Hi there,
Thanks for your reply and for the warm welcome to the Manjaro community! I understand that my system is quite old, and I agree that an upgrade would be ideal. Unfortunately, I’m not in a position to get a new one at the moment.
I’ve tried testing with different kernels, including 6.16 and even 5.15 LTS, but the issue with window decorations in GNOME persists. Below is the system information you requested:
~ inxi --filter --verbosity=8 ✔
Kernel: 5.15.189-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=803926cb-6333-4e6a-a807-2584d1037d97 rw quiet splash
resume=UUID=77b8d87b-f163-450d-b849-7d9ab42c21be udev.log_priority=3
Desktop: GNOME v: 48.4 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P8H61-M LX2 v: Rev X.0x
BIOS: American Megatrends v: 0605 date: 05/09/2013
System RAM: total: 4 GiB available: 3.81 GiB used: 1.58 GiB (41.4%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: DIMM0 type: no module installed
Device-2: DIMM1 type: DDR3 detail: synchronous size: 4 GiB
speed: 1067 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: N/A part-no: N/A serial: N/A
Info: model: Intel Pentium G620 bits: 64 type: MCP arch: Sandy Bridge
level: v2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
stepping: 7 microcode: 0x2F
Topology: cpus: 1x dies: 1 cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB
desc: 1x3 MiB
Speed (MHz): avg: 2344 min/max: 1600/2600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2344 2: 2344 bogomips: 10381
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb est flush_l1d
fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_deadline_timer vme xsave xsaveopt
xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
prctl and seccomp
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: NVIDIA GF108 [GeForce GT 430] driver: nvidia v: 390.157
alternate: nouveau,nvidia_drm non-free: series: 390.xx+
status: legacy (EOL~2022-11-22) last: release: 390.157 kernel: 6.0
xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm built: 2010-2016 pcie:
gen: 2 speed: 5 GT/s lanes: 16 ports: active: none off: VGA-1
empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0de1 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
note: <missing: xdpyinfo/xrandr>
Monitor-1: VGA-1 model: Acer P226HQV serial: <filter> built: 2010
res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.651 y: 0.337 green:
x: 0.290 y: 0.604 blue: x: 0.141 y: 0.071 white: x: 0.314 y: 0.329
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
modes: 1920x1080, 1280x1024, 1440x900, 1280x800, 1152x864, 1024x768,
800x600, 640x480
API: EGL v: 1.5 platforms: gbm: drv: kms_swrast
API: OpenGL v: 4.5 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
glx-v: 1.4 direct-render: yes renderer: GeForce GT 430/PCIe/SSE2
memory: 1000 MiB
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xprop
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k5.15.189-2-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active
Device-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 modules: 8139cp port: d000 bus-ID: 05:00.0
chip-ID: 10ec:8139 class-ID: 0200
IF: enp5s0 state: unknown speed: 100 Mbps duplex: full mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Local Storage: total: 931.51 GiB used: 7.44 GiB (0.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EARS-00MVWB0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NS50 rev: XP01
dev-links: cdrom
ID-1: / raw-size: 923.14 GiB size: 907.57 GiB (98.31%) used: 7.44 GiB (0.8%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 803926cb-6333-4e6a-a807-2584d1037d97
ID-1: swap-1 type: partition size: 8.37 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: swap
uuid: 77b8d87b-f163-450d-b849-7d9ab42c21be
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.5:3 info: Logitech Mouse type: mouse
chip-ID: 046d:c077 class-ID: 0301
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 35%
Packages: pm: pacman pkgs: 888 libs: 280 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
3: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 202
1: cpu: 33.3% command: ps pid: 2752 mem: 3.51 MiB (0.0%)
2: cpu: 18.6% command: kgx pid: 2692 mem: 127.9 MiB (3.2%)
3: cpu: 17.7% command: firefox pid: 1790 mem: 520.1 MiB (13.3%)
4: cpu: 7.6% command: firefox pid: 2180 mem: 375.3 MiB (9.6%)
5: cpu: 7.1% command: Xorg pid: 1108 mem: 68.7 MiB (1.7%)
Memory top: 5 of 202
1: mem: 520.1 MiB (13.3%) command: firefox pid: 1790 cpu: 17.7%
2: mem: 375.3 MiB (9.6%) command: firefox pid: 2180 cpu: 7.6%
3: mem: 271.7 MiB (6.9%) command: gnome-shell pid: 1178 cpu: 4.2%
4: mem: 245.8 MiB (6.2%) command: firefox pid: 2009 cpu: 3.7%
5: mem: 132.1 MiB (3.3%) command: firefox pid: 1877 cpu: 0.2%
Processes: 202 Power: uptime: 10m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 1.51 GiB
services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 257
Compilers: N/A Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.38
~ uname -r 1|1 ✘
pacman -Qi nvidia
5.15.189-2-MANJARO
Version : 390.157-130
Description : NVIDIA kernel modules for linux515
Architecture : x86_64
URL : https://www.nvidia.com/
Licenses : custom
Groups : linux515-extramodules
Provides : nvidia=390.157 NVIDIA-MODULE
Depends On : linux515 nvidia-utils=390.157 libglvnd
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 9,12 MiB
Packager : Manjaro Build Server <build@manjaro.org>
Build Date : чт, 31-лип-2025 20:03:27 +0300
Install Date : вт, 26-сер-2025 13:54:03 +0300
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
