Hello,
Sorry in advance for the newbie question.
I have an NTFS partition with all my documents on it, such that I can share it between my windows partiton and my linux partition.
I have mounted it through /etc/fstab, which looks like this:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=3635-8AF0 /boot/efi vfat umask=0077 0 2
UUID=f1845f90-15dc-4b37-94a3-6515fb2ceb8e / ext4 defaults,noatime 0
/swapfile none swap defaults 0 0
UUID="1D254BE563D71870" /mnt/ntfs/ ntfs-3g nls-utf8,umask-0222,uid-1000,gid-1000,ro 0 0
I have ntfs-3g installed, but the drive is still mounted read-only.
In case it helps, here’s the output of lsblk --fs:
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /var/lib/snapd/snap/code/119
loop1 squashfs 4.0 0 100% /var/lib/snapd/snap/core/14399
loop2 squashfs 4.0 0 100% /var/lib/snapd/snap/anbox/186
loop3 squashfs 4.0 0 100% /var/lib/snapd/snap/bare/5
loop4 squashfs 4.0 0 100% /var/lib/snapd/snap/code/118
loop5 squashfs 4.0 0 100% /var/lib/snapd/snap/core18/2667
loop6 squashfs 4.0 0 100% /var/lib/snapd/snap/core/14447
loop7 squashfs 4.0 0 100% /var/lib/snapd/snap/dotnet-runtime-50/23
loop8 squashfs 4.0 0 100% /var/lib/snapd/snap/core20/1822
loop9 squashfs 4.0 0 100% /var/lib/snapd/snap/core20/1778
loop10 squashfs 4.0 0 100% /var/lib/snapd/snap/core18/2679
loop11 squashfs 4.0 0 100% /var/lib/snapd/snap/dotnet-runtime-50/24
loop12 squashfs 4.0 0 100% /var/lib/snapd/snap/dotnet-sdk/164
loop13 squashfs 4.0 0 100% /var/lib/snapd/snap/dotnet-sdk/167
loop14 squashfs 4.0 0 100% /var/lib/snapd/snap/emote/19
loop15 squashfs 4.0 0 100% /var/lib/snapd/snap/flutter/126
loop16 squashfs 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
loop17 squashfs 4.0 0 100% /var/lib/snapd/snap/flutter/130
loop18 squashfs 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1534
loop19 squashfs 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1535
loop20 squashfs 4.0 0 100% /var/lib/snapd/snap/snapd/17883
loop21 squashfs 4.0 0 100% /var/lib/snapd/snap/snapd/17950
loop22 squashfs 4.0
nvme0n1
├─nvme0n1p1 vfat FAT32 3635-8AF0 68.7M 28% /boot/efi
├─nvme0n1p2
├─nvme0n1p3 BitLocker 2
├─nvme0n1p4 ntfs CC56633B56632604
├─nvme0n1p5 ext4 1.0 f1845f90-15dc-4b37-94a3-6515fb2ceb8e 150.4G 64% /
└─nvme0n1p6 ntfs 1D254BE563D71870 22.9G 56% /mnt/ntfs
Thanks in advance!
