I’m having an issue with nvidia-settings not actually being set after following step in this page.
https://wiki.manjaro.org/index.php/Configure_NVIDIA_(non-free)_settings_and_load_them_on_Startup
My primary monitor is connected with display port and should be 1920x1080 at 144hz. It seems to pick up the resolution but never changes to 144hz and stays at 60hz.
I have a secondary monitor that has multiple other issues I’m guessing I’ll just tackle once the main monitor is working but it’s native 1920x1080 resolution at 60hz doesn’t get sensed and after applying the nvidia config and rebooting it just turned black and shows as disabled in nvidia-settings. I’m guessing I’ll have to edit the conf file to fix it? It doesn’t seem to have a “Monitor1” in the config to include it.
Here’s my system info the Graphics section shows it still at 60hz.
andy@manjaro ~]$ inxi --admin --verbosity=7 --filter --no-host --width -G
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3cfd0024-a497-4d9f-84c9-2c95c7d40f1a rw quiet apparmor=1
security=apparmor resume=UUID=433fa599-d4cd-4689-8cd0-5262333f634f
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: Z370 Killer SLI/ac
serial: <superuser required> UEFI: American Megatrends v: P3.30
date: 12/07/2018
RAM: total: 31.29 GiB used: 1.8 GiB (5.8%)
RAM Report:
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 801
5: 800 6: 800 7: 800 8: 800 9: 801 10: 800 11: 800 12: 800 bogomips: 88824
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1b81
class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x291mm (20.6x11.5")
s-diag: 599mm (23.6")
Monitor-1: DP-2 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 495.44
direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:10f0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel bus-ID: 07:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-12:3 chip-ID: 8087:0aa7 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 6.82 TiB used: 15.16 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:8 vendor: Crucial model: CT2000P2SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P2CR033 temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM006-2DM164
type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 032 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-1: / raw-size: 75.25 GiB size: 73.52 GiB (97.70%) used: 15.16 GiB (20.6%)
fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:6 label: N/A
uuid: 3cfd0024-a497-4d9f-84c9-2c95c7d40f1a
ID-2: /boot/efi raw-size: 1 GiB size: 1022.9 MiB (99.80%)
used: 292 KiB (0.0%) fs: vfat dev: /dev/nvme1n1p4 maj-min: 259:4
label: NO_LABEL uuid: BC7F-24E1
ID-1: swap-1 type: partition size: 1.95 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p7 maj-min: 259:7 label: N/A
uuid: 433fa599-d4cd-4689-8cd0-5262333f634f
ID-1: /dev/nvme0n1p1 maj-min: 259:9 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:10 size: 1.82 TiB fs: ntfs
label: Crucial 2TB uuid: 78FCCB41FCCAF900
ID-3: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 0877-6681
ID-4: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
ID-5: /dev/nvme1n1p3 maj-min: 259:3 size: 386.95 GiB fs: ntfs label: N/A
uuid: 42227E81227E7A2D
ID-6: /dev/nvme1n1p5 maj-min: 259:5 size: 508 MiB fs: ntfs label: N/A
uuid: BE7274A972746853
ID-7: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: linux-data
uuid: 08994d45-a4de-4aa0-b4c7-43e8482eca1e
ID-8: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
ID-9: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: MX500 2TB
uuid: FE8471B284716DD1
ID-10: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: ntfs label: WD Black
uuid: 26561B46561B15E1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-9:2 info: Cooler Master MK730 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 2516:008f class-ID: 0300
Device-2: 1-12:3 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
Device-3: 1-13:4 info: SINOWEALTH Wired Gaming Mouse type: Mouse,Keyboard
driver: glorious,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 480mA
chip-ID: 258a:0036 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
Processes: 305 Uptime: 3m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1088 lib: 316 flatpak: 0 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
[andy@manjaro ~]$
I get this error in terminal after trying save the config but the file seems to update.
