Hello,
I have noticed a strange behavior after updating the Julia package recently.
With the latest julia version of the Manjaro stable branch, if I run the following code for solving least squares:
using LinearAlgebra
m,n=100,14
t = [ i/(m-1) for i in 0:(m-1)]
A = [tau^j for tau in t, j in 0:n]
magic=2006.7874531048527;
y=exp.(sin.(4*t))/magic;
Q,R = qr(A);
x = R\(Q[:,1:size(A,2)]'*y)
I get
15-element Vector{Float64}:
[Some numerical values...]
1297.8034058697126
On the other hand, if i do the same on a version downloaded from the Julialang website (julia-1.7.2-linux-x86_64.tar.gz) (which is the exact same Julia version number as the one in the Manjaro package), I get
1.0000001533225875
which is the correct solution (as it is known analytically that the last entry of the solution is 1).
So, it seems that the version provided with Manjaro yields more numerical errors. I have also experienced this behavior on other operations (Cholesky factorization, etc…). Does anybody have any explanation of this?
Thanks!
My configuration:
CPU: Intel Core i7-1065G7,
Kernel 5.10.98-1-MANJARO (Manjaro stable),
julia package 2:1.7.2-1,
This is a sync package from Arch repo.
It was last updated on 2022-02-21 epoch2 v1.7.2-2
_
_ _ _(_)_ | Documentation: https://docs.julialang.org
(_) | (_) (_) |
_ _ _| |_ __ _ | Type "?" for help, "]?" for Pkg help.
| | | | | | |/ _` | |
| | |_| | | | (_| | | Version 1.7.2 (2022-02-06)
_/ |\__'_|_|_|\__'_| |
|__/ |
julia> using LinearAlgebra
julia> m,n=100,14
(100, 14)
julia> t = [ i/(m-1) for i in 0:(m-1)]
100-element Vector{Float64}:
0.0
0.010101010101010102
0.020202020202020204
0.030303030303030304
0.04040404040404041
0.050505050505050504
0.06060606060606061
0.0707070707070707
0.08080808080808081
0.09090909090909091
0.10101010101010101
0.1111111111111111
0.12121212121212122
0.8888888888888888
0.898989898989899
0.9090909090909091
0.9191919191919192
0.9292929292929293
0.9393939393939394
0.9494949494949495
0.9595959595959596
0.9696969696969697
0.9797979797979798
0.98989898989899
1.0
julia> A = [tau^j for tau in t, j in 0:n]
100×15 Matrix{Float64}:
1.0 0.0 0.0 0.0 0.0 … 0.0 0.0 0.0 0.0
1.0 0.010101 0.00010203 1.03061e-6 1.04102e-8 1.1169e-22 1.12818e-24 1.13957e-26 1.15108e-28
1.0 0.020202 0.000408122 8.24488e-6 1.66563e-7 2.2874e-19 4.62102e-21 9.33539e-23 1.88594e-24
1.0 0.030303 0.000918274 2.78265e-5 8.43226e-7 1.97855e-17 5.9956e-19 1.81685e-20 5.5056e-22
1.0 0.040404 0.00163249 6.5959e-5 2.66501e-6 4.6846e-16 1.89277e-17 7.64755e-19 3.08992e-20
1.0 0.0505051 0.00255076 0.000128826 6.50638e-6 … 5.4536e-15 2.75434e-16 1.39108e-17 7.02566e-19
1.0 0.0606061 0.00367309 0.000222612 1.34916e-5 4.05207e-14 2.4558e-15 1.48836e-16 9.02038e-18
1.0 0.0707071 0.00499949 0.000353499 2.49949e-5 2.20847e-13 1.56154e-14 1.10412e-15 7.80692e-17
1.0 0.0808081 0.00652995 0.000527672 4.26402e-5 9.59407e-13 7.75278e-14 6.26487e-15 5.06252e-16
1.0 0.0909091 0.00826446 0.000751315 6.83013e-5 3.50494e-12 3.18631e-13 2.89664e-14 2.63331e-15
1.0 0.10101 0.010203 0.00103061 0.000104102 … 1.1169e-11 1.12818e-12 1.13957e-13 1.15108e-14
1.0 0.111111 0.0123457 0.00137174 0.000152416 3.18664e-11 3.54071e-12 3.93412e-13 4.37124e-14
1.0 0.121212 0.0146924 0.00178089 0.000215866 8.29863e-11 1.00589e-11 1.21927e-12 1.4779e-13
1.0 0.888889 0.790123 0.702332 0.624295 0.27373 0.243315 0.21628 0.192249
1.0 0.89899 0.808183 0.726548 0.65316 0.309958 0.278649 0.250503 0.225199
1.0 0.909091 0.826446 0.751315 0.683013 … 0.350494 0.318631 0.289664 0.263331
1.0 0.919192 0.844914 0.776638 0.713879 0.395793 0.36381 0.334411 0.307388
1.0 0.929293 0.863585 0.802524 0.74578 0.446354 0.414793 0.385464 0.358209
1.0 0.939394 0.882461 0.828978 0.778737 0.502719 0.472251 0.44363 0.416743
1.0 0.949495 0.901541 0.856008 0.812776 0.565483 0.536923 0.509806 0.484058
1.0 0.959596 0.920824 0.883619 0.847918 … 0.635291 0.609622 0.584991 0.561355
1.0 0.969697 0.940312 0.911818 0.884187 0.712847 0.691246 0.670299 0.649987
1.0 0.979798 0.960004 0.94061 0.921608 0.798918 0.782778 0.766964 0.75147
1.0 0.989899 0.9799 0.970002 0.960204 0.894334 0.8853 0.876358 0.867506
1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0
julia> magic=2006.7874531048527;
julia> y=exp.(sin.(4*t))/magic;
julia> Q,R = qr(A);
julia> x = R\(Q[:,1:size(A,2)]'*y)
0.0004983151685235319
0.0019899844279268786
0.0042128704771148325
-0.006236968547994574
0.07434877716958352
-0.8184198703622808
4.385806911859523
-16.417021607549707
42.446684448139415
-73.54081667380801
84.72882079897417
-64.10938507389506
30.631176100980912
-8.381424477628508
1.000000249382658
xabbu
March 21, 2022, 4:55pm
#3
Can’t reproduce it with julia 1.7.2 (2022-02-06) (package 2:1.7.2-2). The version 2:1.7.2-2 is in stable, so you are not up to date.
$ cat test.jl
using LinearAlgebra
m,n=100,14
Q,R = qr(A);
print(x)
$ julia test.jl
[0.0004983151685235319,
0.0019899844279268786,
0.0042128704771148325,
-0.006236968547994574,
0.07434877716958352,
-0.8184198703622808,
4.385806911859523,
-16.417021607549707,
42.446684448139415,
-73.54081667380801,
84.72882079897417,
-64.10938507389506,
30.631176100980912,
-8.381424477628508,
1.000000249382658]
(Added the newlines my self)
@xabbu @linux-aarhus ,
Many thanks for your answers! Indeed, I have updated the Julia package to 2:1.7.2-2, and now I get
0.0004983151685225632
0.001989984431559031
0.00421287030051599
-0.006236964961106366
0.07434873710404868
-0.8184195923094356
4.385805629349877
-16.417017518022305
42.446675237834555
-73.5408019144801
84.72880407676679
-64.10937198771387
30.631169374330916
-8.381422434673267
0.9999999716615636
which is the correct answer (it corresponds to the solution obtained by using the SVD).
Problem solved… thanks!
system
closed
March 26, 2022, 11:05am
#5
