV-0): 1.
'CurrentDitheringMode' is an integer attribute.
'CurrentDitheringMode' is a read-only attribute.
'CurrentDitheringMode' is display device specific.
'CurrentDitheringMode' can use the following target types: GPU, Display Device.
Attribute 'CurrentDitheringMode' (pc:1[gpu:0]; display device: TV-3): 1.
Attribute 'DitheringDepth' (pc:1[gpu:0]; display device: TV-0): 0.
'DitheringDepth' is an integer attribute.
'DitheringDepth' is display device specific.
'DitheringDepth' can use the following target types: GPU, Display Device.
Attribute 'DitheringDepth' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'CurrentDitheringDepth' (pc:1[gpu:0]; display device: TV-0): 2.
'CurrentDitheringDepth' is an integer attribute.
'CurrentDitheringDepth' is a read-only attribute.
'CurrentDitheringDepth' is display device specific.
'CurrentDitheringDepth' can use the following target types: GPU, Display Device.
Attribute 'CurrentDitheringDepth' (pc:1[gpu:0]; display device: TV-3): 2.
Attribute 'DigitalVibrance' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'DigitalVibrance' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'ImageSharpeningDefault' (pc:1[gpu:0]; display device: TV-0): 127.
Attribute 'ImageSharpeningDefault' (pc:1[gpu:0]; display device: TV-3): 127.
Attribute 'RefreshRate' (pc:1[gpu:0]; display device: TV-0): 239.76 Hz.
Attribute 'RefreshRate' (pc:1[gpu:0]; display device: TV-3): 239.76 Hz.
Attribute 'RefreshRate3' (pc:1[gpu:0]; display device: TV-0): 239.764 Hz.
Attribute 'RefreshRate3' (pc:1[gpu:0]; display device: TV-3): 239.764 Hz.
Attribute 'ColorSpace' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'ColorSpace' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'ColorRange' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'ColorRange' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'CurrentColorSpace' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'CurrentColorSpace' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'CurrentColorRange' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'CurrentColorRange' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[gpu:0]; display device: TV-0): 0.
'SynchronousPaletteUpdates' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'SynchronousPaletteUpdates' is display device specific.
'SynchronousPaletteUpdates' can use the following target types: GPU, Display Device.
Attribute 'SynchronousPaletteUpdates' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'Hdmi3D' (pc:1[gpu:0]; display device: TV-0): 0.
'Hdmi3D' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'Hdmi3D' is a read-only attribute.
'Hdmi3D' is display device specific.
'Hdmi3D' can use the following target types: GPU, Display Device.
Attribute 'Hdmi3D' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'DisplayPortConnectorType' (pc:1[gpu:0]; display device: TV-0): 1.
Attribute 'DisplayPortConnectorType' (pc:1[gpu:0]; display device: TV-3): 1.
Attribute 'DisplayPortIsMultiStream' (pc:1[gpu:0]; display device: TV-0): 0.
Attribute 'DisplayPortIsMultiStream' (pc:1[gpu:0]; display device: TV-3): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[gpu:0]; display device: TV-0): 1.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[gpu:0]; display device: TV-3): 1.
Attributes queryable via pc:1[fan:0]:
Attribute 'GPUTargetFanSpeed' (pc:1[fan:0]): 0.
The valid values for 'GPUTargetFanSpeed' are in the range 0 - 100 (inclusive).
'GPUTargetFanSpeed' can use the following target types: Fan.
Attribute 'GPUCurrentFanSpeed' (pc:1[fan:0]): 0.
The valid values for 'GPUCurrentFanSpeed' are in the range 0 - 100 (inclusive).
'GPUCurrentFanSpeed' is a read-only attribute.
'GPUCurrentFanSpeed' can use the following target types: Fan.
Attribute 'GPUCurrentFanSpeedRPM' (pc:1[fan:0]): 0.
'GPUCurrentFanSpeedRPM' is an integer attribute.
'GPUCurrentFanSpeedRPM' is a read-only attribute.
'GPUCurrentFanSpeedRPM' can use the following target types: Fan.
Attribute 'GPUFanControlType' (pc:1[fan:0]): 2.
'GPUFanControlType' is an integer attribute.
'GPUFanControlType' is a read-only attribute.
'GPUFanControlType' can use the following target types: Fan.
Attribute 'GPUFanTarget' (pc:1[fan:0]): 0x00000007.
'GPUFanTarget' is a bitmask attribute.
'GPUFanTarget' is a read-only attribute.
'GPUFanTarget' can use the following target types: Fan.
Attributes queryable via pc:1[fan:1]:
Attribute 'GPUTargetFanSpeed' (pc:1[fan:1]): 0.
Attribute 'GPUCurrentFanSpeed' (pc:1[fan:1]): 0.
Attribute 'GPUCurrentFanSpeedRPM' (pc:1[fan:1]): 0.
Attribute 'GPUFanControlType' (pc:1[fan:1]): 2.
Attribute 'GPUFanTarget' (pc:1[fan:1]): 0x00000007.
