NV GPU fan speed too high since update 6.2
Hello,
since the big update that brought the KDE Plasma Version to 6.2 the GPU fans speed up like crazy in idle mode, while surfing, small updates etc.
Just for a comparison in Win and Kubuntu I am playing games like Horizon Zero Dawn or God of War and I can barely hear the fan’s. But as soon as I am starting Manjaro I can hear them in the next room just during updates where the GPU isnt really used.
I do not want to set the fan speed manually because I have no experience with that (even less under Linux), but this noise is unbearable. I cannot even watch a YT vid without the fans speeding up, slowing down every few seconds.
KDE Plasma Version: 6.2.5
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.1
Kernel Version: 5.15.177-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-9700K CPU @ 3.60GHz
Memory: 15,6 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 2080/PCIe/SSE2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z390 AORUS PRO
NV-driver is at 550.144.03 now but the earlier versions did not give a different result.
I hope someone can help.
Please provide inxi -zv8 so we can try to help you.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_CTYPE = (unset),
        LC_NUMERIC = "de_AT.UTF-8",
        LC_COLLATE = (unset),
        LC_TIME = "de_AT.UTF-8",
        LC_MESSAGES = (unset),
        LC_MONETARY = "en_AT.UTF-8",
        LC_ADDRESS = "de_AT.UTF-8",
        LC_IDENTIFICATION = "de_AT.UTF-8",
        LC_MEASUREMENT = "de_AT.UTF-8",
        LC_PAPER = "de_AT.UTF-8",
        LC_TELEPHONE = "de_AT.UTF-8",
        LC_NAME = "de_AT.UTF-8",
        LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
  Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=07d318bc-dcf4-48b4-8d93-778b982890d4 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x
    serial: <superuser required> uuid: <superuser required>
    UEFI-[Legacy]: American Megatrends v: F12d date: 12/18/2019
  System RAM: total: 16 GiB available: 15.55 GiB used: 2.82 GiB (18.2%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: G.Skill part-no: F4-3200C16-8GVKB
    serial: N/A
  Device-3: ChannelB-DIMM0 type: no module installed
  Device-4: ChannelB-DIMM1 type: DDR4 detail: synchronous size: 8 GiB
    serial: N/A
  Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 8 cores: 8 smt: <unsupported> cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4900 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 57616
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap
    smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Micro-Star MSI
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 01:00.0 chip-ID: 10de:1e82 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x342mm (31.57x13.46")
    s-diag: 872mm (34.33")
  Monitor-1: Unknown-1 mapped: DP-2 res: N/A size: 800x340mm (31.5x13.39")
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2080 driver: N/A device-ID: 10de:1e82
    surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
    bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
  API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Info: services: NetworkManager
  Local Storage: total: 4.78 TiB used: 444.33 GiB (9.1%)
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620331WD temp: 32.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
    fw-rev: 620311WD temp: 30.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
  ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.88 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 300.57 GiB size: 294.79 GiB (98.08%)
    used: 55.32 GiB (18.8%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
    uuid: 07d318bc-dcf4-48b4-8d93-778b982890d4
  ID-2: /run/media/fred/M.2-2TB-W raw-size: 1.82 TiB
    size: 1.82 TiB (100.00%) used: 389.01 GiB (20.9%) fs: ntfs
    dev: /dev/nvme1n1p1 maj-min: 259:2 label: M.2-2TB-W uuid: 5BFD0EB944863891
  ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 1.82 TiB fs: ext4 label: M.2A-2TB
    uuid: c616db53-89db-417b-a3c1-a4634f601fe3
  ID-2: /dev/sda1 maj-min: 8:1 size: 464.3 GiB fs: ntfs label: Win-SSD
    uuid: 6E9CD26C9CD22DF9
  ID-3: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
    uuid: 36E3-4747
  ID-4: /dev/sda3 maj-min: 8:3 size: 546 MiB fs: ntfs label: N/A
    uuid: 36F68638F685F7FF
  ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-6: /dev/sdb3 maj-min: 8:19 size: 16 GiB fs: vfat label: IPM
    uuid: 5474-9295
  ID-7: /dev/sdc1 maj-min: 8:33 size: 111.4 GiB fs: ntfs label: Win-Data
    uuid: 60BC39A7BC39791C
  ID-8: /dev/sdc2 maj-min: 8:34 size: 513 MiB fs: vfat label: N/A
    uuid: DEB8-B4C8
  ID-9: /dev/sdc3 maj-min: 8:35 size: 1 KiB fs: <superuser required>
  ID-10: /dev/sdc4 maj-min: 8:36 size: 17.11 GiB fs: swap label: N/A
    uuid: d2c63481-7f17-43a1-bb02-adf7ff350822
  ID-11: /dev/sdc5 maj-min: 8:37 size: 103.87 GiB fs: ext4 label: Kubuntu
    uuid: 716b289e-9908-4221-825a-cd721ffcaad6
  Hub-2: 1-11:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-11.4:4 info: Corsair H115i Platinum type: <vendor specific>
    driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 64mA chip-ID: 1b1c:0c13 class-ID: 0000 serial: <filter>
  Device-2: 1-12:3 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-3: 1-13:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-13.1:6 info: Turtle Beach Vulcan II TKL Pro type: HID,keyboard
    driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 10f5:5001 class-ID: 0300
  Device-2: 1-13.4:7 info: Logitech G MX518 Gaming Mouse (MU0053)
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08e class-ID: 0300 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 23.0 C pch: 39.0 C mobo: N/A gpu: nvidia
