Okay first it is a fresh installation and updated .
the Nvidia GT2xx was supported by nvidia with the nvidia-driver-340.xx
this driver is no more supported
so i use nouveau free driver
after fresh installation and reboot , there is no way to get a loginscreen , only blue white stripes.
or black screen random after reboot
so i digg into this problem
first i disabled sddm
reboot
LOGIN over ssh user 192.xxx.xxx.xxx
su --login root ...
lsmod gives me NO nouveau module loaded
after reboot
next step modprobe nouveau
okay
inxi -G
Device-1: NVIDIA GT216M [GeForce GT 330M] driver: N/A
Device-2: Z-Star Micro WebCam SCB-1900N driver: uvcvideo type: USB
Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver: X: loaded: nouveau,vesa
gpu: N/A tty: 131x71
API: EGL v: 1.5 drivers: kms_swrast,swrast platforms: gbm,surfaceless,device
API: OpenGL v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1 note: console (EGL sourced)
renderer: llvmpipe (LLVM 16.0.6 128 bits)
in lsmod nouveau didnât show up
okay
modprobe nouveau
inxi -G
Device-1: NVIDIA GT216M [GeForce GT 330M] driver: nouveau v: kernel
unloaded: vesa dri: nouveau gpu: nouveau tty: 131x71 resolution: 1600x900
API: EGL v: 1.4,1.5 drivers: nouveau,swrast platforms: gbm,surfaceless,device
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 23.1.9-manjaro1.1 note: console (EGL sourced)
renderer: NVA5, llvmpipe (LLVM 16.0.6 128 bits)
no login , only blue white stripes âŠ
so i did a
systemctl restart sddm
and it works.
but thats NOT the way it should work
has someone any idea where i can fix this issue
FINAL EDIT
i switched back to linux54 with nvidia-driver 340.xxx
and blocked any update of this 2 packages
see below