Attributes queryable via pc:1[thermalsensor:0]:
Attribute 'ThermalSensorReading' (pc:1[thermalsensor:0]): 41.
The valid values for 'ThermalSensorReading' are in the range 0 - 127 (inclusive).
'ThermalSensorReading' is a read-only attribute.
'ThermalSensorReading' can use the following target types: Thermal Sensor.
Attribute 'ThermalSensorProvider' (pc:1[thermalsensor:0]): 1.
'ThermalSensorProvider' is an integer attribute.
'ThermalSensorProvider' is a read-only attribute.
'ThermalSensorProvider' can use the following target types: Thermal Sensor.
Attribute 'ThermalSensorTarget' (pc:1[thermalsensor:0]): 1.
'ThermalSensorTarget' is an integer attribute.
'ThermalSensorTarget' is a read-only attribute.
'ThermalSensorTarget' can use the following target types: Thermal Sensor.
Attributes queryable via pc:1[dpy:0]:
Attribute 'FrameLockAvailable' (pc:1[dpy:0]): 0.
Attribute 'Dithering' (pc:1[dpy:0]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:0]): 1.
Attribute 'DitheringMode' (pc:1[dpy:0]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:0]): 1.
Attribute 'DitheringDepth' (pc:1[dpy:0]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:0]): 2.
Attribute 'DigitalVibrance' (pc:1[dpy:0]): 0.
Attribute 'ImageSharpeningDefault' (pc:1[dpy:0]): 127.
Attribute 'RefreshRate' (pc:1[dpy:0]): 239.76 Hz.
Attribute 'RefreshRate3' (pc:1[dpy:0]): 239.764 Hz.
Attribute 'ColorSpace' (pc:1[dpy:0]): 0.
Attribute 'ColorRange' (pc:1[dpy:0]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:0]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:0]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:0]): 0.
Attribute 'RandROutputID' (pc:1[dpy:0]): 445.
'RandROutputID' is an integer attribute.
'RandROutputID' is a read-only attribute.
'RandROutputID' is display device specific.
'RandROutputID' can use the following target types: Display Device.
Attribute 'Hdmi3D' (pc:1[dpy:0]): 0.
Attribute 'DisplayPortConnectorType' (pc:1[dpy:0]): 1.
Attribute 'DisplayPortIsMultiStream' (pc:1[dpy:0]): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[dpy:0]): 1.
Attribute 'DisplayVRRMode' (pc:1[dpy:0]): 0.
'DisplayVRRMode' is an integer attribute.
'DisplayVRRMode' is a read-only attribute.
'DisplayVRRMode' is display device specific.
'DisplayVRRMode' can use the following target types: Display Device.
Attribute 'DisplayVRRMinRefreshRate' (pc:1[dpy:0]): 0.
The valid values for 'DisplayVRRMinRefreshRate' are in the range 0 - 0 (inclusive).
'DisplayVRRMinRefreshRate' is a read-only attribute.
'DisplayVRRMinRefreshRate' is display device specific.
'DisplayVRRMinRefreshRate' can use the following target types: Display Device.
Attribute 'DisplayVRREnabled' (pc:1[dpy:0]): 0.
'DisplayVRREnabled' is a boolean attribute; valid values are: 1 (on/true) and 0 (off/false).
'DisplayVRREnabled' is a read-only attribute.
'DisplayVRREnabled' is display device specific.
'DisplayVRREnabled' can use the following target types: Display Device.
Attributes queryable via pc:1[dpy:1]:
Attribute 'FrameLockAvailable' (pc:1[dpy:1]): 0.
Attribute 'Dithering' (pc:1[dpy:1]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:1]): 0.
Attribute 'DitheringMode' (pc:1[dpy:1]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:1]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:1]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:1]): 0.
Attribute 'ColorSpace' (pc:1[dpy:1]): 0.
Attribute 'ColorRange' (pc:1[dpy:1]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:1]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:1]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:1]): 0.
Attribute 'RandROutputID' (pc:1[dpy:1]): 471.
Attribute 'DisplayVRRMode' (pc:1[dpy:1]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:1]): 0.
Attributes queryable via pc:1[dpy:2]:
Attribute 'FrameLockAvailable' (pc:1[dpy:2]): 0.
Attribute 'Dithering' (pc:1[dpy:2]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:2]): 0.
Attribute 'DitheringMode' (pc:1[dpy:2]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:2]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:2]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:2]): 0.
Attribute 'ColorSpace' (pc:1[dpy:2]): 0.
Attribute 'ColorRange' (pc:1[dpy:2]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:2]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:2]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:2]): 0.
Attribute 'RandROutputID' (pc:1[dpy:2]): 472.
Attribute 'DisplayVRRMode' (pc:1[dpy:2]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:2]): 0.
Attributes queryable via pc:1[dpy:3]:
Attribute 'FrameLockAvailable' (pc:1[dpy:3]): 0.
Attribute 'Dithering' (pc:1[dpy:3]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:3]): 1.
