I’m getting a notification for Pamac but my system is fully updated. Did an update yesterday for a flatpak and it’s still showing. Been looking through the settings but nothing is tipping me off. Any ideas where I should look at?
clean? pamac clean
? pamac clean -b
force refresh? pamac update --force-refresh
did you enable a check for foreign package changes - AUR or flatpak?
There might still be a wonky issue with Dash to Dock. Does this work?
You actually have to clear the notification panel manually and then the badges match. Press the super key (Windows button) + V and clear list. All your badges will sync and be correct. Gnome stores all your notifications until you clear them and all are reflected in the application badges.
Yes I enabled flatpak and allowed it to check for updates.
Thank you that was it, it was a notification that it had updated packages successfully.