andy@manjaro ~]$ sudo nvidia-settings
[sudo] password for andy:
(nvidia-settings:1852): GLib-GObject-CRITICAL **: 19:08:58.227: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
sh: line 1: pkg-config: command not found
Here’s the config file
andy@manjaro ~]$ cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 495.44
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Microstep MSI MAG241C"
HorizSync 180.0 - 180.0
VertRefresh 48.0 - 146.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GTX 1070"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-5"
Option "metamodes" "DP-2: 1920x1080_144 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I left the config file in /home default
# /home/andy/.nvidia-settings-rc
# Configuration file for nvidia-settings - the NVIDIA X Server Settings utility
# Generated on Wed Jan 5 18:34:53 2022
# ConfigProperties:
RcFileLocale = C
DisplayStatusBar = Yes
SliderTextEntries = Yes
IncludeDisplayNameInConfigFile = No
ShowQuitDialog = Yes
UpdateRulesOnProfileNameChange = Yes
Timer = PowerMizer_Monitor_(GPU_0),Yes,1000
Timer = Thermal_Monitor_(GPU_0),Yes,1000
Timer = Memory_Used_(GPU_0),Yes,3000
# Attributes:
0/SyncToVBlank=1
0/LogAniso=0
0/FSAA=0
0/TextureClamping=1
0/FXAA=0
0/AllowFlipping=1
0/FSAAAppControlled=1
0/LogAnisoAppControlled=1
0/OpenGLImageSettings=1
0/FSAAAppEnhanced=0
0/ShowGraphicsVisualIndicator=0
0/XVideoSyncToDisplayID=DP-2
[DPY:DVI-D-0]/Dithering=0
[DPY:DVI-D-0]/DitheringMode=0
[DPY:DVI-D-0]/DitheringDepth=0
[DPY:DVI-D-0]/ColorSpace=0
[DPY:DVI-D-0]/ColorRange=0
[DPY:DVI-D-0]/SynchronousPaletteUpdates=0
[DPY:HDMI-0]/RedBrightness=0.000000
[DPY:HDMI-0]/GreenBrightness=0.000000
[DPY:HDMI-0]/BlueBrightness=0.000000
[DPY:HDMI-0]/RedContrast=0.000000
[DPY:HDMI-0]/GreenContrast=0.000000
[DPY:HDMI-0]/BlueContrast=0.000000
[DPY:HDMI-0]/RedGamma=1.000000
[DPY:HDMI-0]/GreenGamma=1.000000
[DPY:HDMI-0]/BlueGamma=1.000000
[DPY:HDMI-0]/Dithering=0
[DPY:HDMI-0]/DitheringMode=0
[DPY:HDMI-0]/DitheringDepth=0
[DPY:HDMI-0]/DigitalVibrance=0
[DPY:HDMI-0]/ColorSpace=0
[DPY:HDMI-0]/ColorRange=0
[DPY:HDMI-0]/SynchronousPaletteUpdates=0
[DPY:HDMI-1]/Dithering=0
[DPY:HDMI-1]/DitheringMode=0
[DPY:HDMI-1]/DitheringDepth=0
[DPY:HDMI-1]/ColorSpace=0
[DPY:HDMI-1]/ColorRange=0
[DPY:HDMI-1]/SynchronousPaletteUpdates=0
[DPY:DP-0]/Dithering=0
[DPY:DP-0]/DitheringMode=0
[DPY:DP-0]/DitheringDepth=0
[DPY:DP-0]/ColorSpace=0
[DPY:DP-0]/ColorRange=0
[DPY:DP-0]/SynchronousPaletteUpdates=0
[DPY:DP-1]/Dithering=0
[DPY:DP-1]/DitheringMode=0
[DPY:DP-1]/DitheringDepth=0
[DPY:DP-1]/ColorSpace=0
[DPY:DP-1]/ColorRange=0
[DPY:DP-1]/SynchronousPaletteUpdates=0
[DPY:DP-2]/RedBrightness=0.000000
[DPY:DP-2]/GreenBrightness=0.000000
[DPY:DP-2]/BlueBrightness=0.000000
[DPY:DP-2]/RedContrast=0.000000
[DPY:DP-2]/GreenContrast=0.000000
[DPY:DP-2]/BlueContrast=0.000000
[DPY:DP-2]/RedGamma=1.000000
[DPY:DP-2]/GreenGamma=1.000000
[DPY:DP-2]/BlueGamma=1.000000
[DPY:DP-2]/Dithering=0
[DPY:DP-2]/DitheringMode=0
[DPY:DP-2]/DitheringDepth=0
[DPY:DP-2]/DigitalVibrance=0
[DPY:DP-2]/ColorSpace=0
[DPY:DP-2]/ColorRange=0
[DPY:DP-2]/SynchronousPaletteUpdates=0
[DPY:DP-3]/Dithering=0
[DPY:DP-3]/DitheringMode=0
[DPY:DP-3]/DitheringDepth=0
[DPY:DP-3]/ColorSpace=0
[DPY:DP-3]/ColorRange=0
[DPY:DP-3]/SynchronousPaletteUpdates=0
