Num Lock on login screen
Is it possible to have Num Lock enabled
on login screen of KDE (sddm) ?
Edit /etc/sddm.conf. Make sure that the three lines near the top look like this… :arrow_down:
[General]
InputMethod=
Numlock=on
Just tried to do this but I have sddm.conf.d which is the virtual keyboard. i am a bit dim so probably missing something. Thanks
I have changed /etc/sddm.conf and Num Lock is enabled during login.
I don’t have etc/sddm.conf only sddm.config.d which says virtual keyboard and has no GENERAL line. Do I just add the three lines below that?
I have the file /etc/sddm.conf and I am posting it:
[General]
InputMethod=
Numlock=on
[Theme]
CursorTheme=breeze_cursors
DisableAvatarsThreshold=7
EnableAvatars=true
FacesDir=/usr/share/sddm/faces
ThemeDir=/usr/share/sddm/themes
[Users]
DefaultPath=/usr/local/sbin:/usr/local/bin:/usr/bin
HideShells=
HideUsers=
RememberLastSession=true
RememberLastUser=true
ReuseSession=false
[Wayland]
EnableHiDPI=false
SessionCommand=/usr/share/sddm/scripts/wayland-session
SessionDir=/usr/share/wayland-sessions
SessionLogFile=.local/share/sddm/wayland-session.log
[X11]
DisplayCommand=/usr/share/sddm/scripts/Xsetup
DisplayStopCommand=/usr/share/sddm/scripts/Xstop
EnableHiDPI=false
MinimumVT=1
ServerArguments=-nolisten tcp
ServerPath=/usr/bin/X
SessionCommand=/usr/share/sddm/scripts/Xsession
SessionDir=/usr/share/xsessions
SessionLogFile=.local/share/sddm/xorg-session.log
UserAuthFile=.Xauthority
XauthPath=/usr/bin/xauth
XephyrPath=/usr/bin/Xephyr
I guess you only need the first 3 lines.
Thanks for your reply I don’t seem to have this folder, but I have found an easier method. Start /search for keyboard and there is an option there.
This is not a folder, it is a text file in the folder /etc/.
Do you have KDE installed ?
Or using sddm ?
Apologies should have said text file. This is in sddm.conf.d
InputMethod=qtvirtualkeyboard
Yes I am using KDE.
@nl.smart: this enables the Num Lock for the KDE session, but not during login.
