Hi,
I installed Manjaro/KDE on a new Notebook (Medion Akoya S17405).
The keyboard now gives no response.
In Grub menu or in BIOS it works fine. If the system is startet only some special key work. I can switch the key backlight on an off, adjust the screen brightness and screen on/off. Thats all. Every other key gives no response.
I googled a lot about it but cant find a working solution.
I hope you can give me a hint.
Here some data:
inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ea7fd4c6-296a-44c1-b785-cb93db3068a5 ro quiet apparmor=1
security=apparmor resume=UUID=787dcb01-88f7-4bf1-9050-6b53ab0018f0
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MEDION product: S17405 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: MEDION model: M17T serial: <filter> UEFI: American Megatrends LLC.
v: 208 date: 11/19/2020
ID-1: BAT0 charge: 38.6 Wh (92.3%) condition: 41.8/41.6 Wh (100.6%)
volts: 12.4 min: 11.4 model: M173137 type: Li-ion serial: N/A
status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Quad Core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 6E
cache: L2: 8 MiB
bogomips: 38720
Speed: 1301 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 1301 2: 1300
3: 1300 4: 1300 5: 1302 6: 1300 7: 1293 8: 1283
Device-1: Intel Iris Xe Graphics driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-7:3 chip-ID: 04f2:b5c6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 128 size: 380x220mm (15.0x8.7")
diag: 439mm (17.3")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a0c8
class-ID: 0401
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 11.2 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison model: E12-512G-SSD-B16-07
lanes: 4 rotation: SSD serial: <filter> rev: ECFM22.7 temp: 24.9 C
scheme: GPT
ID-1: / raw-size: 459.72 GiB size: 451.5 GiB (98.21%) used: 11.2 GiB (2.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.93 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 35.0 C mobo: 27.8 C
Processes: 220 Uptime: 30m wakeups: 4 Memory: 15.39 GiB
used: 1.81 GiB (11.8%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1281 lib: 406 flatpak: 0 Shell: Bash v: 5.1.0
running-in: konsole inxi: 3.3.
sudo evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: Sleep Button
/dev/input/event1: Power Button
/dev/input/event2: Lid Switch
/dev/input/event3: Video Bus
/dev/input/event4: PC Speaker
/dev/input/event5: ELAN0406:00 04F3:30A6 Mouse
/dev/input/event6: ELAN0406:00 04F3:30A6 Touchpad
/dev/input/event7: USB2.0 HD UVC WebCam: USB2.0 HD
/dev/input/event8: HDA Intel PCH Mic
/dev/input/event9: HDA Intel PCH Headphone
/dev/input/event10: HDA Intel PCH HDMI/DP,pcm=3
/dev/input/event11: HDA Intel PCH HDMI/DP,pcm=7
/dev/input/event12: HDA Intel PCH HDMI/DP,pcm=8
/dev/input/event13: HDA Intel PCH HDMI/DP,pcm=9
/dev/input/event14: HDA Intel PCH HDMI/DP,pcm=10
/dev/input/event15: HDA Intel PCH HDMI/DP,pcm=11
/dev/input/event16: HDA Intel PCH HDMI/DP,pcm=12
/dev/input/event17: HDA Intel PCH HDMI/DP,pcm=13
/dev/input/event18: HDA Intel PCH HDMI/DP,pcm=14
/dev/input/event19: HDA Intel PCH HDMI/DP,pcm=15
/dev/input/event20: HDA Intel PCH HDMI/DP,pcm=16
/dev/input/event21: Logitech Wireless Keyboard PID:4023
/dev/input/event22: Logitech Wireless Mouse
Select the device event number [0-22]:
For me it looks like there is no keyboard detected!?!? The Logitech is a USB keyboard.
The brightness keys react with event3.
Maybe there is someting wrong with the ELAN? There is no mouse installed .
