Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=8c135ad8-b617-44e3-9f6f-70181f46948d rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop Mobo: MSI model: H81M-E33 (MS-7817) v: 1.0
serial: <superuser required> uuid: <superuser required>
UEFI: American Megatrends v: 6.8 date: 07/17/2018
System RAM: total: 10 GiB available: 9.66 GiB used: 5.53 GiB (57.3%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 8 GiB speed:
spec: 1600 MT/s actual: 1333 MT/s volts: curr: 2 min: 1.35 max: 2
width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT102464BD160B.C16 serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 2 GiB
speed: 1333 MT/s volts: curr: 2 min: 2 max: 2 width (bits): data: 64
total: 64 manufacturer: Samsung part-no: M378B5773CH0-CH9 serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i3-4160 bits: 64 type: MT MCP arch: Haswell
gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3C (60) stepping: 3 microcode: 0x28
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1200 min/max: 800/3600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 28812
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht ibpb ibrs invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X] driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 2
speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0 chip-ID: 1002:67ef
class-ID: 0300 temp: 33.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.92x22.44")
s-diag: 762mm (30.01")
Monitor-1: DP-1 pos: primary,bottom model: AOC 2270W serial: <filter>
built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 chroma: red: x: 0.635
y: 0.349 green: x: 0.322 y: 0.631 blue: x: 0.153 y: 0.047 white: x: 0.314
y: 0.329 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: top model: AAA built: 2016
res: 1920x1080 dpi: 85 gamma: 1.2 chroma: red: x: 0.635 y: 0.349 green:
x: 0.290 y: 0.588 blue: x: 0.141 y: 0.078 white: x: 0.314 y: 0.329
size: 575x323mm (22.64x12.72") modes: 1366x768, 1920x1080, 1280x768,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 560 Series (radeonsi
polaris11 LLVM 18.1.8 DRM 3.57 6.9.12-1-MANJARO) device-ID: 1002:67ef
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 560 Series (RADV POLARIS11) driver: mesa radv
v: 24.1.5-manjaro1.1 device-ID: 1002:67ef surfaces: xcb,xlib
Device-1: Intel 8 Series/C220 Series High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aae0
class-ID: 0403
API: ALSA v: k6.9.12-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 1.7 TiB used: 735.48 GiB (42.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Leven model: JAJS600M128C
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HTS727550A9E364
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A0E0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Toshiba model: DT01ACA100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: A-Data model: SU630 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD
serial: <filter> fw-rev: 024B scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 56.44 GiB (48.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 8c135ad8-b617-44e3-9f6f-70181f46948d
used: 25.6 MiB (8.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 6F6E-6AB4
ID-3: /home/<filter>/RHYSTELLE raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 571.49 GiB (61.4%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: Rhystelle uuid: F63EF3CB3EF38343
ID-4: /mnt/windows10 raw-size: 465.75 GiB size: 465.75 GiB (100.00%)
used: 107.53 GiB (23.1%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: F0F225B7F2258348
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdd1 maj-min: 8:49 size: 223.57 GiB fs: ext4 label: N/A
uuid: 104bd674-f936-4806-a824-7817081f57f3
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-1:2 info: Corsair K60 RGB PRO SE Mechanical Gaming Keyboard
type: keyboard,HID,mouse driver: hid-generic,usbhid interfaces: 4 rev: 2.0
chip-ID: 1b1c:1b8d class-ID: 0301 serial: <filter>
Device-2: 3-2:3 info: HUION Tablet_RTS-300 type: mouse,HID
driver: hid-generic,usbfs,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 480mA
chip-ID: 256c:0064 class-ID: 0300 serial: <filter>
Device-3: 3-3:4 info: USB OPTICAL MOUSE type: mouse,keyboard
chip-ID: 4e53:5407 class-ID: 0301
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): N/A
Packages: 1479 pm: pacman pkgs: 1460 libs: 390 tools: pamac,yay pm: flatpak
pkgs: 19
here my system info, also im sorry im really new and this is my first time using the forums ^^"