Attribute 'DitheringMode' (pc:1[dpy:3]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:3]): 1.
Attribute 'DitheringDepth' (pc:1[dpy:3]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:3]): 2.
Attribute 'DigitalVibrance' (pc:1[dpy:3]): 0.
Attribute 'ImageSharpeningDefault' (pc:1[dpy:3]): 127.
Attribute 'RefreshRate' (pc:1[dpy:3]): 239.76 Hz.
Attribute 'RefreshRate3' (pc:1[dpy:3]): 239.764 Hz.
Attribute 'ColorSpace' (pc:1[dpy:3]): 0.
Attribute 'ColorRange' (pc:1[dpy:3]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:3]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:3]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:3]): 0.
Attribute 'RandROutputID' (pc:1[dpy:3]): 473.
Attribute 'Hdmi3D' (pc:1[dpy:3]): 0.
Attribute 'DisplayPortConnectorType' (pc:1[dpy:3]): 1.
Attribute 'DisplayPortIsMultiStream' (pc:1[dpy:3]): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[dpy:3]): 1.
Attribute 'DisplayVRRMode' (pc:1[dpy:3]): 0.
Attribute 'DisplayVRRMinRefreshRate' (pc:1[dpy:3]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:3]): 0.
Attributes queryable via pc:1[dpy:4]:
Attribute 'FrameLockAvailable' (pc:1[dpy:4]): 0.
Attribute 'Dithering' (pc:1[dpy:4]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:4]): 0.
Attribute 'DitheringMode' (pc:1[dpy:4]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:4]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:4]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:4]): 0.
Attribute 'ColorSpace' (pc:1[dpy:4]): 0.
Attribute 'ColorRange' (pc:1[dpy:4]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:4]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:4]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:4]): 0.
Attribute 'RandROutputID' (pc:1[dpy:4]): 474.
Attribute 'DisplayVRRMode' (pc:1[dpy:4]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:4]): 0.
Attributes queryable via pc:1[dpy:5]:
Attribute 'FrameLockAvailable' (pc:1[dpy:5]): 0.
Attribute 'Dithering' (pc:1[dpy:5]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:5]): 0.
Attribute 'DitheringMode' (pc:1[dpy:5]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:5]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:5]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:5]): 0.
Attribute 'ColorSpace' (pc:1[dpy:5]): 0.
Attribute 'ColorRange' (pc:1[dpy:5]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:5]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:5]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:5]): 0.
Attribute 'RandROutputID' (pc:1[dpy:5]): 475.
Attribute 'DisplayPortConnectorType' (pc:1[dpy:5]): 0.
Attribute 'DisplayPortIsMultiStream' (pc:1[dpy:5]): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[dpy:5]): 0.
Attribute 'DisplayVRRMode' (pc:1[dpy:5]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:5]): 0.
Attributes queryable via pc:1[dpy:6]:
Attribute 'FrameLockAvailable' (pc:1[dpy:6]): 0.
Attribute 'Dithering' (pc:1[dpy:6]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:6]): 0.
Attribute 'DitheringMode' (pc:1[dpy:6]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:6]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:6]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:6]): 0.
Attribute 'ColorSpace' (pc:1[dpy:6]): 0.
Attribute 'ColorRange' (pc:1[dpy:6]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:6]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:6]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:6]): 0.
Attribute 'RandROutputID' (pc:1[dpy:6]): 476.
Attribute 'DisplayVRRMode' (pc:1[dpy:6]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:6]): 0.
Attributes queryable via pc:1[dpy:7]:
Attribute 'FrameLockAvailable' (pc:1[dpy:7]): 0.
Attribute 'Dithering' (pc:1[dpy:7]): 0.
Attribute 'CurrentDithering' (pc:1[dpy:7]): 0.
Attribute 'DitheringMode' (pc:1[dpy:7]): 0.
Attribute 'CurrentDitheringMode' (pc:1[dpy:7]): 0.
Attribute 'DitheringDepth' (pc:1[dpy:7]): 0.
Attribute 'CurrentDitheringDepth' (pc:1[dpy:7]): 0.
Attribute 'ColorSpace' (pc:1[dpy:7]): 0.
Attribute 'ColorRange' (pc:1[dpy:7]): 0.
Attribute 'CurrentColorSpace' (pc:1[dpy:7]): 0.
Attribute 'CurrentColorRange' (pc:1[dpy:7]): 0.
Attribute 'SynchronousPaletteUpdates' (pc:1[dpy:7]): 0.
Attribute 'RandROutputID' (pc:1[dpy:7]): 477.
Attribute 'DisplayPortConnectorType' (pc:1[dpy:7]): 0.
Attribute 'DisplayPortIsMultiStream' (pc:1[dpy:7]): 0.
Attribute 'DisplayPortSinkIsAudioCapable' (pc:1[dpy:7]): 0.
Attribute 'DisplayVRRMode' (pc:1[dpy:7]): 0.
Attribute 'DisplayVRREnabled' (pc:1[dpy:7]): 0.
