Hi,
I’m usually running the xanmod kernel and until yesterday, I could add the nvidia driver with the package nvidia-455xx-dkms in the AUR and keep a standard manjaro kernel installed with the nvidia driver provided by mhwd as a backup. The 455 dkms package disappeared from aur and now I can’t use a custom kernel with nvidia 455 anymore, the only way is to install the nvidia-beta-dkms package that try to remove the mhwd installed driver, this way I don’t have a working manjaro standard kernel as backup.
Adding the nvidia-dkms package to manjaro repositories would allow to use some custom kernel without relying on custom aur packages or manually install it, can you please consider to add this package?
