This is an informative post. The issue is resolved for now.
What happend is that I was using the below config for weeks. I put system to standby at nights. Yesterday when it was awakened it didn’t show anything on my LG Ultrawide display and all stuff was put into secondary Samsung display (which is connected to integrated graphics). It was also sluggish which I guessed because of weak onboard Intel graphics. Checked journalctl to see if there is any error. An irrelevant SGX is disabled by firmware
was there which I fixed. And a few more lines which I think are not relevant:
Aug 31 11:47:40 siavosh-ms7b18 systemd-udevd[306]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Aug 31 11:47:45 siavosh-ms7b18 kernel: ntfs3: Unknown parameter 'windows_names'
Aug 31 11:47:46 siavosh-ms7b18 wpa_supplicant[545]: bgscan simple: Failed to enable signal strength monitoring
Aug 31 11:47:55 siavosh-ms7b18 kded5[647]: org.kde.plasma.dataengine.geolocation: error: "Unknown host location.services.mozilla.com: Host not found"
Aug 31 11:48:10 siavosh-ms7b18 pulseaudio[785]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
Then went for Xorg log. I saw there that the display was not recognized. Which was strange because during boot it was displaying POST information correctly as the main display.
[ 1574.525] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 1574.525] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[ 1574.525] (II) AMDGPU(0): Output HDMI-A-3 disconnected
[ 1574.525] (II) AMDGPU(0): Output HDMI-A-4 disconnected
[ 1574.525] (II) AMDGPU(0): Output DVI-D-0 disconnected
So I did these actions to fix this:
- Went back to LTS kernel
- Disabled XMP in firmware settings
- Updated firmware
- Unplugged plugged display
- Shutdown and cut off power from all devices
- Unplugged second display (smaller Samsung monitor)
Non of the above sold the problem so I turned back to newest kernel and enabled XMP again.
I fixed the problem by swapping connections between HDMI port 1 and 2 of the LG monitor.
Here is my system info:
Host: siavosh-ms7b18 Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.1 parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=0baecea2-6a30-4ac4-ab13-4c58bcf15c2f rw quiet
udev.log_priority=3 zswap.enabled=0
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7B18 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MAG Z390 TOMAHAWK (MS-7B18) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.C2
date: 11/19/2021
Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless
Keyboard serial: 4062-d2-0e-20-3a charge: 55% (should be ignored)
rechargeable: yes status: discharging
RAM: total: 15.37 GiB used: 8.08 GiB (52.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xC (12) microcode: 0xF0
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 1500 high: 3600 min/max: 800/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 800 3: 800
4: 800 5: 3600 6: 800 7: 800 8: 800 bogomips: 57616
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep sgx sgx_lc smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: HDMI-A-3 empty: DP-3,HDMI-A-4,HDMI-A-5 bus-ID: 00:02.0
chip-ID: 8086:3e98 class-ID: 0380
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: HDMI-A-2
empty: DP-1, DP-2, DVI-D-1, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu,modesetting alternate: fbdev,vesa gpu: amdgpu,i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1182x285mm (46.54x11.22")
s-diag: 1216mm (47.87")
Monitor-1: not-matched mapped: HDMI-1-3 pos: primary,left res: 1920x1080
hz: 60 dpi: 102 size: 477x268mm (18.78x10.55") diag: 547mm (21.54")
modes: N/A
Monitor-2: not-matched mapped: HDMI-A-1 pos: primary,right res: 2560x1080
hz: 60 dpi: 81 size: 798x334mm (31.42x13.15") diag: 865mm (34.06")
modes: N/A
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.47 5.19.1-3-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno1 state: down mac: 00:d8:61:10:ae:5a
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: 00:d8:61:10:ae:5b
Device-3: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8812 class-ID: 0280
IF: wlp5s0 state: up mac: a8:63:7d:42:09:2e
IP v4: 192.168.1.60/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::a348:6db8:695d:e4fb/64 type: noprefixroute scope: link
IF-ID-1: br-060fa0bb413f state: up speed: 10000 Mbps duplex: unknown
mac: 02:42:c4:e8:f1:7f
IP v4: 192.168.2.1/24 scope: global broadcast: 192.168.2.255
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-2: br-d751fc7560f4 state: down mac: 02:42:62:f0:a7:a7
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-3: docker0 state: down mac: 02:42:89:7a:70:22
all]
IF-ID-4: veth6bfc2fe state: up speed: 10000 Mbps duplex: full
mac: 56:07:77:f5:78:8e
IF-ID-5: veth7ec9d3d state: up speed: 10000 Mbps duplex: full
mac: be:44:ff:4c:5f:29
WAN IP: 5.238.253.40
Local Storage: total: 6.16 TiB used: 3 TiB (48.8%)
model: MZVL2256HCHQ-00B00 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: S674NF0R111147
rev: GXA7301Q temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: TS512GSSD230S
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: E825370225 rev: 7BNR scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST6000NM0115-1YZ110
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: ZAD9G8D5 rev: SN05 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%) used: 52.9 GiB
(22.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0baecea2-6a30-4ac4-ab13-4c58bcf15c2f
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 316 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 6A3D-F50F
ID-3: /run/media/siavoshk/620E10310E1000A9 raw-size: 476.34 GiB
size: 476.34 GiB (100.00%) used: 331.34 GiB (69.6%) fs: ntfs dev: /dev/sda4
maj-min: 8:4 label: N/A uuid: 620E10310E1000A9
ID-4: /run/media/siavoshk/Seagate 6T raw-size: 5.46 TiB size: 5.46 TiB
(100.00%) used: 2.63 TiB (48.1%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: Seagate 6T uuid: B0106F77106F4386
Kernel: swappiness: 80 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-2: swap-2 type: zram size: 30.74 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: N/A
uuid: CA2ED3FB2ED3DE8F
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: DCFC-E19D
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdb1 maj-min: 8:17 size: 128 MiB fs: <superuser required>
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:3 info: A4Tech Optical Mouse Opto 510D / OP-620D
type: Mouse driver: a4tech,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 09da:000a class-ID: 0301
Device-3: 1-7:4 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7b18 class-ID: 0300 serial: A02018080110
Hub-2: 1-13:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.0 C pch: 44.0 C mobo: N/A gpu: amdgpu
temp: 45.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1712
Processes: 292 Uptime: 17m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1349 pm: pacman pkgs: 1339 libs: 332 tools: pamac pm: flatpak
pkgs: 10 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.21
