I reinstalled my Manjaro Plasma, and after this my notebook webcam is randomly working in Brave Browser or Chromium Browser, I join a google meet and sometimes it works and then freeze, sometimes it don’t even work and camera turns all black or don’t start. I don’t have any clue on how to investigate this error or fix it. I have a suspect is something related to codecs cause Whatsapp videos are failling as well.
This is my inxi -Fazy
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e2a4c474-95de-4d6a-8b6b-563a43d28703 rw rootflags=subvol=@ quiet
splash resume=UUID=15bb94fc-ec0d-40af-a6c3-fe6edbdcc364
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Laptop System: Dell product: Inspiron 5402 v: N/A
Mobo: Dell model: 0FJYHK v: A00 serial: <superuser required> part-nu: 0A01
uuid: <superuser required> UEFI: Dell v: 1.8.0 date: 10/01/2021
ID-1: BAT0 charge: 41.9 Wh (100.0%) condition: 41.9/53.0 Wh (79.1%)
volts: 15.8 min: 15.0 model: BYD DELL TXD0316 type: Unknown serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB8
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3800 min/max: 400/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800
7: 3800 8: 3800 bogomips: 27040
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nouveau
v: kernel non-free: 550/565.xx+ status: current (as of 2025-01;
EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-2021 bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16 class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:3 chip-ID: 0bda:5538
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris,nouveau gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
built: 2024 res: 3440x1440 dpi: 109 gamma: 1.2 size: 800x334mm (31.5x13.15")
diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
Monitor-2: eDP-1 model: BOE Display 0x082e built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.5 GiB unified: yes
API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: N/A device-ID: 8086:9a49
surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 46.84 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 92103061 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 120 GiB size: 120 GiB (100.00%) used: 31.62 GiB (26.4%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:4
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 348.44 GiB size: 348.44 GiB (100.00%)
used: 14.46 GiB (4.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:3
ID-4: /var/log raw-size: 120 GiB size: 120 GiB (100.00%)
used: 31.62 GiB (26.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:4
ID-1: swap-1 type: partition size: 8 GiB used: 775 MiB (9.5%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 88.0 C mobo: 68.0 C sodimm: SODIMM C gpu: nouveau
temp: 69.0 C
Fan Speeds (rpm): cpu: 5853 mobo: 5847
Memory: total: 16 GiB note: est. available: 15.35 GiB used: 10.75 GiB (70.0%)
Processes: 385 Power: uptime: 2h 21m states: freeze,mem,disk
suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.11 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1245 pm: pacman pkgs: 1230 libs: 330 tools: pamac pm: appimage
pkgs: 0 pm: flatpak pkgs: 15 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
