PU: quad core 11th Gen Intel Core i5-1135G7 (-MT MCP-)
speed/min/max: 575/400/4200 MHz Kernel: 6.5.5-1-MANJARO x86_64 Up: 17m
Mem: 3.08/7.51 GiB (41.0%) Storage: 1.36 TiB (4.6% used) Procs: 266 Shell: Zsh
inxi: 3.3.31
~ inxi ✔
CPU: quad core 11th Gen Intel Core i5-1135G7 (-MT MCP-)
speed/min/max: 591/400/4200 MHz Kernel: 6.5.5-1-MANJARO x86_64 Up: 18m
Mem: 3.08/7.51 GiB (41.0%) Storage: 1.36 TiB (4.6% used) Procs: 264 Shell: Zsh
inxi: 3.3.31
~ inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 6.5.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: Dell product: Latitude 3420 v: N/A
Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> UEFI: Dell
v: 1.3.1 date: 04/23/2021
ID-1: BAT0 charge: 7.1 Wh (17.4%) condition: 40.8/40.8 Wh (100.0%)
volts: 10.4 min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial: <filter>
status: discharging
System RAM: total: 8 GiB note: est. available: 7.51 GiB
used: 3.11 GiB (41.5%)
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xAC
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 448 high: 791 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 791
5: 400 6: 400 7: 400 8: 400 bogomips: 22120
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0c45:6d1a
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: 1366x768 hz: 60
dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.33 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.5.5-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active
tools: pactl,pw-cat,pw-cli
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s port: 3000 bus-ID: 2c:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp44s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.36 TiB used: 64.04 GiB (4.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0N01 temp: 33.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 01 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 36.97 GiB (48.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1C6D-8153
ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%)
used: 27.07 GiB (7.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: vfat label: N/A
uuid: 7616-A725
ID-2: /dev/sda2 maj-min: 8:2 size: 921.73 GiB fs: ext4 label: endeavouros
uuid: c5836b3c-5bb7-4d47-8d49-56202845d398
ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: swap
uuid: 0a93cecb-4ed9-4925-aff6-72849d60ff7e
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-4:2 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6d1a class-ID: 0e02
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
System Temperatures: cpu: 30.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 264 Uptime: 19m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1505
pm: pacman pkgs: 1487 libs: 434 tools: pamac,yay pm: flatpak pkgs: 18
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.31
Buen dia, hoy al alctualizar ,muestra esto en la terminal
sudo pacman -Syu
[sudo] contraseña para juliogl:
Lo siento, pruebe otra vez.
:: Sincronizando las bases de datos de los paquetes…
core está actualizado
extra está actualizado
community está actualizado
multilib está actualizado
DEB_Arch_Extra 7,3 KiB 7,26 KiB/s 00:01 [###########################################################] 100%
:: Iniciando actualización completa del sistema…
:: ¿Remplazar kirigami-addons con extra/kirigami-addons5? [S/n] S
advertencia: kpeoplevcard: la versión instalada (0.1+r38.32d50a9-1) es más nueva que extra (0.1-2)
resolviendo dependencias…
buscando conflictos entre paquetes…
error: no se pudo preparar la operación (no se pudo satisfacer las dependencias)
:: instalando kpeople5 (5.111.0-1) se rompe la dependencia con «kpeople», necesaria para el paquete kpeoplevcard
:: instalando kcontacts5 (5.111.0-1) se rompe la dependencia con «kcontacts», necesaria para el paquete kpeoplevcard
Y no me deja continuar con la actualizacion, yo puse si al reemplazo del paquete, quizás es no,pero no lo hice, tal vez necesito eliminar algún paquete, no se, algún tip para resolverlo?
Muchas gracias y buen día
