Not possible to update AUR virtualbox-ext-oracle or remove it
Hello,
I know there are several threads and the wiki, but with none of them I could fix my problem.
I have virtualbox installed and need the extension package.
My installed versions:
wolf@wolf-desktop:~$ vboxmanage --version
7.0.4r154605
wolf@wolf-desktop:~$ pamac search virtualbox-ext-oracle
virtualbox6-ext-oracle 6.1.40-2 AUR Oracle VM VirtualBox Extension Pack 6.1.40 (stable)
virtualbox-ext-oracle-dev 7.0.5.154732-1  AUR Oracle VM VirtualBox Extension Pack for virtualbox dev version
virtualbox-ext-oracle [Installiert] 7.0.2-1 AUR Oracle VM VirtualBox Extension Pack
Installing the extesion does not work and ends with error:
Vorbereitung...
Klone virtualbox-ext-oracle Build-Dateien...
Generiere virtualbox-ext-oracle Informationen...
Überprüfe virtualbox-ext-oracle Abhängigkeiten...
Abhängigkeiten werden aufgelöst...
Interne Konflikte werden überprüft...
Erstelle virtualbox-ext-oracle...
==> FEHLER: install-Datei (virtualbox-ext-oracle.install) existiert nicht oder ist keine reguläre Datei.
translated to english:
Preparation...
Clone virtualbox-ext-oracle build files...
Generate virtualbox-ext-oracle information...
Check virtualbox-ext-oracle dependencies...
Dependencies are resolved...
Internal conflicts are checked...
Create virtualbox-ext-oracle...
==> ERROR: install file (virtualbox-ext-oracle.install) does not exist or is not a regular file.
Thanks in advance!
Hello,
Always best to download it from their page, for the exact version of virtualbox you run.
you need Downloads – Oracle VM VirtualBox the 7.0.4 Oracle VM VirtualBox Extension Pack
Do a clean build. If you’re using Add/Remove Software (Pamac), remove the build folder; i.e.,
sudo rm -rf /var/tmp/pamac-build-exaveal/virtualbox-ext-oracle/
