Notification popup not working correctly
Wayland Gnome Desktop notification popup banner is across whole screen although text is wrapped to a narrow column on left hand side - unreadable
I have a screenshot but cannot see how to post it!?
It seems like it could be a theming issue.
Could you create a new User and login to that, then tell us if you experience the same issue?
In the meantime, please provide system information (see below) and follow the links (in particular the link marked with :eyes:) to learn how to use the forum effectively.
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Be prepared to provide more information and outputs from other commands whenever asked.
Required reading
Resources
Enclosed is a screenshot of the problem - the notification bar covers the full width of the screen. https://paste.pics/ae2409eb632808aa7f8ca6f6758b6240
I have created a new user and the problem still exists with that user.
My machine details:-
  Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=<withheld> rw quiet splash
    i915.modeset=1 intel_iommu=on preempt=voluntary apparmor=1
    security=apparmor
  Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 7080 v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <withheld>
  Mobo: Dell model: 0RR02N v: A00 serial: <withheld> part-nu: 09A4
    uuid: <withheld> UEFI: Dell v: 1.31.0 date: 11/14/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Illuminated Keyboard K800
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 30.93 GiB used: 3.78 GiB (12.2%)
  Info: model: Intel Core i5-10500T bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 3 microcode: 0xFE
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
    rep_good sdbg sep sgx sgx_lc smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: DP-1,DP-2 empty: DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:9bc8 class-ID: 0300
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: DP-1 model: LG (GoldStar) HDR 4K serial: <filter> built: 2022
    res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
    x: 0.278 y: 0.675 blue: x: 0.153 y: 0.047 white: x: 0.314 y: 0.329
    size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1080, 1600x900, 1280x1024, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 720x480, 640x480
  Monitor-2: DP-2 model: LG (GoldStar) HDR 4K serial: <filter> built: 2021
  API: EGL Message: EGL data requires eglinfo. Check --recommends.
  Info: Tools: x11: xprop,xrandr
  Packages: 2256 pm: pacman pkgs: 2181 libs: 533
    tools: gnome-software,pamac,yay pm: appimage pkgs: 0 pm: flatpak pkgs: 43
    pm: snap pkgs: 32
    1: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    4: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    7: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    8: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    9: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    10: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    11: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    12: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    13: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    14: https://manjaro.kurdy.org/stable/$repo/$arch
    15: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    16: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    17: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    18: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    20: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    22: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    23: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    24: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    25: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://manjaro.ynh.ovh/stable/$repo/$arch
    27: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    28: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    30: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    32: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    33: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    34: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    35: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    37: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    38: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    39: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    40: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    41: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    42: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    43: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    45: http://manjaro.grena.ge/stable/$repo/$arch
    46: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    47: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    48: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    49: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    50: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    51: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    52: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    53: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    54: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    55: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    56: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    57: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    58: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    59: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    60: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    61: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    62: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    63: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    64: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    65: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    66: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    67: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    68: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    69: https://mirror.init7.net/manjaro/stable/$repo/$arch
    70: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    71: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    72: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    73: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    75: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    76: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    77: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    79: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    81: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    83: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    84: https://linorg.usp.br/manjaro/stable/$repo/$arch
    85: https://mirrors2.manjaro.org/stable/$repo/$arch
    86: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    87: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    88: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    89: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    90: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    91: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    92: https://mirror.23m.com/manjaro/stable/$repo/$arch
    93: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    94: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    95: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 371
  1: cpu: 13.2% command: gnome-shell pid: 29090 mem: 539.2 MiB (1.7%)
  2: cpu: 5.0% command: chrome pid: 30340 mem: 329.5 MiB (1.0%)
  3: cpu: 4.4% command: chrome pid: 30610 mem: 250.1 MiB (0.7%)
  4: cpu: 3.7% command: keepassxc pid: 29872 mem: 240.1 MiB (0.7%)
  5: cpu: 2.4% command: chrome pid: 30387 mem: 251.7 MiB (0.7%)
  Memory top: 5 of 371
  1: mem: 539.2 MiB (1.7%) command: gnome-shell pid: 29090 cpu: 13.2%
  2: mem: 406.3 MiB (1.2%) command: mysqld pid: 1503 cpu: 0.4%
  3: mem: 329.5 MiB (1.0%) command: chrome pid: 30340 cpu: 5.0%
  4: mem: 293.8 MiB (0.9%) command: mutter-x11-frames pid: 29813 cpu: 1.2%
  5: mem: 251.7 MiB (0.7%) command: chrome pid: 30387 cpu: 2.4%
  Processes: 371 Power: uptime: 12h 7m states: freeze,mem,disk suspend: s2idle
    wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
    image: 12.36 GiB services: gsd-power, power-profiles-daemon, upowerd
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 running-in: gnome-terminal
    inxi: 3.3.37
Mod Edit: Fixed formatting
The notifications rendered as expected on a recent Gnome VM. I’m applying the 2025-02-18 sync/update now to see if it’s related.
Update;
I cannot reproduce the issue with notify-send. I suspect this may indeed be a rendering problem intruduced by a custom theme; of course, this is only a guess. You could try reverting to all standard theme components to see if the issue persists.
A brief search has revealed nothing specific; naturally, this doesn’t mean an issue (or a bug) might not be discovered in the meantime. However, until it is reproducible by multiple Users, it’s much too early to scream “Bug!”
Let’s leave your topic open until we have more information.
I have now identified that notifications works as expected with Default" theme but not with any of the “Matcha-…” themes? (I was using Matcha-dark-sea)
Unfortunately, Vince has not been updating Matcha much and has not adapted to recent GNOME changes. However, it may still work well with other Desktop Environments and Window Managers.
I understand the Matcha themes are getting a bit long-in-the-tooth – perhaps you might search the forum for suggestions for a replacement; either that, or stick with the default, I suppose.
