finskiy
February 13, 2022, 4:44pm
#1
Hello! I’m using OBS Studio to record my screen. However, NVENC encoding doesnt work. I get this error:
and a console output:
Is this a known issue? My GPU is Nvidia Geforce GT1030, using proprietary drivers.
Pretty sure my GPU should support NVENC.
finskiy
February 13, 2022, 4:53pm
#2
Oh wait, i’m dumb. NVENC is not supported on my GPU at all. Sorry.
If it’s not supported then you can go to Settings > Output > Streaming and set the “Encoder” to “Software (x264)” and Apply. Same can be done for Recording also.
system
Closed
February 16, 2022, 7:01am
#4
