The error messages started with a “no action required”… not sure if that means the kernel knows the system isn’t using ECC RAM or not… but either way it’s weird that I got this error when I don’t use ECC RAM.
$ journalctl -k --priority err --boot 0
Jan 07 12:24:08 AM4-5600X-Linux kernel: [Hardware Error]: Deferred error, no action required.
Jan 07 12:24:08 AM4-5600X-Linux kernel: [Hardware Error]: CPU:1 (19:21:0) MC17_STATUS[Over|-|-|-|-|SyndV|Deferred|-|-]: 0xc1e692b0c646fd27
Jan 07 12:24:08 AM4-5600X-Linux kernel: [Hardware Error]: IPID: 0x0000000000000000, Syndrome: 0x0000000000000000
Jan 07 12:24:08 AM4-5600X-Linux kernel: [Hardware Error]: Unified Memory Controller Ext. Error Code: 6, DCQ SRAM ECC error.
Jan 07 12:24:08 AM4-5600X-Linux kernel: [Hardware Error]: cache level: L3/GEN, tx: DATA
full inxi
$ inxi -Fazym
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5d67a7c6-6cdf-446d-92f6-b7be1f0fb13d rw apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.90
date: 05/17/2021
RAM: total: 31.33 GiB used: 10.18 GiB (32.5%)
RAM Report:
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2912 high: 3841 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3841 2: 3057
3: 3178 4: 2840 5: 2214 6: 2461 7: 2969 8: 2879 9: 2879 10: 2876 11: 2879
12: 2879 bogomips: 88836
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Limited XFX Speedster MERC 319 driver: amdgpu v: kernel
bus-ID: 2f:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.3x15.0")
s-diag: 1407mm (55.4")
Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 93
size: 698x392mm (27.5x15.4") diag: 801mm (31.5")
Monitor-2: DisplayPort-1 res: 2560x1440 hz: 144 dpi: 93
size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
OpenGL: renderer: AMD Radeon RX 6800 XT (SIENNA_CICHLID DRM 3.42.0
5.15.12-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 2f:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Corsair CORSAIR VIRTUOSO SE USB Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:3 chip-ID: 1b1c:0a3d
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.42 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: f000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Supported mdraid levels: raid1
Device-1: md127 maj-min: 9:127 type: mdraid level: mirror status: active
Info: report: 2/2 UU blocks: 7813893120 chunk-size: N/A super-blocks: 1.2
Components: Online:
0: sdb1 maj-min: 8:17 size: 7.28 TiB
1: sdc1 maj-min: 8:33 size: 7.28 TiB
Local Storage: total: 19.33 TiB used: 9 TiB (46.5%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 613200WD temp: 38.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 102000WD temp: 35.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:1 vendor: Western Digital
rev: 613200WD temp: 41.9 C scheme: GPT
ID-4: /dev/nvme3n1 maj-min: 259:7 vendor: Western Digital
model: WDS200T2B0C-00PXH0 size: 1.82 TiB block-size: physical: 512 B
rev: 21705000 temp: 30.9 C scheme: GPT
ID-5: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: DB6Q scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-6: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD80EFAX-68KNBN0 size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A81 scheme: GPT
ID-7: /dev/sdc maj-min: 8:32 vendor: Western Digital
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 460.84 GiB (50.3%) fs: ext4 dev: /dev/nvme2n1p2 maj-min: 259:5
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:4
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: file size: 38 GiB used: 117.8 MiB (0.3%) priority: -2
file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C mem: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 363 Uptime: 2d 13h 11m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1463 lib: 404
flatpak: 0 Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
sudo inxi targeted to just Memory
RAM: total: 31.33 GiB used: 10.15 GiB (32.4%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 size: No Module Installed
Device-2: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: G.Skill part-no: F4-3600C16-16GTZNC
serial: N/A
Device-3: DIMM 0 size: No Module Installed
Device-4: DIMM 1 size: 16 GiB speed: 3600 MT/s type: DDR4
serial: N/A
I’m wondering if the new 5.15.12-1 kernel requires the recent AGESA 1.2.0.5 update. There was a BIOS update released for my motherboard that includes it in late Dec… but I thought I’d wait to see if others have experienced this issue before I dove into that rabbit hole.
Note: The only system change I made today was installing the new manjaro-pipewire package… maybe I should have rebooted?