    temp: 29 C
  Fan Speeds (rpm): cpu: 0 fan-2: 0 fan-3: 0 gpu: nvidia fan: 48%
  Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.12
  Packages: pm: pacman pkgs: 1515 libs: 426 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 245
  1: cpu: 18.6% command: firefox pid: 1619 mem: 329.4 MiB (2.0%)
  2: cpu: 16.4% command: firefox pid: 1467 mem: 347.2 MiB (2.1%)
  3: cpu: 8.8% command: kwin_x11 pid: 688 mem: 601.3 MiB (3.7%)
  4: cpu: 7.4% command: Xorg pid: 583 mem: 130.6 MiB (0.8%)
  5: cpu: 5.7% command: dolphin pid: 1155 mem: 127.3 MiB (0.7%)
  Memory top: 5 of 245
  1: mem: 601.3 MiB (3.7%) command: kwin_x11 pid: 688 cpu: 8.8%
  2: mem: 347.2 MiB (2.1%) command: firefox pid: 1467 cpu: 16.4%
  3: mem: 329.4 MiB (2.0%) command: firefox pid: 1619 cpu: 18.6%
  4: mem: 310.6 MiB (1.9%) command: plasmashell pid: 704 cpu: 2.9%
  5: mem: 297.7 MiB (1.8%) command: WebKitWebProcess pid: 995 cpu: 3.5%
  Processes: 245 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,upowerd
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
Mod Edit: Fixed formatting. inxi is below the perl locale stuff.
Meanwhile I have updated the Kernel to 6.12.11.1. (fascinating how easy that is in Manjaro) but the problem persists.
You (and we) may find it helpful for you to read the HowTo Post section of the wiki.
You may find a thing or two about formating (like using ``` on a single line in front and past some text) to make your infos readable. :footprints:
I dont understand 80 % of the Linux wikis.
e.g. it says install pkgstats but trying to install it gives a “target not found” error.
If I understood them I wouldnt need to seek help in the forum. If one needs a wiki to understand a wiki (or to post in a forum) it gets too complex.
What says install pkgstats?
A target not found error means the package can’t be found in the local database. That would usually mean, as in this case, that the package doesn’t exist.
The forum has certain presentation guidelines, and information aimed at helping Members ask effective questions, and provide information required to assist others who might wish to help.
Links such as those already given are designed to empower you to create generally more useful Support requests that will attract quality responses from the community.
Spending a few minutes to read and understand what is required from you can only be beneficial.
I see nothing complex about that.
As a new or infrequent forum user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
Required Reading:
Resources:
Update Announcements:
The Update Announcements contain update related information and a Known Issues and Solutions section that should generally be checked before posting a request for support.
System Information:
inxi --verbosity=8 --filter
Be prepared to provide more information and outputs from other commands when asked.
In the forum rules: Please use a pastebin service when posting large amount of code or long logs.
Clicking on that says: " Please consider installing the pkgstats package, which provides a timer that sends a list of the packages installed on your system, along with the architecture and the mirrors you use"
I tried sudo pacman -Syu pkgstats and yay -S pkgstats
Both dont find any package.
So it is not needed then?
I had a question, got prompted to read a wiki about formatting where the word “format” or “formating” does not even appear when searching for it and the discussion ends up being about the format rather than about the PROBLEM! I find that sad.
The link is out of date, it’s meant to take you to information about pastebin services, but the destination page has changed and it no longer exists (it’s on a different page). Instead you’re taken to the top of the page, which shows an unrelated request for data collection using pkgstats.
The package seems to be Arch specific. Manjaro doesn’t have it.
Correct, it’s not needed.
We’re only human, mistakes happen. Perhaps this is what they meant:
Like it or not formatting is important. If things are formatted incorrectly it’s difficult to read, and it’s easy to miss things. Compare the current formatting of post #3 with the previous formatting, you’ll see it’s now much easier to read.
You’ll likely get better help if people can easily read about your issue and gain an
accurate understanding.
It’s usually just a short diversion and then back to the issue at hand. However it can distract from the issue if there’s too much conversation about it.
Unfortunately, I have no suggestions regarding your actual issue. So I’ll leave that to others.
Ditto.
After the correct format was applied by someone the output was not better readable at all because I had to move the bars from side to side all the time to even be able to read it. Even in fullscreen at UWQHD!
Thus I do still not see the advantage.
Anyways I have found the culprit on my own, it was coolercontrol, which I am using for controlling the pump and fans of the water-cooler. I did not realize that It also had taken over the GPU-vans.
The system went back to normal when I removed the GPU profile from coolercontrol.
It’s immensely more readable, instead of a huge wall of text where everything is mashed together, we now have properly formatted text, 1 line per line, that doesn’t make the page stupidly long.
Scroll up and click on the pencil at the top of the post, it’s got a 3 next to it, you’ll see the difference.
Use Shift + scrollwheel to scroll sideways.
Glad you got it sorted.
Nonetheless, you will conform in future, right?
Especially after it having been requested of you, and with the formatting being a part of forum guidelines for presentation.
